CMake script for add eternal libaray ( BSEC ) to test Bosch sensor raeding?
hello,
i have downloaded    ( BSEC )    library from https://www.bosch-sensortec.com/software-tools/software/bsec/  for read sensor data . now want to test the code by build and flashing it with VS code for thingy 91 borad.
CMamke  file have
FILE(GLOB bsec_integration src/*.c)
target_sources(app PRIVATE src/bsec_integration.c)
target_sources(app PRIVATE src/bme680.c)
i have add c file and header file in scr folder .
on build shows error
FATAL ERROR: command exited with status 1: 'c:\Users\mohit\ncs\v1.9.1\toolchain\opt\bin\cmake.EXE' '-DWEST_PYTHON=c:\Users\mohit\ncs\v1.9.1\toolchain\opt\bin\python.exe' '-Be:\Nordic_Acadmey\bsec_integration\build_1' '-Se:\Nordic_Acadmey\bsec_integration' -GNinja -DBOARD=thingy91_nrf9160 -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING=NONE.
please suggest
  • sir i  have already share the link for download BSEC library . want to compile example file for testing bosch sensor.  https://www.bosch-sensortec.com/software-tools/software/bsec/
     * Copyright (C) 2017 Robert Bosch. All Rights Reserved.
     * Disclaimer
     * Common:
     * Bosch Sensortec products are developed for the consumer goods industry. They may only be used
     * within the parameters of the respective valid product data sheet.  Bosch Sensortec products are
     * provided with the express understanding that there is no warranty of fitness for a particular purpose.
     * They are not fit for use in life-sustaining, safety or security sensitive systems or any system or device
     * that may lead to bodily harm or property damage if the system or device malfunctions. In addition,
     * Bosch Sensortec products are not fit for use in products which interact with motor vehicle systems.
     * The resale and/or use of products are at the purchasers own risk and his own responsibility. The
     * examination of fitness for the intended use is the sole responsibility of the Purchaser.
     * The purchaser shall indemnify Bosch Sensortec from all third party claims, including any claims for
     * incidental, or consequential damages, arising from any product use not covered by the parameters of
     * the respective valid product data sheet or not approved by Bosch Sensortec and reimburse Bosch
     * Sensortec for all costs in connection with such claims.
     * The purchaser must monitor the market for the purchased products, particularly with regard to
     * product safety and inform Bosch Sensortec without delay of all security relevant incidents.
     * Engineering Samples are marked with an asterisk (*) or (e). Samples may vary from the valid
     * technical specifications of the product series. They are therefore not intended or fit for resale to third
     * parties or for use in end products. Their sole purpose is internal client testing. The testing of an
     * engineering sample may in no way replace the testing of a product series. Bosch Sensortec
     * assumes no liability for the use of engineering samples. By accepting the engineering samples, the
     * Purchaser agrees to indemnify Bosch Sensortec from all claims arising from the use of engineering
     * samples.
     * Special:
     * This software module (hereinafter called "Software") and any information on application-sheets
     * (hereinafter called "Information") is provided free of charge for the sole purpose to support your
     * application work. The Software and Information is subject to the following terms and conditions:
     * The Software is specifically designed for the exclusive use for Bosch Sensortec products by
     * personnel who have special experience and training. Do not use this Software if you do not have the
     * proper experience or training.
     * This Software package is provided `` as is `` and without any expressed or implied warranties,
     * including without limitation, the implied warranties of merchantability and fitness for a particular
     * purpose.
     * Bosch Sensortec and their representatives and agents deny any liability for the functional impairment
     * of this Software in terms of fitness, performance and safety. Bosch Sensortec and their
     * representatives and agents shall not be liable for any direct or indirect damages or injury, except as
     * otherwise stipulated in mandatory applicable law.
     * The Information provided is believed to be accurate and reliable. Bosch Sensortec assumes no
     * responsibility for the consequences of use of such Information nor for any infringement of patents or
     * other rights of third parties which may result from its use. No license is granted by implication or
     * otherwise under any patent or patent rights of Bosch. Specifications mentioned in the Information are
     * subject to change without notice.
     * It is not allowed to deliver the source code of the Software to any third party without permission of
     * Bosch Sensortec.
     * @file bsec_iot_example.c
     * @brief
     * Example for using of BSEC library in a fixed configuration with the BME680 sensor.
     * This works by running an endless loop in the bsec_iot_loop() function.
     * @addtogroup bsec_examples BSEC Examples
     * @brief BSEC usage examples
    /* header files */
    #include "bsec_integration.h"
    #include <zephyr.h>
    #include <sys/printk.h>
    /* functions */
     * @brief           Write operation in either I2C or SPI
     * param[in]        dev_addr        I2C or SPI device address
     * param[in]        reg_addr        register address
     * param[in]        reg_data_ptr    pointer to the data to be written
     * param[in]        data_len        number of bytes to be written
     * @return          result of the bus communication function
    int8_t bus_write(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data_ptr, uint16_t data_len)
        // Please insert system specific function to write to the bus where BME680 is connected
        return 0;
     * @brief           Read operation in either I2C or SPI
     * param[out]       reg_data_ptr    pointer to the memory to be used to store the read data
     * param[in]        data_len        number of bytes to be read
    int8_t bus_read(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data_ptr, uint16_t data_len)
        // Please insert system specific function to read from bus where BME680 is connected
        return 0;
     * @brief           System specific implementation of sleep function
     * @param[in]       t_ms    time in milliseconds
     * @return          none
    void sleep(uint32_t t_ms)
        // Please insert system specific function sleep or delay for t_ms milliseconds
     * @brief           Capture the system time in microseconds
     * @return          system_current_time    current system timestamp in microseconds
    int64_t get_timestamp_us()
        int64_t system_current_time = 0;
        // Please insert system specific function to retrieve a timestamp (in microseconds)
        return system_current_time;
     * @brief           Handling of the ready outputs
     * @param[in]       timestamp       time in nanoseconds
     * @param[in]       iaq             IAQ signal
     * @param[in]       iaq_accuracy    accuracy of IAQ signal
     * @param[in]       temperature     temperature signal
     * @param[in]       humidity        humidity signal
     * @param[in]       pressure        pressure signal
     * @param[in]       raw_temperature raw temperature signal
     * @param[in]       raw_humidity    raw humidity signal
     * @param[in]       gas             raw gas sensor signal
     * @param[in]       bsec_status     value returned by the bsec_do_steps() call
     * @return          none
    void output_ready(int64_t timestamp, float iaq, uint8_t iaq_accuracy, float temperature, float humidity,
         float pressure, float raw_temperature, float raw_humidity, float gas, bsec_library_return_t bsec_status,
         float static_iaq, float co2_equivalent, float breath_voc_equivalent)
        // Please insert system specific code to further process or display the BSEC outputs
     * @brief           Load previous library state from non-volatile memory
     * @param[in,out]   state_buffer    buffer to hold the loaded state string
     * @param[in]       n_buffer        size of the allocated state buffer
     * @return          number of bytes copied to state_buffer
    uint32_t state_load(uint8_t *state_buffer, uint32_t n_buffer)
        // Load a previous library state from non-volatile memory, if available.
        // Return zero if loading was unsuccessful or no state was available,
        // otherwise return length of loaded state string.
        return 0;
     * @brief           Save library state to non-volatile memory
     * @param[in]       state_buffer    buffer holding the state to be stored
     * @param[in]       length          length of the state string to be stored
     * @return          none
    void state_save(const uint8_t *state_buffer, uint32_t length)
        // Save the string some form of non-volatile memory, if possible.
     * @brief           Load library config from non-volatile memory
     * @param[in,out]   config_buffer    buffer to hold the loaded state string
     * @return          number of bytes copied to config_buffer
    uint32_t config_load(uint8_t *config_buffer, uint32_t n_buffer)
        // Load a library config from non-volatile memory, if available.
        // Return zero if loading was unsuccessful or no config was available,
        // otherwise return length of loaded config string.
        return 0;
     * @brief       Main function which configures BSEC library and then reads and processes the data from sensor based
     *              on timer ticks
     * @return      result of the processing
    int main()
        return_values_init ret;
        printk("welcome! %s\n", CONFIG_BOARD);
        /* Call to the function which initializes the BSEC library
         * Switch on low-power mode and provide no temperature offset */
        ret = bsec_iot_init(BSEC_SAMPLE_RATE_LP, 0.0f, bus_write, bus_read, sleep, state_load, config_load);
        if (ret.bme680_status)
            /* Could not intialize BME680 */
            return (int)ret.bme680_status;
        else if (ret.bsec_status)
            /* Could not intialize BSEC library */
            return (int)ret.bsec_status;
        /* Call to endless loop function which reads and processes data based on sensor settings */
        /* State is saved every 10.000 samples, which means every 10.000 * 3 secs = 500 minutes  */
        bsec_iot_loop(sleep, get_timestamp_us, output_ready, state_save, 10000);
        return 0;
    Main code '
    Link for download BSEC library and sample code https://www.bosch-sensortec.com/software-tools/software/bsec/
    CMake code
    cmake_minimum_required(VERSION 3.20.0)
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(hello_world)
    set(CONFIG_EXTERNAL_SENSORS_BME680_BSEC_PATH nrf\v1.9.1\nrf\ext\BSEC_1.4.8.0_Generic_Release_updated_v3)
    target_sources(app PRIVATE src/main.c)
    Sorry for the late reply. We have had a public Holiday in Norway. Can you please zip the project that you are trying to compile and upload it here, then I can navigate it and see if I can find out what's missing?
    Edvin
  • sir, try to upload zip file but , i don't know how to upload zip file on chat? please help
