nRF52-DK can be made to silently reset even with all ARM fault handlers implemented
We are developing a product based on nRF52832 and we need to verify that in case of problems, the device will "fail gracefully". So we looked at implementing the ARM handlers, and also making a test setup to verify that they are working OK. The test setup runs on the nRF52-DK and contains a minimal app (we call it "kamikaze") which has a simple UART interface, and which will do various nasty things to trigger the handlers when asked. (Of course you have to reset kamikaze after.)
All handlers print stack frame and fault registers to a simple bitbash UART, and flash LEDS in an infinite loop.
We were able initially to see that our HARD FAULT handler is OK. Then we enabled the BUS FAULT, MEMMANAGE FAULT and USAGE FAULT handlers and were able to trigger them all in different ways. (We also enabled DIV_BY_ZERO and ALIGNMENT faults.)
Just to see how the controller responded, we thought we would try writing some "evil recursive" code and try to overflow the stack. It was harder thna we thought, but we did it like this:
static volatile uint32_t dummy = 1;
uint32_t evil_recursive(uint32_t i)
  printf("N:%d MSP: 0x%08x", i, (uint32_t *)__get_MSP());
  return evil_recursive( i + dummy);
main()
  uint32_t i = evil_recursive(1);
We needed to compile with the
-fno-optimize-sibling-calls
flag, but this does cause a BUS FAULT after eating stack for a few minutes. The printf is a slow, blocking call to the bit bash UART.
So far so good.
Next to speed up the test, we removed the printf, expecting the same BUS FAULT, but sooner.
To our surprise, we didn't get that. The uC immediately resets, NO handler is triggered.
We also tried replacing the long string with a single UART puct() call, to make things happen quicker - now we also got the same silent reset.
Maybe we are missing something, but this is not what we want or expect. With all handlers implemented and working, we don't want it to be possible to make the ARM core silently reset.
We realise that what we are doing is pretty abusive and not at all a usual situation, but still, cannot easily explain how this can happen.
  • I got some compiler output for the two functions. First the one that DOES trigger a BUS FAULT:
    00026678 <evil_recursive>:
       26678:    b5f0          push    {r4, r5, r6, r7, lr}
       2667a:    4e4c          ldr    r6, [pc, #304]    ; (267ac <evil_recursive+0x134>)
       2667c:    b083          sub    sp, #12
       2667e:    4604          mov    r4, r0
       26680:    212f          movs    r1, #47    ; 0x2f
       26682:    4630          mov    r0, r6
       26684:    f004 fb8f     bl    2ada6 <strrchr>
       26688:    f3ef 8308     mrs    r3, MSP
       2668c:    4f48          ldr    r7, [pc, #288]    ; (267b0 <evil_recursive+0x138>)
       2668e:    4d49          ldr    r5, [pc, #292]    ; (267b4 <evil_recursive+0x13c>)
       26690:    9301          str    r3, [sp, #4]
       26692:    1c41          adds    r1, r0, #1
       26694:    463b          mov    r3, r7
       26696:    9400          str    r4, [sp, #0]
       26698:    223c          movs    r2, #60    ; 0x3c
       2669a:    2000          movs    r0, #0
       2669c:    f004 fa14     bl    2aac8 <project_log>
       266a0:    682b          ldr    r3, [r5, #0]
       266a2:    212f          movs    r1, #47    ; 0x2f
       266a4:    4630          mov    r0, r6
       266a6:    441c          add    r4, r3
       266a8:    f004 fb7d     bl    2ada6 <strrchr>
       266ac:    f3ef 8308     mrs    r3, MSP
       266b0:    223c          movs    r2, #60    ; 0x3c
       266b2:    9301          str    r3, [sp, #4]
       266b4:    1c41          adds    r1, r0, #1
       266b6:    9400          str    r4, [sp, #0]
       266b8:    463b          mov    r3, r7
       266ba:    2000          movs    r0, #0
       266bc:    f004 fa04     bl    2aac8 <project_log>
       266c0:    682b          ldr    r3, [r5, #0]
       266c2:    212f          movs    r1, #47    ; 0x2f
       266c4:    4630          mov    r0, r6
       266c6:    441c          add    r4, r3
       266c8:    f004 fb6d     bl    2ada6 <strrchr>
       266cc:    f3ef 8308     mrs    r3, MSP
       266d0:    223c          movs    r2, #60    ; 0x3c
       266d2:    9301          str    r3, [sp, #4]
       266d4:    1c41          adds    r1, r0, #1
       266d6:    9400          str    r4, [sp, #0]
       266d8:    463b          mov    r3, r7
       266da:    2000          movs    r0, #0
       266dc:    f004 f9f4     bl    2aac8 <project_log>
       266e0:    682b          ldr    r3, [r5, #0]
       266e2:    212f          movs    r1, #47    ; 0x2f
       266e4:    4630          mov    r0, r6
       266e6:    441c          add    r4, r3
       266e8:    f004 fb5d     bl    2ada6 <strrchr>
       266ec:    f3ef 8308     mrs    r3, MSP
       266f0:    223c          movs    r2, #60    ; 0x3c
       266f2:    9301          str    r3, [sp, #4]
       266f4:    1c41          adds    r1, r0, #1
       266f6:    9400          str    r4, [sp, #0]
       266f8:    463b          mov    r3, r7
       266fa:    2000          movs    r0, #0
       266fc:    f004 f9e4     bl    2aac8 <project_log>
       26700:    682b          ldr    r3, [r5, #0]
       26702:    212f          movs    r1, #47    ; 0x2f
       26704:    4630          mov    r0, r6
       26706:    441c          add    r4, r3
       26708:    f004 fb4d     bl    2ada6 <strrchr>
       2670c:    f3ef 8308     mrs    r3, MSP
       26710:    223c          movs    r2, #60    ; 0x3c
       26712:    9301          str    r3, [sp, #4]
       26714:    1c41          adds    r1, r0, #1
       26716:    9400          str    r4, [sp, #0]
       26718:    463b          mov    r3, r7
       2671a:    2000          movs    r0, #0
       2671c:    f004 f9d4     bl    2aac8 <project_log>
       26720:    682b          ldr    r3, [r5, #0]
       26722:    212f          movs    r1, #47    ; 0x2f
       26724:    4630          mov    r0, r6
       26726:    441c          add    r4, r3
       26728:    f004 fb3d     bl    2ada6 <strrchr>
       2672c:    f3ef 8308     mrs    r3, MSP
       26730:    223c          movs    r2, #60    ; 0x3c
       26732:    9301          str    r3, [sp, #4]
       26734:    1c41          adds    r1, r0, #1
       26736:    9400          str    r4, [sp, #0]
       26738:    463b          mov    r3, r7
       2673a:    2000          movs    r0, #0
       2673c:    f004 f9c4     bl    2aac8 <project_log>
       26740:    682b          ldr    r3, [r5, #0]
       26742:    212f          movs    r1, #47    ; 0x2f
       26744:    4630          mov    r0, r6
       26746:    441c          add    r4, r3
       26748:    f004 fb2d     bl    2ada6 <strrchr>
       2674c:    f3ef 8308     mrs    r3, MSP
       26750:    223c          movs    r2, #60    ; 0x3c
       26752:    9301          str    r3, [sp, #4]
       26754:    1c41          adds    r1, r0, #1
       26756:    9400          str    r4, [sp, #0]
       26758:    463b          mov    r3, r7
       2675a:    2000          movs    r0, #0
       2675c:    f004 f9b4     bl    2aac8 <project_log>
       26760:    682b          ldr    r3, [r5, #0]
       26762:    212f          movs    r1, #47    ; 0x2f
       26764:    4630          mov    r0, r6
       26766:    441c          add    r4, r3
       26768:    f004 fb1d     bl    2ada6 <strrchr>
       2676c:    f3ef 8308     mrs    r3, MSP
       26770:    223c          movs    r2, #60    ; 0x3c
       26772:    9301          str    r3, [sp, #4]
       26774:    1c41          adds    r1, r0, #1
       26776:    9400          str    r4, [sp, #0]
       26778:    463b          mov    r3, r7
       2677a:    2000          movs    r0, #0
       2677c:    f004 f9a4     bl    2aac8 <project_log>
       26780:    682b          ldr    r3, [r5, #0]
       26782:    4630          mov    r0, r6
       26784:    212f          movs    r1, #47    ; 0x2f
       26786:    441c          add    r4, r3
       26788:    f004 fb0d     bl    2ada6 <strrchr>
       2678c:    f3ef 8308     mrs    r3, MSP
       26790:    223c          movs    r2, #60    ; 0x3c
       26792:    1c41          adds    r1, r0, #1
       26794:    e9cd 4300     strd    r4, r3, [sp]
       26798:    2000          movs    r0, #0
       2679a:    463b          mov    r3, r7
       2679c:    f004 f994     bl    2aac8 <project_log>
       267a0:    6828          ldr    r0, [r5, #0]
       267a2:    4420          add    r0, r4
       267a4:    f7ff ff68     bl    26678 <evil_recursive>
       267a8:    b003          add    sp, #12
       267aa:    bdf0          pop    {r4, r5, r6, r7, pc}
       267ac:    0002bd28     .word    0x0002bd28
       267b0:    0002bd3c     .word    0x0002bd3c
       267b4:    20003310     .word    0x20003310
    and here is the  version with no print statements that causes the silent reset:
       26678:    b510          push    {r4, lr}
       2667a:    4a0b          ldr    r2, [pc, #44]    ; (266a8 <evil_recursive+0x30>)
       2667c:    6813          ldr    r3, [r2, #0]
       2667e:    6811          ldr    r1, [r2, #0]
       26680:    440b          add    r3, r1
       26682:    6811          ldr    r1, [r2, #0]
       26684:    6814          ldr    r4, [r2, #0]
       26686:    440b          add    r3, r1
       26688:    6811          ldr    r1, [r2, #0]
       2668a:    4423          add    r3, r4
       2668c:    440b          add    r3, r1
       2668e:    6811          ldr    r1, [r2, #0]
       26690:    440b          add    r3, r1
       26692:    6811          ldr    r1, [r2, #0]
       26694:    440b          add    r3, r1
       26696:    6811          ldr    r1, [r2, #0]
       26698:    6812          ldr    r2, [r2, #0]
       2669a:    440b          add    r3, r1
       2669c:    4413          add    r3, r2
       2669e:    4418          add    r0, r3
       266a0:    f7ff ffea     bl    26678 <evil_recursive>
       266a4:    bd10          pop    {r4, pc}
       266a6:    bf00          nop
       266a8:    20003310     .word    0x20003310
  • Hello!
    Have you checked the reset reason register?
    You can read this on boot to check if you had a LOCKUP reset (hardfault in hardfault) (this can only happen when you're not in debug interface mode)
    Einar
  • trying to reply to Einar - but for some reason the reply button is not under your post. Yes, lockup turned out to be the cause. Thank you!
