Extracting topic data from JSON topic received from AWS broker (using nRF9160dk)
Hi
I am using nRF9160dk board.
I started with the aws_iot example, compiling it within VS Code.
I set up my board as a ‘thing’ in Amazon’s AWS, along with policy, certificates etc.
I will explain an issue I am having, however I will probably use the wrong terminology etc., because I am relatively new to using Nordic, and just as new to Amazon AWS.
Using AWS’s MQTT Test Client, I subscribed to all topics from my board, and I could see that I received the following two topics every 60 seconds:
$aws/things/my-nRF9160dk_thing01/shadow/update
and
$aws/things/my-nRF9160dk_thing01/shadow/update/accepted
All good so far…
The next thing I wanted to do was publish a change of value, using the MQTT Test Client in AWS
So I entered the following:
Topic name:
$aws/things/imme-nRF9160dk_thing01_eu/shadow/update
Message payload:
  "state": {
    "desired": {
      "batv": 123
Immediately, I can see on the board’s NRF Terminal output that this message was received, as the board received the following topic:
$aws/things/my-nRF9160dk_thing01/shadow/update/delta
along with the new batv desired value
Still good so far…
The next thing I wanted to do, and this is where |I am struggling, is to parse this received JSON delta topic, and just extract the new value for batv
I added additional code to the print_received_data() function in the aws_iot application:
const cJSON * batVal = NULL;    // <-- added this
root_obj = cJSON_Parse(buf);
if (root_obj == NULL) {
  printk("cJSON Parse failure");
  return;
str = cJSON_Print(root_obj);
if (str == NULL) {
  printk("Failed to print JSON object");
  goto clean_exit;
batVal = cJSON_GetObjectItemCaseSensitive(root_obj, "batv");      // <-- added this
However, I think I might be using this function call incorrectly, because I seem to get nothing back.
Any of the following calls, return false:
if (cJSON_IsInvalid(batVal)
if (cJSON_IsFalse (batVal)
if (cJSON_IsTrue (batVal)
if (cJSON_IsNull (batVal)
if (cJSON_IsNumber (batVal)
if (cJSON_IsString (batVal)
if (cJSON_IsArray (batVal)
if (cJSON_IsRaw (batVal)
If anyone can understand this post Blush can you spot what I am doing wrong?
Thanks
Garrett
    Could you try replacing the line
    with the following 2 lines
    cJSON *json_parsed = cJSON_Parse(str);
    batVal = cJSON_GetObjectItemCaseSensitive(json_parsed, "batv");
    You could then print with
    char *str2 = cJSON_Print(batVal);
    printk("batVal: %s\n", str2);
    Dejan
  • Hi Dejan
    Thanks for the suggestion.
    I have been going around in circles with this :)
    Here is what I have at the moment - it's a bit messy as I have been adding a lot of debug feedback etc.
    For some reason, it doesn't seem to extract the "batv" value
    Code:
    static void print_received_data(const char *buf, const char *topic,
    				size_t topic_len)
    	char *str = NULL;
    	cJSON *root_obj = NULL;
    	printk("\n. . . . . . . . \n");
    	printk("print_received_data");
    	printk("Received buffer: \n%s\n", buf);
    	printk("Received topic: \n%s\n", topic);
    	printk("Received topic len: \n%d", topic_len);
    	printk("\n1 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^");
    		return;
    	printk("\n2 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^");
    	if (str == NULL) {
    		goto clean_exit;
    	printk("\n3 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^");
    	cJSON *batval;
    	batval = cJSON_GetObjectItemCaseSensitive(json_parsed, "batv");
    	if (batval == NULL)
    		printk("\n3a bat_val is null");
    	} else {
    		char *str2 = cJSON_Print(batval);
    		printk("\n3b ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^");
    		printk("batval: %s\n", str2);
    		printk("\n3c ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^");
    	printk("\n4 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^");
    Output on the terminal:
    print_received_data
    Received buffer:
    {"state":{"desired":{"dbg":444,"batv":445,"dbgStr":"apples"},"reported":{"app_version":"v1.0.0","batv":5019,"ts":69521,"dbg":0,"dbgStr":""},"delta":{"dbg":444,"batv":445,"dbgStr":"apples"}},"metadata":{"desired":{"dbg":{"timestamp":1648562859},"batv":{"timestamp":1648562859},"dbgStr":{"timestamp":1648562859}},"reported":{"app_version":{"timestamp":1648567600},"batv":{"timestamp":1648567659},"ts":{"timestamp":1648567659},"dbg":{"timestamp":1648567659},"dbgStr":{"timestamp":1648567659}}},"version":2102,"timestamp":1648567687}
    Received topic:
    $aws/things/my-nRF9160dk_thing01/shadow/get/accepted
    Received topic len:
    57
    3a bat_val is null
    Currently, you are accessing batv at the root level. Based on your structure, batv cannot be read directly (as if it is in the root level) because it is nested inside "state" and "desired".
    Dejan
  • Thank you Dejan
    You are correct - and I got it working.
    Below is an example of how it worked for me.
    Again, this is rough and ready - just trying to get the concept etc.
    	cJSON *objState;
    	cJSON *objDesired;
    	cJSON *objBatval;
    	objState = cJSON_GetObjectItemCaseSensitive(json_parsed, "state");
    	if (objState == NULL)
    		printk("\n3a objState is null");
    	} else {
    		str2 = cJSON_Print(objState);
    		json_parsed = cJSON_Parse(str2);
    		objDesired = cJSON_GetObjectItemCaseSensitive(json_parsed, "desired");
    		if (objDesired == NULL)
    			printk("\n3b objDesired is null");
    		} else {
    			str2 = cJSON_Print(objDesired);
    			objBatval = cJSON_GetObjectItemCaseSensitive(json_parsed, "batv");
    			if (objBatval == NULL)
    				printk("\n3c objBatval is null");
    			} else {
    				printk("\n3d objBatval is NOT null");
    				str2 = cJSON_Print(objBatval);
    				printk("\n3e ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^");
    				printk("objBatval: %s\n", str2);
    				printk("\n3f ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^");
    Regards
    Garrett
