Adding saadc driver to a project
I want to use in my project the saadc (I'm using segger embedded studio). So, I found that I have to add the driver file to the driver folder, and I have added the file nrfx_saadc.c (then I have added the folder path to the preprocessor).
Then I have to activate it in the sdk_config.h file, but it is not present, so I add the following code to the file
// <e> NRFX_SAADC_ENABLED - nrfx_saadc - SAADC peripheral driver
#ifndef NRFX_SAADC_ENABLED
#define NRFX_SAADC_ENABLED 1
// <o> NRFX_SAADC_CONFIG_RESOLUTION - Resolution
// <0=> 8 bit
// <1=> 10 bit
// <2=> 12 bit
// <3=> 14 bit
#ifndef NRFX_SAADC_CONFIG_RESOLUTION
#define NRFX_SAADC_CONFIG_RESOLUTION 1
// <o> NRFX_SAADC_CONFIG_OVERSAMPLE - Sample period
// <0=> Disabled
// <1=> 2x
// <2=> 4x
// <3=> 8x
// <4=> 16x
// <5=> 32x
// <6=> 64x
// <7=> 128x
// <8=> 256x
#ifndef NRFX_SAADC_CONFIG_OVERSAMPLE
#define NRFX_SAADC_CONFIG_OVERSAMPLE 0
// <q> NRFX_SAADC_CONFIG_LP_MODE - Enabling low power mode
#ifndef NRFX_SAADC_CONFIG_LP_MODE
#define NRFX_SAADC_CONFIG_LP_MODE 0
// <o> NRFX_SAADC_CONFIG_IRQ_PRIORITY - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef NRFX_SAADC_CONFIG_IRQ_PRIORITY
#define NRFX_SAADC_CONFIG_IRQ_PRIORITY 6
I built and I expect to find in CMSIS configuration wizard the file related to saadc in order to enable/disable it. The problem is that I do not find it.
So, I do not understand if I miss some steps or I make any errors.
Thanks for helping.
    The CMSIS configuration wizard will have problems displaying the sdk_config.h file in the GUI if there is an error in the tags it uses. Here it looks like you are missing a line with "// </e>" at the end. (This has no effect on the preprocessor and compiler though, it is only a problem for the GUI).
  • Thanks for helping.
    I tried to correct th sdk_config.h file, but it still does not compare.
    Also, I tried to include "nrf_saadc.h" and "nrf_drv_saadc.h" library in the main file, but when I build there are errors.
    For example, one is:
    'NRFX_SAADC_CONFIG_RESOLUTION' undeclared (first use in this function); did you mean 'NRF_SAADC_INT_RESULTDONE'?
    They are all in nrfx_saadc.h file, which I have not modified, so I think the problem is due to the import and enable of the driver.
    Thanks again
    If you have the snippet from your original post in your application's sdk_config.h, then NRFX_SAADC_CONFIG_RESOLUTION will not be undeclared. Can you double check that this is not inside a block comment, or that you have not added it to the wrong sdk_config.h file by accident (from another project or similar).
    I check and NRFX_SAADC_CONFIG_RESOLUTION is declared in this way in the sdk_config.h
    I also compare the sdk_config.h file from which I take the code with my new sdk_config.h file and the code related to saadc is the same
  • That does not really mach the error you wrote you get (stating that NRFX_SAADC_CONFIG_RESOLUTION is undefined), unless you undef it or the preprocessor excludes it. If you still have not solved it, you can upload your project and I can have a brief look to see if I spot the cause.
