Building MCUBoot separate from application.
Hi there,
Our current understanding is that when building an application using NCS, the images of of MCUBoot and the application gets merged into merged.hex.
We however would like to be able to build MCUBoot in its own seperate project (SES/VS Code). This will allow us to easily customize the bootloader where needed and also access the sources:
1) Is this possible? Is there an example project for this?
2) Please provide information on how to set this up/configure/build MCUBoot separately.
Our application is developed in IAR, using a different OS than Zephyr. This thus requires us to build MCUBoot separately. We will then boot from MCUBoot using Zephyr, into our application using a different OS.
3) If not possible to build separately, will we be able to use an example project (e.g. blinky), configure the bootloader from there, and just use the child image generated for the bootloader before merged.hex is created, in order to boot into our application?
Frikkie Badenhorst
  • Hi Frikkie,
    Yes, it should be possible to build MCUboot as a separate project. You can find more information about bootloader and mcuboot repositories on bootloader, mcuboot and sdk-mcuboot.
    This is dependent on the operating system you choose. We have extensive documentation regarding bootloader and building and using MCUboot with Zephyr.
    Dejan
    sorry to border you but i'm stucked in the building procedure of the mcuboot.
    I'm following that  documentation Build MCUBoot with zephyr but i can not undestand this command:
    "cmake -GNinja -DBOARD=<board> .."
    Which is the file that i have to put instead of "borad"? Which is the right path?
    Every time that i insert a board i receive back from the cmc "Access Denied".
    Can you provide me an example about this command?
    Thank's for your help
    <board> is the name of the board in your project that you want to build for. This can be your custom board or the board included in NCS.
    For example, for the custom board named reel_board
    Use cmake to configure a Ninja-based build system:
    cmake -B build -GNinja -DBOARD=reel_board samples/hello_world
    As another example, for nRF9160-DK the option would be
    -DBOARD=nrf9160dk_nrf9160ns
    Dejan
  • Hi Sigurd, we are having similar issues. We are not able to build the bootloader. When trying to install the necessary dependencies, we get a lot of warnings:
    C:\nordic\v1.9.0\bootloader\mcuboot>pip3 install --user -r scripts/requirements.txt
    WARNING: Ignoring invalid distribution -ip (c:\python39\lib\site-packages)
    Requirement already satisfied: cryptography>=2.6 in c:\users\frikkiebadenhorst\appdata\roaming\python\python39\site-packages (from -r scripts/requirements.txt (line 1)) (36.0.2)
    Requirement already satisfied: intelhex in c:\users\frikkiebadenhorst\appdata\roaming\python\python39\site-packages (from -r scripts/requirements.txt (line 2)) (2.3.0)
    Requirement already satisfied: click in c:\users\frikkiebadenhorst\appdata\roaming\python\python39\site-packages (from -r scripts/requirements.txt (line 3)) (8.1.0)
    Requirement already satisfied: cbor2 in c:\users\frikkiebadenhorst\appdata\roaming\python\python39\site-packages (from -r scripts/requirements.txt (line 4)) (5.4.2.post1)
    Requirement already satisfied: cffi>=1.12 in c:\users\frikkiebadenhorst\appdata\roaming\python\python39\site-packages (from cryptography>=2.6->-r scripts/requirements.txt (line 1)) (1.15.0)
    Requirement already satisfied: colorama in c:\python39\lib\site-packages (from click->-r scripts/requirements.txt (line 3)) (0.4.4)
    Requirement already satisfied: pycparser in c:\users\frikkiebadenhorst\appdata\roaming\python\python39\site-packages (from cffi>=1.12->cryptography>=2.6->-r scripts/requirements.txt (line 1)) (2.21)
    Then after trying to build the bootloader for the nrf5340, we get errors:
    C:\nordic\v1.9.0\bootloader\mcuboot>cd boot/zephyr
    C:\nordic\v1.9.0\bootloader\mcuboot\boot\zephyr>mkdir build && cd build
    A subdirectory or file build already exists.
    C:\nordic\v1.9.0\bootloader\mcuboot\boot\zephyr>cmake -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp
    CMake Warning:
      No source or binary directory provided.  Both will be assumed to be the
      same as the current working directory, but note that this warning will
      become a fatal error in future CMake releases.
    Including boilerplate (Zephyr workspace): C:/nordic/v1.9.0/zephyr/cmake/app/boilerplate.cmake
    -- Application: C:/nordic/v1.9.0/bootloader/mcuboot/boot/zephyr
    -- Using NCS Toolchain 1.9.0 for building. (C:/nordic/v1.9.0/toolchain/cmake)
    -- Zephyr version: 2.7.99 (C:/nordic/v1.9.0/zephyr), build: v2.7.99-ncs1
    -- Found Python3: C:/nordic/v1.9.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
    CMake Error at C:/nordic/v1.9.0/zephyr/cmake/app/boilerplate.cmake:174 (file):
      file problem creating directory:
      C:/nordic/v1.9.0/bootloader/mcuboot/boot/zephyr/Kconfig
      C:/nordic/v1.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
      C:/nordic/v1.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:68 (include_boilerplate)
      C:/nordic/v1.6.0/zephyr/share/zephyr-package/cmake/zephyr_package_search.cmake:101 (include)
      C:/nordic/v1.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:95 (check_zephyr_package)
      CMakeLists.txt:44 (find_package)
    CMake Error at C:/nordic/v1.9.0/zephyr/cmake/zephyr_module.cmake:61 (message):
        File "C:/nordic/v1.9.0/zephyr/scripts/zephyr_module.py", line 542, in <module>
          main()
        File "C:/nordic/v1.9.0/zephyr/scripts/zephyr_module.py", line 508, in main
          with open(args.kconfig_out, 'w', encoding="utf-8") as fp:
      FileNotFoundError: [Errno 2] No such file or directory:
      'C:/nordic/v1.9.0/bootloader/mcuboot/boot/zephyr/Kconfig/Kconfig.modules'
      C:/nordic/v1.9.0/zephyr/cmake/app/boilerplate.cmake:175 (include)
    This is quite frustrating, as we are experiencing a lot of issues when using NCS tools. Please advise
    I noticed that there is an inconsistency of using both "C:/nordic/v1.9.0" and "C:/nordic/v1.6.0". Your Zephyr version is OK.
    What were the SDK and Toolchain versions used when creating the application?
    Dejan
