Capacitor values on DEC pins
I'm opening a different thread to discuss further my latest findings.
I'm using a module E73-2G4M04S1AX that is based on nRF52810. My project has very strict power requirements as I want it to last for more than 3-4 years.
However as you can read on my previous thread I'm having some unexpected and random battery drain issues.
After further investigation I found out that the capacitors on DEC pins inside the module have different values than the ones in the reference circuit.
This is the internal schematic of the module I'm using.
This is my design with its external passive components.
If I remove all the external capacitors I added, and keep only the C5 (1uF on DEC4 pin). Will the design be improved?
There's one capacitor on DEC3 that is far off... 100nF instead of 100pF... Which I cannot remove from inside the module. Will that cause any further problems?
