nrf9160 DTLS Certificates with Native Sockets
I am trying to implement a simple UDP client on the nrf9160 using DTLS Certificate authentication.
I understand that the modem only supports PSK. However, I am trying to implement this with using Native Sockets using the SOCK_NATIVE_TLS flag.
data->udp.sock = socket(addr->sa_family, SOCK_DGRAM| SOCK_NATIVE_TLS , IPPROTO_DTLS_1_2 );
I can get the the echo_client DTLS to work with a native_posix board to a dtls_server test application.
But with the nrf9160, something gets lost in the handshaking.
Should DTLS with certificates work using native sockets?
I have tried a nrf9160 DK board as well as a Thingy91.
I have tried nRF Connect SDK versions 1.7, 1.9.1, and 1.9.9
    Did you try with our samples that support DTLS, e.g. nRF9160: HTTPS client sample (nrf\samples\nrf9160\https_client\)
    What modem version are you running on your board? Have you verified that you are not seeing the TLS/DTLS limitation, from the mfw_1.3.1 release notes:
    - TLS/DTLS
        - Up to three simultaneous TLS/DTLS connections are possible.
        - Maximum server certificate chain size has a limit of 4kB.
        - Server certificate expiry time is not verified.
        - pkcs#8 is not supported.
        - Absolute maximum number of supported credentials is 32. The actual amount depends on size of
          credentials as memory area reserved for credentials may be a limiting factor as well.
        - DTLS supports PSK authentication only.
        - 2kB secure socket buffer size.
    We will need a modem trace in order to see what is failing.
    Øyvind
