app_uart high sleep current issue
We are making software for our custom board based on nRF52833 and nRF5 SDK 17.0.2. We use app_uart for our serial communication in active mode and in sleep mode we disable the UART. Without APP_UART_FIFO_INIT the device's current consumption is about 2uA in sleep mode using nrf_pwr_mgmt_run(). When we initialize UART for serial communication, we have made sure to uninitilaze UART by calling app_uart_close function and set UART TX and UART RX pin to  INPUT_NOPULL before setting the device to sleep mode, but current that does not work. The sleep current consumption is now about 179uA. Here is our configurations for app_uart
//brief: uart settings:
static app_uart_comm_params_t comm_params = {
    .rx_pin_no    = UART_RX,
    .tx_pin_no    = UART_TX,
    .rts_pin_no   = 0xffffffff,
    .cts_pin_no   = 0xffffffff,
    .use_parity   = false,
#if defined (UART_PRESENT)
    .baud_rate    = NRF_UART_BAUDRATE_115200
#else
    .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       DRV_UART_RX_BUFFER_SIZE,
                       DRV_UART_TX_BUFFER_SIZE,
                       uart_callback_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
  • Allright! I finally found the root cause for high sleep current consumption in my device. It was not the issue with app_uart_close nor the issue with the nRF52833 SoC. So using just  app_uart_close() is the proper setup before going to sleep. So we can close the topic here. Thank you so much for you help!
