Build and Run with SEGGER Embedded Studio (SES) v6.20a on nRF5 SDK 17.1.0 and S140 7.2.0 on nRF52840
Hi DevZone,
I have recently updated:
  • nRF5 SDK to 17.1.0 from 15.3.0
  • S140 to 7.2.0 from 6.1.1
  • SES to v6.20a from 4.16
The SoftDevice now fails to initialize when using the "Build and Run" option with SES.
The code initializes without issue if I:
  • Use Programmer v2.3.3 from nRF Connect for Desktop v3.10.0
  • If I Power Cycle the hardware after each flash of the .hex files
  • If I "Build and Debug" with SES
Is this a known issue, and could it potentially be a timing issue?
Code that fails:
void ble_stack_init(void)
    ret_code_t err_code;
    uint32_t ram_start = 0;
    err_code = nrf_sdh_ble_default_cfg_set(BLE_CONN_CFG_TAG, &ram_start);
    // Enable BLE stack.
//    // NO OBSERVERS AT THIS POINT
//    // Register a handler for BLE events.
//    NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, ble_evt_handler, NULL);
Specifically the call to nrf_sdh_enable_request() returns with error code NRF_ERROR_INVALID_STATE (0x00000008).
This should mean that the SoftDevice is already initialized when reading the documentation. However, preceding the nrf_sdh_enable_request() call with a nrf_sdh_is_enabled()
tells me that it is not.
Comparing with example projects:
I have compared to the example projects given in SDK 17.1.0, and the initialization code for the BLE stack seems unchanged between versions 17.1.0 and 15.3.0.
Also, I have tried building and running the peripheral example from SDK 17.1.0 "usbd_ble_uart_freertos" both on our hardware and an nRF52840-DK, which fails with the same error code.
So, even with code directly from the SDK and on multiple hardware the issue is the same.
Thanks in advance.
Br. Casper
  • Hello Casper,
    Can you please check whether the log says anything when the nrf_sdh_enable_request() fails?
    I believe it should say something about ram start and sizes.
    Edvin
  • Hi Edvin,
    Thank you for getting back to me.
    By log do you mean the nrf_log?
    The only output I am getting from that is:
    [Debug] <debug> nrf_sdh_freertos: Creating a SoftDevice task.
    [Debug] <debug> nrf_sdh_freertos: Enter softdevice_task.
    This is outputted after the NRF_ERROR_INVALID_STATE error is returned by nrf_sdh_enable_request().
    The reason for the prepended [Debug] is that the nrf_log is fed to our own log system for a common output of all log messages.
    Is there something I might need to add or initialize if the messages are being filtered out somehow?
    Br. Casper
    I didn't understand exactly what you did with your log, but if you look at the implementation of nrf_sdh_ble_enable(), it should look something like this:
    ret_code_t nrf_sdh_ble_enable(uint32_t * const p_app_ram_start)
        // Start of RAM, obtained from linker symbol.
        uint32_t const app_ram_start_link = *p_app_ram_start;
        ret_code_t ret_code = sd_ble_enable(p_app_ram_start);
        if (*p_app_ram_start > app_ram_start_link)
            NRF_LOG_WARNING("Insufficient RAM allocated for the SoftDevice.");
            NRF_LOG_WARNING("Change the RAM start location from 0x%x to 0x%x.",
                            app_ram_start_link, *p_app_ram_start);
            NRF_LOG_WARNING("Maximum RAM size for application is 0x%x.",
                            ram_end_address_get() - (*p_app_ram_start));
            NRF_LOG_DEBUG("RAM starts at 0x%x", app_ram_start_link);
            if (*p_app_ram_start != app_ram_start_link)
                NRF_LOG_DEBUG("RAM start location can be adjusted to 0x%x.", *p_app_ram_start);
                NRF_LOG_DEBUG("RAM size for application can be adjusted to 0x%x.",
        if (ret_code == NRF_SUCCESS)
            m_stack_is_enabled = true;
            NRF_LOG_ERROR("sd_ble_enable() returned %s.", nrf_strerror_get(ret_code));
        return ret_code;
    Are any of the lines containing NRF_LOG_WARNING hit? And if so, what are the parameters that it is trying to print?
    Edvin
  • Hi Edvin,
    I had to remove the calls to APP_ERROR_CHECK(err_code) to get some output.
    This is what I am getting from all of ble_stack_init():
    <error> nrf_sdh_ble: sd_ble_cfg_set() returned NRF_ERROR_INVALID
     _STATE when attempting to set BLE_CONN_CFG_GAP.
    _STATE when attempting to set BLE_GAP_CFG_ROLE_COUNT.
    _STATE when attempting to set BLE_COMMON_CFG_VS_UUID.
    _STATE when attempting to set BLE_GATTS_CFG_ATTR_TAB_SIZE.
     _STATE when attempting to set BLE_GATTS_CFG_SERVICE_CHANGED.
    <error> nrf_sdh_ble: sd_ble_enable() returned NRF_ERROR_INVALID_
    STATE.
    It does not seem like any of the NRF_LOG_WARNING calls in nrf_sdh_ble_enable() are being hit.
    Br. Casper
  • Are you calling ble_stack_init() 6 times? Because it looks like you are trying to call sd_ble_cfg_set() 6 times, and it returns NRF_ERROR_INVALID_STATE. One reason for that may be that it is already enabled, I believe. From ble.h:
     * @retval ::NRF_SUCCESS              The configuration has been added successfully.
     * @retval ::NRF_ERROR_INVALID_STATE  The BLE stack had already been initialized.
     * @retval ::NRF_ERROR_INVALID_ADDR   Invalid or not sufficiently aligned pointer supplied.
     * @retval ::NRF_ERROR_INVALID_PARAM  Invalid cfg_id supplied.
     * @retval ::NRF_ERROR_NO_MEM         The amount of memory assigned to the SoftDevice by app_ram_base is not
     *                                    large enough to fit this configuration's memory requirement.
    SVCALL(SD_BLE_CFG_SET, uint32_t, sd_ble_cfg_set(uint32_t cfg_id, ble_cfg_t const * p_cfg, uint32_t app_ram_base));
    Will I be able to reproduce your issue with a DK? If so, can you send a project that replicates the issue that you are seeing?
    Edvin
