Open nRF Connect SDK Project fails when importing project with board.c out of tree source file
I'm esperiencing this error when I try to import a project which has board folder inside project folder and board definition include board.c sourcefile (nrf52840dongle_nrf52840),
C:\Users\Luca\ncs\v1.9.1\toolchain\opt\bin\arm-none-eabi-gdb.exe: warning: Couldn't determine a path for the index cache directory.
CMake Error at C:/Users/Luca/ncs/v1.9.1/zephyr/cmake/extensions.cmake:421 (add_library):
The target name
"D:__Users__Luca__Documents__nRF52__Peripheral__boards__arm__nrf52840dongle_nrf52840"
is reserved or not valid for certain CMake features, such as generator
expressions, and may result in undefined behavior.
C:/Users/Luca/ncs/v1.9.1/zephyr/cmake/extensions.cmake:398 (zephyr_library_named)
boards/arm/nrf52840dongle_nrf52840/CMakeLists.txt:3 (zephyr_library)
CMake Error at C:/Users/Luca/ncs/v1.9.1/zephyr/cmake/extensions.cmake:476 (target_sources):
Cannot specify sources for target
which is not built by this project.
boards/arm/nrf52840dongle_nrf52840/CMakeLists.txt:4 (zephyr_library_sources)
error: cmake failed
create_nordic_project.py failed (1)
I'm able to import whitout problems the project with out tree board difinition which do not require board.c sourcefile (nrf52840dk)_nrf52840.
I'm using windows 10 and Segger IDE and 1.9.1 nRF Connect SDK. My Documens folder is on disk D: whereas SDK is on disk C: standard installation folder.
I need to make changes to board.c file, but for this test I just copied the board definition folders in my project folder in boards/arm subdirectory, without modification.
Here the tree structure:
D:\Users\Luca\Documents\nRF52\Peripheral
 - src
 - CMakeList.txt
D:\Users\Luca\Documents\nRF52\Peripheral\boards\arm\nrf52840dongle_nrf52840
 - board.c
 - CMakeList.txt
I changed the project makelist file in accordance to Out Of Tree Board sample project, and it works when no board.c source file required.
Here the full log from the importer and project makefile:
Creating solution Peripheral.emProject
  C:/Users/Luca/ncs/v1.9.1/toolchain/opt/bin/cmake.exe -GNinja -DBOARD=nrf52840dongle_nrf52840 -DBOARD_DIR=D:\Users\Luca\Documents\nRF52\Peripheral\boards\arm\nrf52840dongle_nrf52840 -BD:\Users\Luca\Documents\nRF52\Peripheral\build_nrf52840dongle_nrf52840 -SD:\Users\Luca\Documents\nRF52\Peripheral -DNCS_TOOLCHAIN_VERSION=1.9.1 -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:\Users\Luca\ncs\v1.9.1\toolchain\segger_embedded_studio/html/configure_nordic_project_menuconfig.py
  -- Application: D:/Users/Luca/Documents/nRF52/Peripheral
  -- Zephyr version: 2.7.99 (C:/Users/Luca/ncs/v1.9.1/zephyr), build: v2.7.99-ncs1-1
  -- Found Python3: C:/Users/Luca/ncs/v1.9.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
  -- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
  -- Board: nrf52840dongle_nrf52840
  -- Cache files will be written to: C:/Users/Luca/ncs/v1.9.1/zephyr/.cache
  -- Found dtc: C:/Users/Luca/ncs/v1.9.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
  -- Found toolchain: gnuarmemb (C:/Users/Luca/ncs/v1.9.1/toolchain/opt)
  -- Found BOARD.dts: D:/Users/Luca/Documents/nRF52/Peripheral/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840.dts
  -- Found devicetree overlay: D:/Users/Luca/Documents/nRF52/Peripheral/app.overlay
  -- Generated zephyr.dts: D:/Users/Luca/Documents/nRF52/Peripheral/build_nrf52840dongle_nrf52840/zephyr/zephyr.dts
  -- Generated devicetree_unfixed.h: D:/Users/Luca/Documents/nRF52/Peripheral/build_nrf52840dongle_nrf52840/zephyr/include/generated/devicetree_unfixed.h
  -- Generated device_extern.h: D:/Users/Luca/Documents/nRF52/Peripheral/build_nrf52840dongle_nrf52840/zephyr/include/generated/device_extern.h
  -- Including generated dts.cmake file: D:/Users/Luca/Documents/nRF52/Peripheral/build_nrf52840dongle_nrf52840/zephyr/dts.cmake
  Parsing D:/Users/Luca/Documents/nRF52/Peripheral/Kconfig
  Loaded configuration 'D:/Users/Luca/Documents/nRF52/Peripheral/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840_defconfig'
  Merged configuration 'D:/Users/Luca/Documents/nRF52/Peripheral/prj.conf'
  Configuration saved to 'D:/Users/Luca/Documents/nRF52/Peripheral/build_nrf52840dongle_nrf52840/zephyr/.config'
  Kconfig header saved to 'D:/Users/Luca/Documents/nRF52/Peripheral/build_nrf52840dongle_nrf52840/zephyr/include/generated/autoconf.h'
  -- The C compiler identification is GNU 9.2.1
  -- The CXX compiler identification is GNU 9.2.1
  -- Found assembler: C:/Users/Luca/ncs/v1.9.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
  See also "D:/Users/Luca/Documents/nRF52/Peripheral/build_nrf52840dongle_nrf52840/CMakeFiles/CMakeOutput.log".
  See also "D:/Users/Luca/Documents/nRF52/Peripheral/build_nrf52840dongle_nrf52840/CMakeFiles/CMakeError.log".
  Including boilerplate (Zephyr base): C:/Users/Luca/ncs/v1.9.1/zephyr/cmake/app/boilerplate.cmake
  -- Using NCS Toolchain 1.9.1 for building. (C:/Users/Luca/ncs/v1.9.1/toolchain/cmake)
  warning: STDOUT_CONSOLE (defined at lib/libc/Kconfig:182) was assigned the value 'y' but got the
  value 'n'. Check these unsatisfied dependencies: CONSOLE_HAS_DRIVER (=n). See
  http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_STDOUT_CONSOLE.html and/or look up
  STDOUT_CONSOLE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
  Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
  too.
  warning: The choice symbol LOG_BACKEND_RTT_MODE_DROP (defined at
  subsys/logging\Kconfig.backends:111) was selected (set =y), but no symbol ended up as the choice
  selection. See
  http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_LOG_BACKEND_RTT_MODE_DROP.html and/or
  look up LOG_BACKEND_RTT_MODE_DROP in the menuconfig/guiconfig interface. The Application Development
  Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
  might be helpful too.
    The target name
  error: cmake failed
# Copyright (c) 2020 Nordic Semiconductor
cmake_minimum_required(VERSION 3.20.0)
# Re-direct the directory where the 'boards' directory is found from
# $ZEPHYR_BASE to this directory.
set(BOARD_ROOT ${CMAKE_CURRENT_LIST_DIR})
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(Peripheral)
target_sources(app PRIVATE src/main.c)
Thank you very match for your help.
LucaF
