How to fix bad file descriptor error in VS Code? "File changes watcher stopped unexpectedly. "
I have vsc version 1.66. I'm getting the following notification:
File changes watcher stopped unexpectedly. A reload of the window may enable the watcher again unless the workspace cannot be watched for file changes.
there's  nrf connect:generate Support Information :
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro for Workstations",
    "osKernel": "10.0.22000",
    "vscode": "1.66.0",
    "electron": "17.2.0",
    "node": "v16.13.0"
  "system": {
    "date": "2022-04-01T08:06:47.304Z",
    "vscodeRoot": "c:\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:01:48",
    "osUptime": "24:45:07",
    "cpu": {
      "model": "Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz",
      "speed": "2112 MHz",
      "count": 4
    "memory": {
      "total": "15.84 GB",
      "free": "6.84 GB"
  "workspace": {
    "name": "Untitled (Workspace)",
    "workspaceFile": "1648727226399",
    "folders": [
      "d:\\ncs\\myapps\\myfirstapp",
      "d:\\ncs\\myapps\\mysecondapp"
  "extensions": {
    "internal": {
        "version": "2022.3.104",
        "path": "c:\\Users\\AK_firmware\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.3.104",
        "isActive": true
        "version": "2022.3.31",
        "path": "c:\\Users\\AK_firmware\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.3.31",
        "isActive": true
      "nordic-semiconductor.devicetree": null,
      "nordic-semiconductor.kconfig": null
    "external": {
      "marus25.cortex-debug": "1.4.4",
      "ms-vscode.cpptools": "1.9.7",
      "ms-vscode-remote.remote-wsl-recommender": "0.0.15",
      "ms-vscode.js-debug": "1.66.1",
      "ms-vscode.js-debug-companion": "1.0.16",
      "ms-vscode.references-view": "0.0.86",
      "ms-vscode.vscode-js-profile-table": "1.0.0",
      "cschlosser.doxdocgen": "1.4.0",
      "jeff-hykin.better-cpp-syntax": "1.15.13",
      "MS-CEINTL.vscode-language-pack-zh-hans": "1.66.1",
      "ms-vscode-remote.remote-containers": "0.231.1",
      "ms-vscode-remote.remote-ssh": "0.78.0",
      "ms-vscode-remote.remote-ssh-edit": "0.78.0",
      "ms-vscode-remote.remote-wsl": "0.66.0",
      "ms-vscode.cpptools-extension-pack": "1.1.0",
      "ms-vscode.cpptools-themes": "1.0.0",
      "twxs.cmake": "0.0.17"
  "tools": {
    "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.58b",
    "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.15.4",
    "nrfutil": "Not found",
    "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\cmake.exe": "3.20.5",
    "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\Scripts\\west.exe": "0.12.0",
    "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\python.exe": "3.8.2",
    "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\ninja.exe": "1.9.0",
    "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\gperf.exe": "3.1",
    "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\dtc.exe": "1.4.7",
    "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\arm-none-eabi-gcc.exe": "9-2019-q4-major",
    "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\gn.exe": "1977",
    "d:\\ncs\\v1.9.1\\toolchain\\mingw64\\bin\\git.exe": "2.26.2.windows.1"
  "sdks": [
      "version": "1.9.1",
      "path": "d:\\ncs\\v1.9.1"
  "toolchains": [
      "version": "1.9.1",
      "path": "d:\\ncs\\v1.9.1\\toolchain"
  "connectedDevices": [
      "serialNumber": "960129880"
  "deviceProviders": [
    "nrfjprog"
  "config": {
      "topdir": "${nrf-connect.sdk:1.9.1}",
      "toolchain": {
        "path": "${nrf-connect.toolchain:1.9.1}"
      "ozonePath": "",
      "applications": [
        "${workspaceFolder}",
      "kconfig": {
        "interface": "kconfig"
      "welcome": {
        "showOnStartup": true
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "enableTelemetry": true
      "terminalMode": "character"
    "nordic-semiconductor.devicetree": {
      "modules": [
        "${zephyrBase}",
        "${zephyrBase}/../nrf",
      "zephyr": "",
      "ctxFile": "",
      "defaultBoard": ""
    "nordic-semiconductor.kconfig": {
      "root": "",
      "env": {},
      "cfiles": true,
      "disable": false,
      "zephyr": {
        "base": ""
      "python": "",
      "liveValue": true
    "marus25.cortex-debug": {
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "enableTelemetry": true,
      "flattenAnonymous": false,
      "registerUseNaturalFormat": true,
      "variableUseNaturalFormat": true,
      "dbgServerLogfile": null,
      "showRTOS": false,
      "showDevDebugOutput": "none"
  "environment": {
    "westExe": "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\Scripts\\west.exe",
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "HOME": "C:\\Users\\AK_firmware",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\AK_firmware",
      "Path": "d:\\ncs\\v1.9.1\\toolchain\\mingw64\\bin;d:\\ncs\\v1.9.1\\toolchain\\mingw64\\libexec\\git-core;d:\\ncs\\v1.9.1\\toolchain\\opt\\bin;d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\Scripts;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\Windows\\System32\\HWAudioDriverLibs;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Users\\AK_firmware\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;D:\\Program Files\\TortoiseSVN\\bin;D:\\Program Files\\cmder;C:\\Program Files\\dotnet\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;C:\\Users\\AK_firmware\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\AK_firmware\\.dotnet\\tools;C:\\Microsoft VS Code\\bin",
      "ZEPHYR_BASE": "d:\\ncs\\v1.9.1\\zephyr",
      "GNUARMEMB_TOOLCHAIN_PATH": "d:\\ncs\\v1.9.1\\toolchain\\opt",
      "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
      "PYTHONPATH": "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin;d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\Lib;d:\\ncs\\v1.9.1\\toolchain\\opt\\bin\\Lib\\site-packages",
      "Python3_ROOT": "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin"
    "toolchainPath": "d:\\ncs\\v1.9.1\\toolchain",
    "toolchainBinPath": "d:\\ncs\\v1.9.1\\toolchain\\opt\\bin",
    "toolchainVersion": "1.9.1"
  "terminal": {
    "shell": null,
    "defaultProfile": null
there's  Developer log file:
[2022-04-01 16:11:42.676] [renderer1] [warning] Settings pattern "keyboard.*" doesn't match any settings
[2022-04-01 16:11:43.378] [renderer1] [info] Ignoring configured affinity for 'pub.name' because the extension is unknown or cannot execute.
[2022-04-01 16:11:45.042] [renderer1] [info] Ignoring configured affinity for 'pub.name' because the extension is unknown or cannot execute.
[2022-04-01 16:11:46.554] [renderer1] [warning] Settings pattern "keyboard.*" doesn't match any settings
[2022-04-01 16:11:51.302] [renderer1] [error] [Extension Host] (node:15140) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
(Use `Code --trace-deprecation ...` to show where the warning was created)
[2022-04-01 16:11:53.876] [renderer1] [warning] [File Watcher (parcel)] ignoring a path for watching who's parent is already watched: d:\ncs\v1.9.1\test\cmock\vendor\unity
[2022-04-01 16:11:53.918] [renderer1] [error] [File Watcher (parcel)] Unexpected error: Invalid handle (EUNKNOWN) (path: d:\ncs\v1.9.1\find-my)
[2022-04-01 16:11:53.919] [renderer1] [error] [File Watcher (universal)] restarting watcher after error: Invalid handle
[2022-04-01 16:11:54.127] [renderer1] [warning] [File Watcher (parcel)] ignoring a path for watching who's parent is already watched: d:\ncs\v1.9.1\test\cmock\vendor\unity
[2022-04-01 16:11:54.128] [renderer1] [error] [File Watcher (parcel)] Unexpected error: Invalid handle (EUNKNOWN) (path: d:\ncs\v1.9.1\find-my)
[2022-04-01 16:11:54.128] [renderer1] [error] [File Watcher (universal)] restarting watcher after error: Invalid handle
[2022-04-01 16:11:54.319] [renderer1] [warning] [File Watcher (parcel)] ignoring a path for watching who's parent is already watched: d:\ncs\v1.9.1\test\cmock\vendor\unity
[2022-04-01 16:11:54.320] [renderer1] [error] [File Watcher (parcel)] Unexpected error: Invalid handle (EUNKNOWN) (path: d:\ncs\v1.9.1\find-my)
[2022-04-01 16:11:54.320] [renderer1] [error] [File Watcher (universal)] restarting watcher after error: Invalid handle
[2022-04-01 16:11:54.518] [renderer1] [warning] [File Watcher (parcel)] ignoring a path for watching who's parent is already watched: d:\ncs\v1.9.1\test\cmock\vendor\unity
[2022-04-01 16:11:54.518] [renderer1] [error] [File Watcher (parcel)] Unexpected error: Invalid handle (EUNKNOWN) (path: d:\ncs\v1.9.1\find-my)
[2022-04-01 16:11:54.519] [renderer1] [error] [File Watcher (universal)] restarting watcher after error: Invalid handle
[2022-04-01 16:11:54.701] [renderer1] [warning] [File Watcher (parcel)] ignoring a path for watching who's parent is already watched: d:\ncs\v1.9.1\test\cmock\vendor\unity
[2022-04-01 16:11:54.702] [renderer1] [error] [File Watcher (parcel)] Unexpected error: Invalid handle (EUNKNOWN) (path: d:\ncs\v1.9.1\find-my)
[2022-04-01 16:11:54.702] [renderer1] [error] [File Watcher (universal)] restarting watcher after error: Invalid handle
[2022-04-01 16:11:54.883] [renderer1] [warning] [File Watcher (parcel)] ignoring a path for watching who's parent is already watched: d:\ncs\v1.9.1\test\cmock\vendor\unity
[2022-04-01 16:11:54.884] [renderer1] [error] [File Watcher (parcel)] Unexpected error: Invalid handle (EUNKNOWN) (path: d:\ncs\v1.9.1\find-my)
[2022-04-01 16:11:54.885] [renderer1] [error] [File Watcher (universal)] gave up attempting to restart watcher after error: Invalid handle
[2022-04-01 16:11:54.886] [renderer1] [error] [File Watcher (parcel)] Unexpected error: Invalid handle (EUNKNOWN) (path: d:\ncs\v1.9.1\homekit)
[2022-04-01 16:11:54.886] [renderer1] [error] [File Watcher (universal)] gave up attempting to restart watcher after error: Invalid handle
[2022-04-01 16:11:54.887] [renderer1] [error] [File Watcher (parcel)] Unexpected error: Invalid handle (EUNKNOWN) (path: d:\ncs\v1.9.1\modules\lib\fff)
[2022-04-01 16:11:54.888] [renderer1] [error] [File Watcher (universal)] gave up attempting to restart watcher after error: Invalid handle
[2022-04-01 16:11:54.888] [renderer1] [error] [File Watcher (parcel)] Unexpected error: Invalid handle (EUNKNOWN) (path: d:\ncs\v1.9.1\nrf-802154)
[2022-04-01 16:11:54.889] [renderer1] [error] [File Watcher (universal)] gave up attempting to restart watcher after error: Invalid handle
Any help troubleshooting this is greatly appreciated!
