Our aim is to install "pc-ble-driver-js" and use the connectivity board for the serialization process.
We are following this link to get this working https://github.com/NordicSemiconductor/pc-ble-driver-js
After executing the first step( i.e command "npm install pc-ble-driver-js") we are facing the following errors and warning
The node version is v16.14.2
The npm version is 8.5.0
C:\Users\info>npm install pc-ble-driver-js npm WARN deprecated [email protected]: this library is no longer supported npm WARN deprecated [email protected]: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm WARN deprecated [email protected]: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated [email protected]: This version of tar is no longer supported, and will not receive security updates. Please upgrade asap. npm WARN deprecated [email protected]: This version of tar is no longer supported, and will not receive security updates. Please upgrade asap. npm ERR! code 1 npm ERR! path C:\Users\info\node_modules\pc-ble-driver-js npm ERR! command failed npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node do_prebuild.js --decompress-only || node do_prebuild.js --install-only || node do_prebuild.js npm ERR! options.shared_install_dir:C:\Users\info\node_modules\pc-ble-driver-js\Release npm ERR! options.shared_install_dir:C:\Users\info\node_modules\pc-ble-driver-js\Release npm ERR! options.shared_install_dir:C:\Users\info\node_modules\pc-ble-driver-js\Release npm ERR! C:\Users\info\node_modules\pc-ble-driver-js\do_prebuild.js:219 npm ERR! throw new Error("npm_config_runtime needs to be specified"); npm ERR! ^ npm ERR! npm ERR! Error: npm_config_runtime needs to be specified npm ERR! at Object.<anonymous> (C:\Users\info\node_modules\pc-ble-driver-js\do_prebuild.js:219:11) npm ERR! at Module._compile (node:internal/modules/cjs/loader:1103:14) npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10) npm ERR! at Module.load (node:internal/modules/cjs/loader:981:32) npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:822:12) npm ERR! at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) npm ERR! at node:internal/main/run_main_module:17:47 npm ERR! C:\Users\info\node_modules\pc-ble-driver-js\do_prebuild.js:219 npm ERR! throw new Error("npm_config_runtime needs to be specified"); npm ERR! ^ npm ERR! npm ERR! Error: npm_config_runtime needs to be specified npm ERR! at Object.<anonymous> (C:\Users\info\node_modules\pc-ble-driver-js\do_prebuild.js:219:11) npm ERR! at Module._compile (node:internal/modules/cjs/loader:1103:14) npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10) npm ERR! at Module.load (node:internal/modules/cjs/loader:981:32) npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:822:12) npm ERR! at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) npm ERR! at node:internal/main/run_main_module:17:47 npm ERR! C:\Users\info\node_modules\pc-ble-driver-js\do_prebuild.js:219 npm ERR! throw new Error("npm_config_runtime needs to be specified"); npm ERR! ^ npm ERR! npm ERR! Error: npm_config_runtime needs to be specified npm ERR! at Object.<anonymous> (C:\Users\info\node_modules\pc-ble-driver-js\do_prebuild.js:219:11) npm ERR! at Module._compile (node:internal/modules/cjs/loader:1103:14) npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10) npm ERR! at Module.load (node:internal/modules/cjs/loader:981:32) npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:822:12) npm ERR! at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12) npm ERR! at node:internal/main/run_main_module:17:47 npm ERR! A complete log of this run can be found in: npm ERR! C:\Users\info\AppData\Local\npm-cache\_logs\2022-04-04T07_47_24_455Z-debug-0.log C:\Users\info>
Please let us know why we are facing these errors.
Sakib
