Sensor model property id
When I was adding the ID of the sensor, I found that the specific name displayed on the Bluetooth app is not my own name. Is there a special definition for this ID? I checked the Bluetooth manual, but it didn't explain. Is there a specific document to explain it?
  • Hi.
    Maybe you could elaborate a little bit?
    What sensor? Which name is displayed, and which name is expected? nRF Mesh is the bluetooth app?
    Please provide some more information, and I'll do my best to help!
    Br,
    Joakim
  • hello,Joakim。Thanks for your advice.
    When I tested the sensor example under Bluetooth mesh SDK, it seems that the officially defined sensor, such as sensor_ MOTION_ SENSED_ PROPERTY_ ID stands for 0x0042. However, if I need to customize the sensor ID and name, it seems that it is not allowed. Can only use officially specified sensors?
  • Hi.
    From what I read in the specification, you can not customize these values:
    "The sensor data state contains an array of property ID / raw value pairs.The Bluetooth mesh device properties specification defines properties and the characteristics to which they relate."
    Br,
    Joakim
