PC-BLE-Driver (JS/ python) for a nRF Connect SDK counterpart
Hi!
Reading this ticket, and the nRF Connect SDK and nRF5 SDK statement, I understand that the PC-BLE-Driver, whether the Python or JS variant, are in maintenance mode, and will not see new features developed for them.
Is there a plan to release a 'PC-BLE-Driver' equivalent which will work with the nRF Connect SDK equivalent of a connectivity firmware?
I assume this requires both a 'connectivity firmware' equivalent be developed under nRF connect SDK, and that a matching PC-BLE-Driver be developed which will issue commends to the connectivity, or the RTOS? I'm not sure as I've not yet worked with RTOS nor nRF connect SDK.
Thanks!
    There is as of now no equivalent to the pc-ble-driver for use with the nRF Connect SDK. We are looking into this though so I expect there will be a solution in the future, but I cannot say what or when.
    (Note that if you are targeting Linux or other host systems that has a Bluetooth host stack that support HCI, then you can run the controller only on the nRF, and that is supported now using for instance Bluetooth: HCI UART).
  • Hi Einar!
    Thank you for your reply!
    I understand you can't share specific details, but could you say if you are aiming at releasing both a pc-ble-driver 'equivalent' (C libraries) and Python and JavaScript wrappers for it as well?
    Thanks!
  • As far as I know there are no immediate plans to make any PC side libraries for BLE connectivity with the nRF Connect SDK. There are a few options, though:
    • Use the Zephyr Bluetooth shell (found under zephyr/tests/) and control it via human readable text commands. This is probably what is most relevant.
    • Use the HCI controller on the nRF and the HCI host on the PC, as suggested before. That assumes that a HCI host exists for the host OS (as is the case for Linux with BlueZ).
    • It might be possible to do something based on the Zephyr serialization API, though this is intended for communication between CPU cores in the same SoC.
