About twi_init function
I have to initialize a i2c multiplexer, for that I am sending the device address and register address to be written using the function:
nrf_drv_twi_tx(&m_twi, (0x70), tx_buf, sizeof(tx_buf), false);
Whenever I call this function, the flow is stuck inside a while block which checks m_xfer_done:
while (m_xfer_done == false) {}
Why the flow is stuck inside this loop?
I have initialized the twi master initialization as follows:
void twi_master_init(void)
    ret_code_t err_code;
    // Configure the settings for twi communication
    const nrf_drv_twi_config_t twi_config = {
       .scl                = TWI_SCL_M,  //SCL Pin
       .sda                = TWI_SDA_M,  //SDA Pin
       .frequency          = NRF_DRV_TWI_FREQ_400K, //Communication Speed
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH, //Interrupt Priority(Note: if using Bluetooth then select priority carefully)
       .clear_bus_init     = false //automatically clear bus
    //A function to initialize the twi communication
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
    //NRF_LOG_INFO("error code in twi init= %d", err_code);
    //Enable the TWI Communication
    nrf_drv_twi_enable(&m_twi);
    //NRF_LOG_INFO("twi is initialized");
Thanks
