How to send a write response error as a peripheral?
I wrote a reply to a 5-year old question which appeared to be related to my needs but the answer was not what I was looking for.
The case is very straight forward:
The client writes a command on a control point, however, the client has not yet enabled the control point to receive indications.
Consequently, I would like to respond to the BLE_GATTS_EVT_WRITE event with an error. I was hoping for some SoftDevice method like sd_gatts_write_rsp(_) where I could set the error code the client is to receive since I cannot indicate an error message on the control point.
The message sequence diagrams show how I can edit/modify/block a write request from entering crap into my service tables database, but there is no way that I have found to send a reply to the client. I have worked on other libraries where I could do this, in fact I was responsible for setting all the responses to write requests. Maybe SoftDevice is just trying to simplify my life by handling all responses under the hood; implicitly assuming it can handle all possible needs.
I think the error code I want to respond with is 0xFD (Client Characteristic Configuration Descriptor Improperly Configured).
How can I do this (I do not see how the write with authentication option SoftDevice provides helps). There is still no control over the response to the client in that case. I do use that option to control what gets read and could use it to control what gets written. It's not what I need here.
As an aside there is a button to the right with that toggles between 'turn notifications on' or 'turn notifications off'. It is not clear what the state of notifications are given the text displayed. If I see 'off' I am assuming notifications are on and vice versa. It would be clearer with 'notifications are now on' and 'notifications are now off' as the toggle options.
    The only case where you can specify the response yourself is when responding to a Write Request with Authorization (as shown in this MCS). You can see an some examples of this in the SDK, for instance in <SDK 17.1.0>\examples\peripheral\usbd_ble_uart_freertos\main.c, around line 515:
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
  • Cool! This is what I was looking for::
    sd_ble_gatts_rw_authorize_reply(....)
    But I did not find the 'reply' option in the sequence diagrams and did not catch it in the list of sd methods. But I will have to shift my writes to rw authorize. (I already do that for reads.)
    !! I have further questions: !!
    This is a control point. When I configure the characteristic for authorized read/writes does that include writing to the CCCD of the characteristic or just when writing to the characteristic itself?
    When I write to the characteristic it is just a command for the server to do something. Do I need to do a reply in that case?
    The only time I want to return an error code to the client is if the client writes a command and has not enabled the CCCD. In that case is the code below sufficient?
    So the only thing I need to enter in the reply is the status code?
        ble_gatts_rw_authorize_reply_params_t reply;
        //reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
        reply.params.write.gatt_status = BLE_GATT_STATUS_ATTERR_CPS_CCCD_CONFIG_ERROR;
        sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.common_evt.conn_handle, &reply);
