Configuration :
IDE : SES V5.70a
SDK version : NRF5_SDK_17.1.0
Board : NRF52840DK
I'd like to use 4 channels of the ADC in a scan mode at a high frequency (around 50 kSPS). To do this, I relied on this example code on github (nrfx_saadc_multi_channel_ppi) https://github.com/NordicPlayground/nRF52-ADC-examples. I modified different things such as the adc sampling rate in order to use microseconds and decreased the time of acquirement. However I got some strange behaviours :
- With a sample period greater than 200us, in a normal time, everything works perfectly. But if put a breakpoint or make a pause during the execution of the program and then resume it, the order of the data in the adc buffer get swapped. The order remain swapped in the same order even if i pause the program again.
- With a sample period lower than 200us, for example 50us, the order get swapped in a random order and this order is changed frequently. And this time no need to pause the program to trigger this behaviour.
I specify that I have already read most of the forums about this subject.
I understood that the problem certainly comes from the fact that the index of the buffer is managed by the cpu and, if this one is busy, it can happen that a new value is written in the buffer before the index is incremented which shifts the order of the channels. However, here the cpu does pratically nothing apart from the adc (no bluetooth app or other power-hungry app).
I guess I have to setup an additionnal ppi channel to trigger the start task on end event as described in this solution. But in the version 17 of the sdk, the nrf_saadc.c driver has changed a lot and I don't know where I need to modify it to achieve what is explained in the solution.
Here is my main :
* Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdbool.h>
#include <stdint.h>
#include <nrfx_saadc.h>
#include "nrfx_timer.h"
#include "nrfx_ppi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define ADC_CHANNELS_IN_USE 4 // Note: If changed, the logging during the NRFX_SAADC_EVT_DONE must be updated.
#define SAADC_BUF_SIZE ADC_CHANNELS_IN_USE
#define SAADC_BUF_COUNT 2
#define SAADC_SAMPLE_FREQUENCY 8000
static nrf_saadc_value_t samples[SAADC_BUF_COUNT][SAADC_BUF_SIZE];
static const nrfx_timer_t m_sample_timer = NRFX_TIMER_INSTANCE(1);
static nrf_ppi_channel_t m_timer_saadc_ppi_channel;
static nrf_ppi_channel_t m_saadc_internal_ppi_channel;
static const uint32_t saadc_sampling_rate = 50; // microseconds (us)
float prevtab[ADC_CHANNELS_IN_USE];
static const nrf_saadc_input_t ANALOG_INPUT_MAP[NRF_SAADC_CHANNEL_COUNT] = { //AIN1 AIN2 AIN3 AIN4
NRF_SAADC_INPUT_AIN1, NRF_SAADC_INPUT_AIN2, NRF_SAADC_INPUT_AIN3, NRF_SAADC_INPUT_AIN4};
// Simple function to provide an index to the next input buffer
// Will simply alernate between 0 and 1 when SAADC_BUF_COUNT is 2
static uint32_t next_free_buf_index(void)
static uint32_t buffer_index = -1;
buffer_index = (buffer_index + 1) % SAADC_BUF_COUNT;
return buffer_index;
static void timer_handler(nrf_timer_event_t event_type, void * p_context)
static void event_handler(nrfx_saadc_evt_t const * p_event)
float coeff = 0.0;
coeff = 3.0/16384.0;
//coeff = 3.0/1024.0;
float tab[ADC_CHANNELS_IN_USE];
ret_code_t err_code;
int j =0;
switch (p_event->type)
case NRFX_SAADC_EVT_DONE:
for (int i =0; i<ADC_CHANNELS_IN_USE; i++){
tab[i] = (float)p_event->data.done.p_buffer[i] * coeff;
if (tab[i]>2.9){
j = i;
if(tab[0]>0.1 || tab[1]<2.9 || tab[2] > 1.1 || tab[2] < 0.9 || tab[3] > 1.1 || tab[3] < 0.9 ){
__NOP();
//NRF_LOG_INFO("%d",j);
//NRF_LOG_INFO("ADC Values: %6d %6d %6d %6d",
// p_event->data.done.p_buffer[0], p_event->data.done.p_buffer[1], p_event->data.done.p_buffer[2], p_event->data.done.p_buffer[3]);
//NRF_LOG_INFO("ADC Voltages :" NRF_LOG_FLOAT_MARKER" "NRF_LOG_FLOAT_MARKER,NRF_LOG_FLOAT(tab[0]), NRF_LOG_FLOAT(tab[1]));
//NRF_LOG_INFO("ADC Voltages :" NRF_LOG_FLOAT_MARKER" "NRF_LOG_FLOAT_MARKER,NRF_LOG_FLOAT(tab[2]), NRF_LOG_FLOAT(tab[3]));
case NRFX_SAADC_EVT_BUF_REQ:
// Set up the next available buffer
err_code = nrfx_saadc_buffer_set(&samples[next_free_buf_index()][0], SAADC_BUF_SIZE);
NRF_LOG_INFO("SAADC evt %d", p_event->type);
static void timer_init(void)
nrfx_err_t err_code;
nrfx_timer_config_t timer_config = NRFX_TIMER_DEFAULT_CONFIG;
timer_config.frequency = NRF_TIMER_FREQ_4MHz;
err_code = nrfx_timer_init(&m_sample_timer, &timer_config, timer_handler);
nrfx_timer_extended_compare(&m_sample_timer,
NRF_TIMER_CC_CHANNEL0,
nrfx_timer_us_to_ticks(&m_sample_timer, saadc_sampling_rate),
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
nrfx_timer_resume(&m_sample_timer);
static void ppi_init(void)
// Trigger task sample from timer
nrfx_err_t err_code = nrfx_ppi_channel_alloc(&m_timer_saadc_ppi_channel);
err_code = nrfx_ppi_channel_assign(m_timer_saadc_ppi_channel,
nrfx_timer_event_address_get(&m_sample_timer, NRF_TIMER_EVENT_COMPARE0),
nrf_saadc_task_address_get(NRF_SAADC_TASK_SAMPLE));
err_code = nrfx_ppi_channel_enable(m_timer_saadc_ppi_channel);
static void adc_configure(void)
nrfx_saadc_adv_config_t saadc_adv_config = NRFX_SAADC_DEFAULT_ADV_CONFIG;
saadc_adv_config.internal_timer_cc = 0;
saadc_adv_config.start_on_end = true;
err_code = nrfx_saadc_init(NRFX_SAADC_CONFIG_IRQ_PRIORITY);
static nrfx_saadc_channel_t channel_configs[ADC_CHANNELS_IN_USE];
uint8_t channel_mask = 0;
for(int i = 0; i < ADC_CHANNELS_IN_USE; i++) {
nrf_saadc_input_t pin = ANALOG_INPUT_MAP[i];
// Apply default config to each channel
nrfx_saadc_channel_t config = NRFX_SAADC_DEFAULT_CHANNEL_SE(pin, i);
// Replace some parameters in default config
config.channel_config.reference = NRF_SAADC_REFERENCE_VDD4;
config.channel_config.gain = NRF_SAADC_GAIN1_4;
config.channel_config.acq_time = SAADC_CH_CONFIG_TACQ_3us;
// Copy to list of channel configs
memcpy(&channel_configs[i], &config, sizeof(config));
// Update channel mask
channel_mask |= 1 << i;
err_code = nrfx_saadc_channels_config(channel_configs, ADC_CHANNELS_IN_USE);
err_code = nrfx_saadc_advanced_mode_set(channel_mask,
NRF_SAADC_RESOLUTION_14BIT,
&saadc_adv_config,
event_handler);
// Configure two buffers to ensure double buffering of samples, to avoid data loss when the sampling frequency is high
err_code = nrfx_saadc_mode_trigger();
// Configure Logging. LOGGING is used to show the SAADC sampled result.
err_code = NRF_LOG_INIT(NULL);
NRF_LOG_INFO("nrfx_saadc_api2 simple SAADC Continuous Sampling Example using timer and PPI.");
adc_configure();
ppi_init();
timer_init();
while (1)
while(NRF_LOG_PROCESS() != NRF_SUCCESS);
__WFE();
And the nrf_saadc.c : /**
* Copyright (c) 2015 - 2021, Nordic Semiconductor ASA
#include <nrfx.h>
#if NRFX_CHECK(NRFX_SAADC_ENABLED)
#define NRFX_LOG_MODULE SAADC
#include <nrfx_log.h>
#if !defined(NRFX_SAADC_API_V2)
#define EVT_TO_STR(event) \
(event == NRF_SAADC_EVENT_STARTED ? "NRF_SAADC_EVENT_STARTED" : \
(event == NRF_SAADC_EVENT_END ? "NRF_SAADC_EVENT_END" : \
(event == NRF_SAADC_EVENT_DONE ? "NRF_SAADC_EVENT_DONE" : \
(event == NRF_SAADC_EVENT_RESULTDONE ? "NRF_SAADC_EVENT_RESULTDONE" : \
(event == NRF_SAADC_EVENT_CALIBRATEDONE ? "NRF_SAADC_EVENT_CALIBRATEDONE" : \
(event == NRF_SAADC_EVENT_STOPPED ? "NRF_SAADC_EVENT_STOPPED" : \
"UNKNOWN EVENT"))))))
typedef enum
NRF_SAADC_STATE_IDLE = 0,
NRF_SAADC_STATE_BUSY = 1,
NRF_SAADC_STATE_CALIBRATION = 2
} nrf_saadc_state_t;
typedef struct
nrf_saadc_input_t pselp;
nrf_saadc_input_t pseln;
} nrf_saadc_psel_buffer;
/** @brief SAADC control block.*/
typedef struct
nrfx_saadc_event_handler_t event_handler; ///< Event handler function pointer.
volatile nrf_saadc_value_t * p_buffer; ///< Sample buffer.
volatile uint16_t buffer_size; ///< Size of the sample buffer.
volatile nrf_saadc_value_t * p_secondary_buffer; ///< Secondary sample buffer.
volatile nrf_saadc_state_t adc_state; ///< State of the SAADC.
uint32_t limits_enabled_flags; ///< Enabled limits flags.
uint16_t secondary_buffer_size; ///< Size of the secondary buffer.
uint16_t buffer_size_left; ///< When low power mode is active indicates how many samples left to convert on current buffer.
nrf_saadc_psel_buffer psel[NRF_SAADC_CHANNEL_COUNT]; ///< Pin configurations of SAADC channels.
nrfx_drv_state_t state; ///< Driver initialization state.
uint8_t active_channels; ///< Number of enabled SAADC channels.
bool low_power_mode; ///< Indicates if low power mode is active.
bool conversions_end; ///< When low power mode is active indicates end of conversions on current buffer.
} nrfx_saadc_cb_t;
static nrfx_saadc_cb_t m_cb;
#define LOW_LIMIT_TO_FLAG(channel) ((2 * channel + 1))
#define HIGH_LIMIT_TO_FLAG(channel) ((2 * channel))
#define FLAG_IDX_TO_EVENT(idx) ((nrf_saadc_event_t)((uint32_t)NRF_SAADC_EVENT_CH0_LIMITH + \
4 * idx))
#define LIMIT_EVENT_TO_CHANNEL(event) (uint8_t)(((uint32_t)event - \
(uint32_t)NRF_SAADC_EVENT_CH0_LIMITH) / 8)
#define LIMIT_EVENT_TO_LIMIT_TYPE(event)((((uint32_t)event - (uint32_t)NRF_SAADC_EVENT_CH0_LIMITH) & 4) \
? NRF_SAADC_LIMIT_LOW : NRF_SAADC_LIMIT_HIGH)
#define HW_TIMEOUT 10000
void nrfx_saadc_irq_handler(void)
if (nrf_saadc_event_check(NRF_SAADC_EVENT_END))
nrf_saadc_event_clear(NRF_SAADC_EVENT_END);
NRFX_LOG_DEBUG("Event: %s.", EVT_TO_STR(NRF_SAADC_EVENT_END));
if (!m_cb.low_power_mode || m_cb.conversions_end)
nrfx_saadc_evt_t evt;
evt.type = NRFX_SAADC_EVT_DONE;
evt.data.done.p_buffer = (nrf_saadc_value_t *)m_cb.p_buffer;
evt.data.done.size = m_cb.buffer_size;
if (m_cb.p_secondary_buffer == NULL)
m_cb.adc_state = NRF_SAADC_STATE_IDLE;
m_cb.buffer_size_left = m_cb.secondary_buffer_size;
m_cb.p_buffer = m_cb.p_secondary_buffer;
m_cb.buffer_size = m_cb.secondary_buffer_size;
m_cb.p_secondary_buffer = NULL;
if (!m_cb.low_power_mode)
nrf_saadc_task_trigger(NRF_SAADC_TASK_START);
m_cb.event_handler(&evt);
m_cb.conversions_end = false;
if (m_cb.low_power_mode && nrf_saadc_event_check(NRF_SAADC_EVENT_STARTED))
nrf_saadc_event_clear(NRF_SAADC_EVENT_STARTED);
NRFX_LOG_DEBUG("Event: %s.", EVT_TO_STR(NRF_SAADC_EVENT_STARTED));
if (m_cb.buffer_size_left > m_cb.active_channels)
// More samples to convert than for single event.
m_cb.buffer_size_left -= m_cb.active_channels;
nrf_saadc_buffer_init((nrf_saadc_value_t *)&m_cb.p_buffer[m_cb.buffer_size -
m_cb.buffer_size_left],
m_cb.active_channels);
else if ((m_cb.buffer_size_left == m_cb.active_channels) &&
(m_cb.p_secondary_buffer != NULL))
// Samples to convert for one event, prepare next buffer.
m_cb.conversions_end = true;
m_cb.buffer_size_left = 0;
nrf_saadc_buffer_init((nrf_saadc_value_t *)m_cb.p_secondary_buffer,
else if (m_cb.buffer_size_left == m_cb.active_channels)
// Samples to convert for one event, but no second buffer.
nrf_saadc_task_trigger(NRF_SAADC_TASK_SAMPLE);
if (nrf_saadc_event_check(NRF_SAADC_EVENT_CALIBRATEDONE))
nrf_saadc_event_clear(NRF_SAADC_EVENT_CALIBRATEDONE);
NRFX_LOG_DEBUG("Event: %s.", EVT_TO_STR(NRF_SAADC_EVENT_CALIBRATEDONE));
evt.type = NRFX_SAADC_EVT_CALIBRATEDONE;
if (nrf_saadc_event_check(NRF_SAADC_EVENT_STOPPED))
nrf_saadc_event_clear(NRF_SAADC_EVENT_STOPPED);
NRFX_LOG_DEBUG("Event: %s.", EVT_TO_STR(NRF_SAADC_EVENT_STOPPED));
uint32_t limit_flags = m_cb.limits_enabled_flags;
uint32_t flag_idx;
nrf_saadc_event_t event;
while (limit_flags)
flag_idx = __CLZ(limit_flags);
limit_flags &= ~((1UL << 31) >> flag_idx);
event = FLAG_IDX_TO_EVENT(flag_idx);
if (nrf_saadc_event_check(event))
nrf_saadc_event_clear(event);
evt.type = NRFX_SAADC_EVT_LIMIT;
evt.data.limit.channel = LIMIT_EVENT_TO_CHANNEL(event);
evt.data.limit.limit_type = LIMIT_EVENT_TO_LIMIT_TYPE(event);
NRFX_LOG_DEBUG("Event limit, channel: %d, limit type: %d.",
evt.data.limit.channel,
evt.data.limit.limit_type);
nrfx_err_t nrfx_saadc_init(nrfx_saadc_config_t const * p_config,
nrfx_saadc_event_handler_t event_handler)
NRFX_ASSERT(p_config);
NRFX_ASSERT(event_handler);
if (m_cb.state != NRFX_DRV_STATE_UNINITIALIZED)
err_code = NRFX_ERROR_INVALID_STATE;
NRFX_LOG_WARNING("Function: %s, error code: %s.",
__func__,
NRFX_LOG_ERROR_STRING_GET(err_code));
return err_code;
m_cb.event_handler = event_handler;
nrf_saadc_resolution_set(p_config->resolution);
nrf_saadc_oversample_set(p_config->oversample);
m_cb.low_power_mode = p_config->low_power_mode;
m_cb.state = NRFX_DRV_STATE_INITIALIZED;
m_cb.active_channels = 0;
m_cb.limits_enabled_flags = 0;
nrf_saadc_int_disable(NRF_SAADC_INT_ALL);
NRFX_IRQ_PRIORITY_SET(SAADC_IRQn, p_config->interrupt_priority);
NRFX_IRQ_ENABLE(SAADC_IRQn);
nrf_saadc_int_enable(NRF_SAADC_INT_END);
if (m_cb.low_power_mode)
nrf_saadc_int_enable(NRF_SAADC_INT_STARTED);
nrf_saadc_enable();
err_code = NRFX_SUCCESS;
NRFX_LOG_INFO("Function: %s, error code: %s.", __func__, NRFX_LOG_ERROR_STRING_GET(err_code));
return err_code;
void nrfx_saadc_uninit(void)
NRFX_ASSERT(m_cb.state != NRFX_DRV_STATE_UNINITIALIZED);
NRFX_IRQ_DISABLE(SAADC_IRQn);
nrf_saadc_task_trigger(NRF_SAADC_TASK_STOP);
// Wait for ADC being stopped.
bool result;
NRFX_WAIT_FOR(nrf_saadc_event_check(NRF_SAADC_EVENT_STOPPED), HW_TIMEOUT, 0, result);
NRFX_ASSERT(result);
nrf_saadc_disable();
for (uint32_t channel = 0; channel < NRF_SAADC_CHANNEL_COUNT; ++channel)
if (m_cb.psel[channel].pselp != NRF_SAADC_INPUT_DISABLED)
nrfx_err_t err_code = nrfx_saadc_channel_uninit(channel);
NRFX_ASSERT(err_code == NRFX_SUCCESS);
m_cb.state = NRFX_DRV_STATE_UNINITIALIZED;
nrfx_err_t nrfx_saadc_channel_init(uint8_t channel,
nrf_saadc_channel_config_t const * const p_config)
NRFX_ASSERT(channel < NRF_SAADC_CHANNEL_COUNT);
// Oversampling can be used only with one channel.
NRFX_ASSERT((nrf_saadc_oversample_get() == NRF_SAADC_OVERSAMPLE_DISABLED) ||
(m_cb.active_channels == 0));
#if defined(SAADC_CH_PSELP_PSELP_VDDHDIV5)
NRFX_ASSERT((p_config->pin_p <= NRF_SAADC_INPUT_VDDHDIV5) &&
(p_config->pin_p > NRF_SAADC_INPUT_DISABLED));
NRFX_ASSERT(p_config->pin_n <= NRF_SAADC_INPUT_VDDHDIV5);
#else
NRFX_ASSERT((p_config->pin_p <= NRF_SAADC_INPUT_VDD) &&
NRFX_ASSERT(p_config->pin_n <= NRF_SAADC_INPUT_VDD);
// A channel can only be initialized if the driver is in the idle state.
if (m_cb.adc_state != NRF_SAADC_STATE_IDLE)
err_code = NRFX_ERROR_BUSY;
__func__,
return err_code;
#ifdef NRF52_PAN_74
if ((p_config->acq_time == NRF_SAADC_ACQTIME_3US) ||
(p_config->acq_time == NRF_SAADC_ACQTIME_5US))
#endif //NRF52_PAN_74
if (m_cb.psel[channel].pselp == NRF_SAADC_INPUT_DISABLED)
++m_cb.active_channels;
m_cb.psel[channel].pselp = p_config->pin_p;
m_cb.psel[channel].pseln = p_config->pin_n;
nrf_saadc_channel_init(channel, p_config);
#ifdef NRF52_PAN_74
nrf_saadc_enable();
NRFX_LOG_INFO("Channel initialized: %d.", channel);
return err_code;
nrfx_err_t nrfx_saadc_channel_uninit(uint8_t channel)
// A channel can only be uninitialized if the driver is in the idle state.
__func__,
return err_code;
--m_cb.active_channels;
m_cb.psel[channel].pselp = NRF_SAADC_INPUT_DISABLED;
m_cb.psel[channel].pseln = NRF_SAADC_INPUT_DISABLED;
nrf_saadc_channel_input_set(channel, NRF_SAADC_INPUT_DISABLED, NRF_SAADC_INPUT_DISABLED);
nrfx_saadc_limits_set(channel, NRFX_SAADC_LIMITL_DISABLED, NRFX_SAADC_LIMITH_DISABLED);
NRFX_LOG_INFO("Channel denitialized: %d.", channel);
return err_code;
uint32_t nrfx_saadc_sample_task_get(void)
return nrf_saadc_task_address_get(
m_cb.low_power_mode ? NRF_SAADC_TASK_START : NRF_SAADC_TASK_SAMPLE);
nrfx_err_t nrfx_saadc_sample_convert(uint8_t channel, nrf_saadc_value_t * p_value)
NRFX_LOG_WARNING("Function: %s error code: %s.",
__func__,
return err_code;
m_cb.adc_state = NRF_SAADC_STATE_BUSY;
nrf_saadc_int_disable(NRF_SAADC_INT_STARTED | NRF_SAADC_INT_END);
nrf_saadc_buffer_init(p_value, 1);
if (m_cb.active_channels > 1)
for (uint32_t i = 0; i < NRF_SAADC_CHANNEL_COUNT; ++i)
nrf_saadc_channel_input_set(i, NRF_SAADC_INPUT_DISABLED, NRF_SAADC_INPUT_DISABLED);
nrf_saadc_channel_input_set(channel, m_cb.psel[channel].pselp, m_cb.psel[channel].pseln);
bool result;
NRFX_WAIT_FOR(nrf_saadc_event_check(NRF_SAADC_EVENT_END), HW_TIMEOUT, 0, result);
NRFX_LOG_INFO("Conversion value: %d, channel %d.", *p_value, channel);
nrf_saadc_channel_input_set(i, m_cb.psel[i].pselp, m_cb.psel[i].pseln);
nrf_saadc_int_enable(NRF_SAADC_INT_STARTED | NRF_SAADC_INT_END);
__func__,
return err_code;
nrfx_err_t nrfx_saadc_buffer_convert(nrf_saadc_value_t * p_buffer, uint16_t size)
NRFX_ASSERT((size % m_cb.active_channels) == 0);
nrf_saadc_int_disable(NRF_SAADC_INT_END | NRF_SAADC_INT_CALIBRATEDONE);
if (m_cb.adc_state == NRF_SAADC_STATE_CALIBRATION)
nrf_saadc_int_enable(NRF_SAADC_INT_END | NRF_SAADC_INT_CALIBRATEDONE);
__func__,
return err_code;
if (m_cb.adc_state == NRF_SAADC_STATE_BUSY)
if ( m_cb.p_secondary_buffer)
__func__,
return err_code;
m_cb.p_secondary_buffer = p_buffer;
m_cb.secondary_buffer_size = size;
while (nrf_saadc_event_check(NRF_SAADC_EVENT_STARTED) == 0);
nrf_saadc_buffer_init(p_buffer, size);
__func__,
return err_code;
m_cb.p_buffer = p_buffer;
m_cb.buffer_size = size;
NRFX_LOG_INFO("Function: %s, buffer length: %d, active channels: %d.",
__func__,
size,
m_cb.buffer_size_left = size;
nrf_saadc_buffer_init(p_buffer, m_cb.active_channels);
return err_code;
nrfx_err_t nrfx_saadc_sample()
nrfx_err_t err_code = NRFX_SUCCESS;
if (m_cb.adc_state != NRF_SAADC_STATE_BUSY)
else if (m_cb.low_power_mode)
return err_code;
nrfx_err_t nrfx_saadc_calibrate_offset()
__func__,
return err_code;
m_cb.adc_state = NRF_SAADC_STATE_CALIBRATION;
nrf_saadc_int_enable(NRF_SAADC_INT_CALIBRATEDONE);
nrf_saadc_task_trigger(NRF_SAADC_TASK_CALIBRATEOFFSET);
__func__,
return err_code;
bool nrfx_saadc_is_busy(void)
return (m_cb.adc_state != NRF_SAADC_STATE_IDLE);
void nrfx_saadc_abort(void)
if (nrfx_saadc_is_busy())
nrf_saadc_int_enable(NRF_SAADC_INT_STOPPED);
bool result;
NRFX_WAIT_FOR((m_cb.adc_state == NRF_SAADC_STATE_IDLE), HW_TIMEOUT, 0, result);
nrf_saadc_int_disable(NRF_SAADC_INT_STOPPED);
m_cb.p_buffer = 0;
m_cb.p_secondary_buffer = 0;
NRFX_LOG_INFO("Conversion aborted.");
void nrfx_saadc_limits_set(uint8_t channel, int16_t limit_low, int16_t limit_high)
NRFX_ASSERT(m_cb.event_handler); // only non blocking mode supported
NRFX_ASSERT(limit_low >= NRFX_SAADC_LIMITL_DISABLED);
NRFX_ASSERT(limit_high <= NRFX_SAADC_LIMITH_DISABLED);
NRFX_ASSERT(limit_low < limit_high);
nrf_saadc_channel_limits_set(channel, limit_low, limit_high);
uint32_t int_mask = nrf_saadc_limit_int_get(channel, NRF_SAADC_LIMIT_LOW);
if (limit_low == NRFX_SAADC_LIMITL_DISABLED)
m_cb.limits_enabled_flags &= ~(0x80000000 >> LOW_LIMIT_TO_FLAG(channel));
nrf_saadc_int_disable(int_mask);
m_cb.limits_enabled_flags |= (0x80000000 >> LOW_LIMIT_TO_FLAG(channel));
nrf_saadc_int_enable(int_mask);
int_mask = nrf_saadc_limit_int_get(channel, NRF_SAADC_LIMIT_HIGH);
if (limit_high == NRFX_SAADC_LIMITH_DISABLED)
m_cb.limits_enabled_flags &= ~(0x80000000 >> HIGH_LIMIT_TO_FLAG(channel));
m_cb.limits_enabled_flags |= (0x80000000 >> HIGH_LIMIT_TO_FLAG(channel));
#endif // !defined(NRFX_SAADC_API_V2)
#if defined(NRFX_SAADC_API_V2) || defined(__NRFX_DOXYGEN__)
#if defined(NRF52_SERIES) && !defined(USE_WORKAROUND_FOR_ANOMALY_212)
// ANOMALY 212 - SAADC events are missing when switching from single channel
// to multi channel configuration with burst enabled.
#define USE_WORKAROUND_FOR_ANOMALY_212 1
#if defined(NRF53_SERIES) || defined(NRF91_SERIES)
// Make sure that SAADC is stopped before channel configuration.
#define STOP_SAADC_ON_CHANNEL_CONFIG 1
// Make sure that SAADC calibration samples do not affect next conversions.
#define INTERCEPT_SAADC_CALIBRATION_SAMPLES 1
/** @brief SAADC driver states.*/
typedef enum
NRF_SAADC_STATE_UNINITIALIZED = 0,
NRF_SAADC_STATE_IDLE,
NRF_SAADC_STATE_SIMPLE_MODE,
NRF_SAADC_STATE_SIMPLE_MODE_SAMPLE,
NRF_SAADC_STATE_ADV_MODE,
NRF_SAADC_STATE_ADV_MODE_SAMPLE,
NRF_SAADC_STATE_ADV_MODE_SAMPLE_STARTED,
typedef struct
nrf_saadc_value_t * p_buffer_primary; ///< Pointer to the primary result buffer.
nrf_saadc_value_t * p_buffer_secondary; ///< Pointer to the secondary result buffer.
#if NRFX_CHECK(INTERCEPT_SAADC_CALIBRATION_SAMPLES)
nrf_saadc_value_t calib_samples[6]; ///< Scratch buffer for calibration samples.
uint16_t size_primary; ///< Size of the primary result buffer.
uint16_t size_secondary; ///< Size of the secondary result buffer.
uint16_t samples_converted; ///< Number of samples present in result buffer when in the blocking mode.
nrf_saadc_input_t channels_pselp[SAADC_CH_NUM]; ///< Array holding each channel positive input.
nrf_saadc_input_t channels_pseln[SAADC_CH_NUM]; ///< Array holding each channel negative input.
nrf_saadc_state_t saadc_state; ///< State of the SAADC driver.
uint8_t channels_configured; ///< Bitmask of the configured channels.
uint8_t channels_activated; ///< Bitmask of the activated channels.
uint8_t channels_activated_count; ///< Number of the activated channels.
uint8_t limits_low_activated; ///< Bitmask of the activated low limits.
uint8_t limits_high_activated; ///< Bitmask of the activated high limits.
bool start_on_end; ///< Flag indicating if the START task is to be triggered on the END event.
bool oversampling_without_burst; ///< Flag indicating whether oversampling without burst is configured.
} nrfx_saadc_cb_t;
#if NRFX_CHECK(USE_WORKAROUND_FOR_ANOMALY_212)
static void saadc_anomaly_212_workaround_apply(void)
uint32_t c[SAADC_CH_NUM];
uint32_t l[SAADC_CH_NUM];
for (uint32_t i = 0; i < SAADC_CH_NUM; i++)
c[i] = NRF_SAADC->CH[i].CONFIG;
l[i] = NRF_SAADC->CH[i].LIMIT;
nrf_saadc_resolution_t resolution = nrf_saadc_resolution_get();
uint32_t u640 = *(volatile uint32_t *)0x40007640;
uint32_t u644 = *(volatile uint32_t *)0x40007644;
uint32_t u648 = *(volatile uint32_t *)0x40007648;
*(volatile uint32_t *)0x40007FFC = 0;
*(volatile uint32_t *)0x40007FFC = 1;
NRF_SAADC->CH[i].CONFIG = c[i];
NRF_SAADC->CH[i].LIMIT = l[i];
*(volatile uint32_t *)0x40007640 = u640;
*(volatile uint32_t *)0x40007644 = u644;
*(volatile uint32_t *)0x40007648 = u648;
nrf_saadc_resolution_set(resolution);
#endif // NRFX_CHECK(USE_WORKAROUND_FOR_ANOMALY_212)
static nrfx_err_t saadc_channel_count_get(uint32_t ch_to_activate_mask,
uint8_t * p_active_ch_count)
NRFX_ASSERT(ch_to_activate_mask);
NRFX_ASSERT(ch_to_activate_mask < (1uL << SAADC_CH_NUM));
uint8_t active_ch_count = 0;
for (uint32_t ch_mask = 1; ch_mask < (1uL << SAADC_CH_NUM); ch_mask <<= 1)
if (ch_to_activate_mask & ch_mask)
// Check if requested channels are configured.
if (!(m_cb.channels_configured & ch_mask))
return NRFX_ERROR_INVALID_PARAM;
active_ch_count++;
*p_active_ch_count = active_ch_count;
return NRFX_SUCCESS;
static bool saadc_busy_check(void)
if ((m_cb.saadc_state == NRF_SAADC_STATE_IDLE) ||
(m_cb.saadc_state == NRF_SAADC_STATE_ADV_MODE) ||
(m_cb.saadc_state == NRF_SAADC_STATE_SIMPLE_MODE))
return false;
return true;
static void saadc_generic_mode_set(uint32_t ch_to_activate_mask,
nrf_saadc_resolution_t resolution,
nrf_saadc_oversample_t oversampling,
nrf_saadc_burst_t burst,
saadc_anomaly_212_workaround_apply();
#if NRFX_CHECK(STOP_SAADC_ON_CHANNEL_CONFIG)
while (!nrf_saadc_event_check(NRF_SAADC_EVENT_STOPPED))
m_cb.limits_low_activated = 0;
m_cb.limits_high_activated = 0;
m_cb.p_buffer_primary = NULL;
m_cb.p_buffer_secondary = NULL;
m_cb.channels_activated = ch_to_activate_mask;
m_cb.samples_converted = 0;
nrf_saadc_oversample_set(oversampling);
if (event_handler)
nrf_saadc_int_set(NRF_SAADC_INT_STARTED |
NRF_SAADC_INT_STOPPED |
NRF_SAADC_INT_END);
nrf_saadc_int_set(0);
for (uint32_t ch_pos = 0; ch_pos < SAADC_CH_NUM; ch_pos++)
nrf_saadc_burst_t burst_to_set;
if (ch_to_activate_mask & (1uL << ch_pos))
pselp = m_cb.channels_pselp[ch_pos];
pseln = m_cb.channels_pseln[ch_pos];
burst_to_set = burst;
burst_to_set = NRF_SAADC_BURST_DISABLED;
nrf_saadc_burst_set(ch_pos, burst_to_set);
nrf_saadc_channel_input_set(ch_pos, pselp, pseln);
nrfx_err_t nrfx_saadc_init(uint8_t interrupt_priority)
if (m_cb.saadc_state != NRF_SAADC_STATE_UNINITIALIZED)
__func__,
return err_code;
m_cb.saadc_state = NRF_SAADC_STATE_IDLE;
NRFX_IRQ_PRIORITY_SET(SAADC_IRQn, interrupt_priority);
return err_code;
nrfx_saadc_abort();
m_cb.saadc_state = NRF_SAADC_STATE_UNINITIALIZED;
nrfx_err_t nrfx_saadc_channels_config(nrfx_saadc_channel_t const * p_channels,
uint32_t channel_count)
NRFX_ASSERT(m_cb.saadc_state != NRF_SAADC_STATE_UNINITIALIZED);
NRFX_ASSERT(channel_count <= SAADC_CH_NUM);
if (saadc_busy_check())
return NRFX_ERROR_BUSY;
m_cb.channels_configured = 0;
uint8_t i = 0;
for (; i < SAADC_CH_NUM; i++)
m_cb.channels_pselp[i] = NRF_SAADC_INPUT_DISABLED;
m_cb.channels_pseln[i] = NRF_SAADC_INPUT_DISABLED;
for (i = 0; i < channel_count; i++)
if (m_cb.channels_configured & (1uL << p_channels[i].channel_index))
// This channel is already configured!
nrf_saadc_channel_init(p_channels[i].channel_index,
&p_channels[i].channel_config);
NRFX_ASSERT(p_channels[i].pin_p);
m_cb.channels_pselp[p_channels[i].channel_index] = p_channels[i].pin_p;
m_cb.channels_pseln[p_channels[i].channel_index] = p_channels[i].pin_n;
m_cb.channels_configured |= 1U << p_channels[i].channel_index;
nrfx_err_t nrfx_saadc_simple_mode_set(uint32_t channel_mask,
uint8_t active_ch_count;
nrfx_err_t err = saadc_channel_count_get(channel_mask, &active_ch_count);
if (err != NRFX_SUCCESS)
return err;
nrf_saadc_burst_t burst;
if (oversampling == NRF_SAADC_OVERSAMPLE_DISABLED)
burst = NRF_SAADC_BURST_DISABLED;
// Burst is implicitly enabled if oversampling is enabled.
burst = NRF_SAADC_BURST_ENABLED;
saadc_generic_mode_set(channel_mask,
resolution,
oversampling,
burst,
event_handler);
m_cb.channels_activated_count = active_ch_count;
m_cb.saadc_state = NRF_SAADC_STATE_SIMPLE_MODE;
nrfx_err_t nrfx_saadc_advanced_mode_set(uint32_t channel_mask,
nrfx_saadc_adv_config_t const * p_config,
return err;
if ((p_config->internal_timer_cc) && ((active_ch_count > 1) || (!event_handler)))
return NRFX_ERROR_NOT_SUPPORTED;
bool oversampling_without_burst = false;
if ((p_config->oversampling != NRF_SAADC_OVERSAMPLE_DISABLED) &&
(p_config->burst == NRF_SAADC_BURST_DISABLED))
if (active_ch_count > 1)
// Oversampling without burst is possible only on single channel.
oversampling_without_burst = true;
resolution,
p_config->oversampling,
p_config->burst,
event_handler);
if (p_config->internal_timer_cc)
nrf_saadc_continuous_mode_enable(p_config->internal_timer_cc);
nrf_saadc_continuous_mode_disable();
m_cb.start_on_end = p_config->start_on_end;
m_cb.oversampling_without_burst = oversampling_without_burst;
m_cb.saadc_state = NRF_SAADC_STATE_ADV_MODE;
nrfx_err_t nrfx_saadc_buffer_set(nrf_saadc_value_t * p_buffer, uint16_t size)
if (m_cb.p_buffer_secondary)
return NRFX_ERROR_ALREADY_INITIALIZED;
if (!nrfx_is_in_ram(p_buffer))
return NRFX_ERROR_INVALID_ADDR;
if ((size % m_cb.channels_activated_count != 0) ||
(size >= (1uL << SAADC_EASYDMA_MAXCNT_SIZE)) ||
(!size))
return NRFX_ERROR_INVALID_LENGTH;
switch (m_cb.saadc_state)
case NRF_SAADC_STATE_SIMPLE_MODE:
if (m_cb.channels_activated_count != size)
m_cb.size_primary = size;
m_cb.p_buffer_primary = p_buffer;
case NRF_SAADC_STATE_ADV_MODE_SAMPLE_STARTED:
/* fall-through */
case NRF_SAADC_STATE_ADV_MODE:
/* fall-through */
case NRF_SAADC_STATE_ADV_MODE_SAMPLE:
if (m_cb.p_buffer_primary)
m_cb.size_secondary = size;
m_cb.p_buffer_secondary = p_buffer;
return NRFX_ERROR_INVALID_STATE;
nrfx_err_t nrfx_saadc_mode_trigger(void)
NRFX_ASSERT(m_cb.saadc_state != NRF_SAADC_STATE_IDLE);
if (!m_cb.p_buffer_primary)
return NRFX_ERROR_NO_MEM;
nrfx_err_t result = NRFX_SUCCESS;
nrf_saadc_enable();
// When in simple blocking or non-blocking mode, buffer size is equal to activated channel count.
// Single SAMPLE task is enough to obtain one sample on each activated channel.
// This will result in buffer being filled with samples and therefore END event will appear.
nrf_saadc_buffer_init(m_cb.p_buffer_primary, m_cb.size_primary);
if (m_cb.event_handler)
m_cb.saadc_state = NRF_SAADC_STATE_SIMPLE_MODE_SAMPLE;
while (!nrf_saadc_event_check(NRF_SAADC_EVENT_STARTED))
while (!nrf_saadc_event_check(NRF_SAADC_EVENT_END))
nrf_saadc_enable();
// When in advanced non-blocking mode, latch whole buffer in EasyDMA.
// END event will arrive when whole buffer is filled with samples.
m_cb.saadc_state = NRF_SAADC_STATE_ADV_MODE_SAMPLE;
// When in advanced blocking mode, latch single chunk of buffer in EasyDMA.
// Each chunk consists of single sample from each activated channels.
// END event will arrive when single chunk is filled with samples.
nrf_saadc_buffer_init(&m_cb.p_buffer_primary[m_cb.samples_converted],
m_cb.channels_activated_count);
if (m_cb.oversampling_without_burst)
// In this configuration more than one SAMPLE task is needed to obtain single sample.
uint32_t samples_to_take =
nrf_saadc_oversample_sample_count_get(nrf_saadc_oversample_get());
for (uint32_t sample_idx = 0; sample_idx < samples_to_take; sample_idx++)
nrf_saadc_event_clear(NRF_SAADC_EVENT_DONE);
while (!nrf_saadc_event_check(NRF_SAADC_EVENT_DONE))
// This will result in chunk being filled with samples and therefore END event will appear.
m_cb.samples_converted += m_cb.channels_activated_count;
if (m_cb.samples_converted < m_cb.size_primary)
result = NRFX_ERROR_BUSY;
m_cb.p_buffer_primary = m_cb.p_buffer_secondary;
m_cb.size_primary = m_cb.size_secondary;
result = NRFX_ERROR_INVALID_STATE;
return result;
if (!m_cb.event_handler)
if (m_cb.saadc_state == NRF_SAADC_STATE_CALIBRATION)
// STOPPED event does not appear when the calibration is ongoing
nrfx_err_t nrfx_saadc_limits_set(uint8_t channel, int16_t limit_low, int16_t limit_high)
NRFX_ASSERT(limit_high >= limit_low);
return NRFX_ERROR_FORBIDDEN;
(m_cb.saadc_state == NRF_SAADC_STATE_CALIBRATION))
if (!(m_cb.channels_activated & (1uL << channel)))
if (limit_low == INT16_MIN)
m_cb.limits_low_activated &= ~(1uL << channel);
m_cb.limits_low_activated |= (1uL << channel);
if (limit_high == INT16_MAX)
m_cb.limits_high_activated &= ~(1uL << channel);
m_cb.limits_high_activated |= (1uL << channel);
nrfx_err_t nrfx_saadc_offset_calibrate(nrfx_saadc_event_handler_t event_handler)
m_cb.saadc_state = NRF_SAADC_STATE_CALIBRATION;
nrf_saadc_enable();
nrf_saadc_buffer_init(m_cb.calib_samples, NRFX_ARRAY_SIZE(m_cb.calib_samples));
if (event_handler)
nrf_saadc_int_set(NRF_SAADC_INT_STARTED | NRF_SAADC_INT_CALIBRATEDONE);
while (!nrf_saadc_event_check(NRF_SAADC_EVENT_CALIBRATEDONE))
#else
if (event_handler)
#endif // NRFX_CHECK(INTERCEPT_SAADC_CALIBRATION_SAMPLES)
static void saadc_event_started_handle(void)
nrfx_saadc_evt_t evt_data;
evt_data.type = NRFX_SAADC_EVT_READY;
m_cb.event_handler(&evt_data);
if (nrf_saadc_continuous_mode_enable_check())
// Trigger internal timer
m_cb.saadc_state = NRF_SAADC_STATE_ADV_MODE_SAMPLE_STARTED;
nrf_saadc_buffer_init(m_cb.p_buffer_secondary,
m_cb.size_secondary);
/* fall-through */
if (!m_cb.p_buffer_secondary)
// Send next buffer request only if it was not provided earlier,
// before conversion start or outside of user's callback context.
evt_data.type = NRFX_SAADC_EVT_BUF_REQ;
case NRF_SAADC_STATE_SIMPLE_MODE_SAMPLE:
case NRF_SAADC_STATE_CALIBRATION:
static void saadc_event_end_handle(void)
evt_data.type = NRFX_SAADC_EVT_DONE;
evt_data.data.done.p_buffer = m_cb.p_buffer_primary;
evt_data.data.done.size = m_cb.size_primary;
if (m_cb.start_on_end)
evt_data.type = NRFX_SAADC_EVT_FINISHED;
static void saadc_event_limits_handle(uint8_t limits_activated, nrf_saadc_limit_t limit_type)
while (limits_activated)
uint8_t channel = __CLZ(__RBIT((uint32_t)limits_activated));
limits_activated &= ~(1uL << channel);
nrf_saadc_event_t event = nrf_saadc_limit_event_get(channel, limit_type);
evt_data.type = NRFX_SAADC_EVT_LIMIT;
evt_data.data.limit.channel = channel;
evt_data.data.limit.limit_type = limit_type;
if (nrf_saadc_event_check(NRF_SAADC_EVENT_STARTED))
saadc_event_started_handle();
// If there was ongoing conversion the STOP task also triggers the END event
m_cb.size_primary = nrf_saadc_amount_get();
/* fall-through to the END event handler */
// When samples are intercepted into scratch buffer during calibration,
// END event appears when the calibration finishes. This event should be ignored.
if (m_cb.saadc_state != NRF_SAADC_STATE_CALIBRATION)
saadc_event_end_handle();
saadc_event_limits_handle(m_cb.limits_low_activated, NRF_SAADC_LIMIT_LOW);
saadc_event_limits_handle(m_cb.limits_high_activated, NRF_SAADC_LIMIT_HIGH);
evt_data.type = NRFX_SAADC_EVT_CALIBRATEDONE;
#endif // defined(NRFX_SAADC_API_V2) || defined(__NRFX_DOXYGEN__)
#endif // NRFX_CHECK(NRFX_SAADC_ENABLED)
I hope my explaination is clear an you can help me.
Guillaume
