Update API key via API
is there a way to update the API key needed to get sensor data?
I got a thingy91 that I can get data from via Rest API. Only thing is that I need to login to my profile and get the new API key. Is there a link where I can do a GET request to update it in my Node-RED project?
best regards,
Sondre
  • Hi Sondre,
    I am not sure if I understand your meaning.
    Why do you need a new API key? When you generate one API key, you can use it for all your third-party platforms to access nrfcloud through REST API. In which condition, do you need to generate a new one?
    No, a new API key shouldn't be requested through REST API itself. It is a high risk any people using this API can request a new key and block your access.
    Charlie
  • The thing is that the API key is only available for 1 hour, correct? So I would need to manually login and update the API key, then copy it into my project..?
  • Hi Sondre,
    NO.
    warning Note that previously issued API keys remain valid for up to 60 minutes. means:
    After generating a new key, your old key may still be valid for 1 hour. You can simply keep monitoring your API key for more than one hour to see if it changes.
    Charlie
