Can't connect to nRF52840-DK with Python CHIP Controller
I have an issue in regard to Matter. I would like to commision a device in my network, but I don't know why the Python CHIP Controller returns this error every time I try to talk to the device:
chip-device-ctrl > connect -ble 3840 20202021
Device is assigned with nodeid = 171557
[1648823813.002918][34530:34536] CHIP:IN: Prepared unauthenticated message 0x7f808d8f4940 to 0x0000000000000000 (0) of type 0x20 and protocolId (0, 0) on exchange 28181i with MessageCounter:2474507507.
[1648823813.003042][34530:34536] CHIP:IN: Sending unauthenticated msg 0x7f808d8f4940 with MessageCounter:2474507507 to 0x0000000000000000 at monotonic time: 7839668 msec
[1648823813.003077][34530:34536] CHIP:CTL: Network commissioning parameters are required for BLE auto commissioning.
CHIP Error 0x0000002F: Invalid argument
chip-device-ctrl > [1648823813.019544][34530:34534] CHIP:BLE: BLE removing known devices.
[1648823813.024382][34530:34534] CHIP:BLE: BLE initiating scan.
[1648823813.340056][34530:34534] CHIP:BLE: Failed to start discovery: GDBus.Error:org.bluez.Error.InProgress: Operation already in progress
[1648823843.004362][34530:34536] CHIP:SC: PASESession timed out while waiting for a response from the peer. Expected message type was 33
Failed to establish secure session to device: 50
Segmentation fault (core dumped)
I followed the instructions from this video:
https://www.youtube.com/watch?v=kdMJQFDRoss
Has anyone encountered this same issue? Thanks!
  • Hi
    I couldn't make the CHIP Contoller work on the VM. Fortunately, I hav a spare nVidia Jetson NX laying around and I managed to run the controller on that (on ubuntu 20.04).
    However, after continuing with the webinar, I am not able to issue the command:
    zcl NetworkCommissioning AddThreadNetwork ....
    The error is the following:
    An exception occurred during process ZCL command:
    UnknownCommand: cluster: NetworkCommissioning, command: AddThreadNetwork
    Does anybody know what this is about?
  • Hi
    Try to use "AddOrUpdateThreadNetwork" instead.
    Does that change anything?
    Sigurd Hellesvik
  • Okay,
    So after I consulted the page https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/matter/python_chip_controller_building.html I have the following issues:
    1. After installing the CHIP controller when I try the BLE interface I get the following:
    sudo out/python_env/bin/chip-device-ctrl --bluetooth-adapter=hci2
    CHIP:DIS: Init admin pairing table with server storage.
    CHIP:IN: local node id is 0x000000000001b669
    CHIP:DL: MDNS failed to join multicast group on eth0 for address type IPv4: Inet Error 1016 (0x000003F8): Address not found
    CHIP:DL: MDNS failed to join multicast group on rndis0 for address type IPv4: Inet Error 1016 (0x000003F8): Address not found
    CHIP:DL: MDNS failed to join multicast group on usb0 for address type IPv4: Inet Error 1016 (0x000003F8): Address not found
    CHIP:ZCL: Using ZAP configuration...
    CHIP:ZCL: deactivate report event
    CHIP:CTL: Getting operational keys
    CHIP:CTL: Generating operational certificate for the controller
    CHIP:CTL: Getting root certificate for the controller from the issuer
    CHIP:CTL: Generating credentials
    CHIP:CTL: Loaded credentials successfully
    CHIP:DL: Platform main loop started.
    2022-05-25 17:29:25,177 ChipBLEMgr   INFO     adapter hci2 cannot be found, expect the ble mac address
      File "out/python_env/bin/chip-device-ctrl", line 789, in <module>
        main()
      File "out/python_env/bin/chip-device-ctrl", line 769, in main
        devMgrCmd = DeviceMgrCmd(rendezvousAddr=options.rendezvousAddr,
      File "out/python_env/bin/chip-device-ctrl", line 155, in __init__
        self.bleMgr.ble_adapter_select("hci{}".format(bluetoothAdapter))
      File "/home/iotlab/connectedhomeip/out/python_env/lib/python3.8/site-packages/chip/ChipBluezMgr.py", line 829, in ble_adapter_select
        self.adapter.adapter_register_signal()
    AttributeError: 'NoneType' object has no attribute 'adapter_register_signal'
    2. And so, I run the following command, which works:
    3. After that, when I try to set the previously obtained Active Operational Dataset I get:
    set-pairing-thread-credential 0e080000000000010000000300000f35060004001fffe0020811111111222222220708fde7466588be63af051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f010212340410445f2b5ca6f2a93a55ce570a70efeecb0c0402a0fff8
    Pairing Thread Credential is nolonger available, use NetworkCommissioning cluster instead.
    4. And finally, if I try to Commission the Matter accessory device over Bluetooth LE I get:
    connect -ble 3840 20202021 1234
    Device is assigned with nodeid = 1234
    CHIP:BLE: New device scanned: E9:1C:51:27:C0:68
    CHIP:BLE: Device discriminator match. Attempting to connect.
    CHIP:BLE: Scan complete notification without an active scan.
    CHIP:DL: Bluez notify CHIPoBluez connection disconnected
    CHIP:IN: Failed to establish BLE connection: Ble Error 6012 (0x0000177C): Remote device closed BLE connection
    CHIP:BLE: no endpoint for sub complete
    Failed to establish secure session to device: 4050
    CHIP:BLE: PASESession timed out while waiting for a response from the peer. Expected message type was 33
    CHIP Error 4050 (0x00000FD2): Timeout
  • Hi
    Do you get the same errors if you use the chip-device-ctrl installed from https://github.com/nrfconnect/sdk-connectedhomeip/releases/tag/v1.9.1?
    Sigurd Hellesvik
  • Hi
    Actually no, after installing it like this and going through the instructions available here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/matter/python_chip_controller_building.html (which you send it to me), I am able to connect to the device by ble and also send commands (turn the ligh bulb on/off), which is Step 6 from the link.
    However, at Step 7, when I try to get ProductName with the command " zclread Basic ProductName 1234 1 0 ", I receive the following error:
    chip-device-ctrl > zclread Basic ProductName 1234 1 0
    Using PASE connection
    [1654072284.640471][271108:271114] CHIP:IN: Prepared secure message 0x7f7a5fce18 to 0x00000000000004D2 (1)  of type 0x2 and protocolId (0, 1) on exchange 33810i with MessageCounter:2809441.
    [1654072284.640541][271108:271114] CHIP:IN: Sending encrypted msg 0x7f7a5fce18 with MessageCounter:2809441 to 0x00000000000004D2 (1) at monotonic time: 773705553 msec
    [1654072284.752556][271108:271114] CHIP:EM: Received message of type 0x5 with protocolId (0, 1) and MessageCounter:15675771 on exchange 33810i
    2022-06-01 10:31:24,753 root         ERROR    For path: Endpoint = 1, Attribute = <class 'chip.clusters.Objects.Basic.Attributes.ProductName'>, got IM Error: InteractionModelError: UnsupportedAttribute (0x86)
    AttributeReadResult(path=AttributePath(nodeId=1234, endpointId=1, clusterId=40, attributeId=3), status=0, value=ValueDecodeFailure(TLVValue=None, Reason=InteractionModelError(<Status.UnsupportedAttribute: 134>)))
    Now, I don't normally require this, I would like to commission the device to my thread network and after that, control it from a WiFi network... How can achieve this?
    Thank you,
    Mihnea Cristian Marin
  • Hi
    For step 7, try "zclread Basic ProductName 1234 0 0" instead. It seems that the documentation is wrong here, and the basic cluster is on endpoint 0, and not endpoint 1.
    When you use the zclread commands, the command goes through Wi-Fi from your PC to the Border Router and then to your Matter device over the Thread network.
    Do you want something else than this?
    Sigurd Hellesvik
    You were right, the command you sent me works. Also, I see your point on WiFi - Thread communication. However, from what I understand, I always require to use the CHIP controller to get info from the device, am I right?
