I'm building a nrfmicro bluetooth keyboard controller which uses an ebyte E73-2G4M08S1C nrf52840. My programmer is cmsis dap link. Openocd verson is 0.11.0.
I built two controllers successfully and they run firmware well. Another controller (the third one) which was built in the same way, but after I reconnect power, the nrfmicro controller starts firmware only after I connect cmsis dap link and run command
openocd -d2 -f interface/cmsis-dap.cfg -f target/nrf52.cfg -c init -c exit
I guess this is a software issue rather than soldering issue or hardware damage. I tried desoldering and re-flash the bootloader but it does't help. Is there a way to factory reset the nrf52840? So that I flash again from the beginning?
Below are what I did and how the controller behaves
1. Unlock is fine
openocd -d2 -f interface/cmsis-dap.cfg -f target/nrf52.cfg -c "init" -c "nrf52.dap apreg 1 0x04 0x01" -c "exit"
############## unlock output omitted
openocd -d2 -f interface/cmsis-dap.cfg -f target/nrf52.cfg -c "init" -c "nrf52.dap apreg 1 0x04" -c "exit"
Open On-Chip Debugger 0.11.0
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
debug_level: 2
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
Info : CMSIS-DAP: SWD Supported
Info : CMSIS-DAP: FW Version = 2.0.0
Info : CMSIS-DAP: Serial# = 205526554555
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 1000 kHz
Info : SWD DPIDR 0x2ba01477
Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : starting gdb server for nrf52.cpu on 3333
Info : Listening on port 3333 for gdb connections
0x00000001
2. Flash Adafruit nRF52 Bootloader pca10056_bootloader-0.6.3_s140_6.1.1.hex
openocd -d2 -c 'set WORKAREASIZE 0;' -f interface/cmsis-dap.cfg -f target/nrf52.cfg -c init -c "program ./pca10056_bootloader-0.6.3_s140_6.1.1.hex verify reset exit"
debug_level: 2
Error: nrf52.cpu -- clearing lockup after double fault
Polling target nrf52.cpu failed, trying to reexamine
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
** Programming Started **
Info : nRF52840-xxAA(build code: D0) 1024kB Flash, 256kB RAM
Info : Padding image section 0 at 0x00000b00 with 1280 bytes
Info : Flash write discontinued at 0x00025de8, next section at 0x000f4000
Warn : Adding extra erase range, 0x00025de8 .. 0x00025fff
Warn : not enough working area available(requested 34)
Warn : no working area available, falling back to slow memory writes
Info : Padding image section 2 at 0x000fc124 with 5852 bytes
Warn : Adding extra erase range, 0x000fd858 .. 0x000fdfff
Warn : Adding extra erase range, 0x10001000 .. 0x10001013
Warn : Adding extra erase range, 0x1000101c .. 0x10001fff
** Programming Finished **
** Verify Started **
Warn : not enough working area available(requested 52)
** Verified OK **
** Resetting Target **
shutdown command invoked
3. Flash a dummy blink firmware blink.uf2 or zmk keyboard firmware by copy the uf2 file to the inernal USB drive.
4. The blink and zmk keyboard firmware works as expected, until power is disconnected
5. disconnect USB power, reconnect USB power
6. The blink and zmk keyboard firmware doesn't start
7. Connect cmsis dap link and run command
8. The blink and zmk keyboard firmware starts and works as expected, until power is disconnected
