I have developed firmware which communicates to an AWS IoT Core erver. To make sure the device is robust I decided to transmit data every 30s to the server. The network stays up, but I open and close a socket each transmission. I'm also testing in a lower signal strength area so I can handle non-optimal conditions. I'm using ncs v1.7.1.
After running the device for about an hour or so I've sometimes encountered this problem:
[00:49:04.473,236] [1;31m<err> lte_lc_helpers: Could not init AT params list, error: -12[0m
[00:49:04.473,236] [1;31m<err> lte_lc: Failed to parse notification (error -12): +CEREG: 1,"2711","0BBD6010",7,,,"11100000","1~[0m
Once this occurs the lte handler for lte_lc_connect_async no longer works in printing registration messages. So instead of printing registration messages, the firmware prints these errors. There is one ticket I've found which is related to this:
https://devzone.nordicsemi.com/f/nordic-q-a/77306/could-not-init-at-param-list-error--12-nrf9160
So I'm assuming I also have a problem with parse_cereg(), but how do I fix this problem? I'm not querying modem informing in my code. I'm letting the lte handler take care of that. As I mentioned I'm in a non-optimal area so I'm getting registration messages more frequently than most, but I don't see how I could get enough messages to fill up the param list.
Thanks for any help,
Chris
