Dear Nordic Experts,
This one's a tough nut to crack:
The firmware is based on nRF5 SDK for Mesh 5.0.0 with nRF5 SDK 17.0.2 and Softdevice s132 7.3.0. It runs on a nRF52832. When provisioning, it very rarely happens that the firmware gets trapped at app_error_fault_handler(). The short question is what can cause this, and how to fix it?
When the error happens, the stacktrace looks like:
app_error_fault_handler() 0x0002708a
app_error_handler_bare() 0x000392bc
RTC1_IRQHandler() 0x0003f0e8
0x00041f10
main() 0x00026948
0x000262AE And SES logged:
<t: 377511>, main.c, 291, Successfully provisioned <t: 377516>, main.c, 175, Restoring default configuration! <t: 377543>, ble_dfu_support.c, 171, ble_dfu_support_service_init() <t: 377549>, main.c, 286, Node Address: 0x0004 Addresses used: 1 <t: 377556>, main.c, 250, Mesh event: 0x1D <t: 378068>, main.c, 250, Mesh event: 0x12 <t: 378071>, main.c, 218, Mesh event: NRF_MESH_EVT_RX_FAILED <t: 424714>, proxy.c, 632, Connected <t: 439992>, ble_softdevice_support.c, 104, Successfully updated connection parameters <t: 489533>, main.c, 250, Mesh event: 0x4 <t: 489537>, mesh_gatt.c, 168, HVN data: 4101007D520E366F2048C10000000025B661239B <t: 489545>, mesh_gatt.c, 219, status: 8 len: 20 usable-mtu:20 sar_type: 1 <t: 493487>, app_error_weak.c, 115, Mesh error 8 at 0x00000000 (:0)
Unfortunately this happened on a release build, so the elf file isn't of much help.
Questions now are:
- What could case RTC1_IRQHandler() to trigger Mesh error 8 (NRF_ERROR_INVALID_STATE)?
- And how to avoid it?
Since this is related to the timer, I suspect that my firmware may have a fundamental flaw. Let me explain:
- The firmware uses app_timer_xxx() api to compute the device's uptime:
uint64_t calculate_uptime_in_milliseconds() { uint32_t this_ticks = app_timer_cnt_get(); uptime_in_ticks += app_timer_cnt_diff_compute(this_ticks, last_ticks); last_ticks = this_ticks; uptime_in_milliseconds = (uptime_in_ticks * 1000) / APP_TIMER_CLOCK_FREQ; return uptime_in_milliseconds; } - The main loop uses the uptime to drive the business logic:
int main(void) { initialize(); start(); while (true) { uint64_t uptime_in_milliseconds = calculate_uptime_in_milliseconds(); handle_node_reset(uptime_in_milliseconds); handle_leds(uptime_in_milliseconds); handle_business_logic(&mesh_server, uptime_in_milliseconds); nrf_delay_ms(50); } }
What's your point on this approach? Could the way app_timer is used be related to RTC1_IRQHandler() causing Mesh error 8 (NRF_ERROR_INVALID_STATE)?
The issue happens only once every few hundred provisioning attempts, so any advise is very welcome!
Thank you,
Michael.
EDIT:
There were some technical issues yesterday (site didn't finish sending), that caused this question to be posted three times. Unfortunately I've noticed it too late.
