Configuration UARTE with nrf52805 for ESB - Part 2
My previous ticket is closed. I would need, but still help with the configuration of the pins. I report my last post.
I did some tests with the oscilloscope directly connected to pins 21 and 18 of the nrf52805.
The transmission on pin 18 by the Stm8l works perfectly. The problem I encounter now is that nrf52805 I have the pull up instruction on this pin
 nrf_gpio_cfg_input(PIN_RXD,GPIO_PIN_CNF_PULL_Pullup);
but nothing happens when oscilloscopes.
It could be that I get the pin definition wrong initially
 #define UARTE_BASE           0x40002000
  #define PORTA_UARTE          ((NRF_UARTE_Type *) UARTE_BASE )
  #define PIN_TXD            21
  #define PIN_RXD            18
or the pull up configuration of pin 18, set as input and pin 21 as output?
     nrf_gpio_cfg_output(PIN_TXD);
  • I need some help figuring out what's wrong with my code.
    With the oscilloscope test I see that my master (STM8l) communicates the value (in the test I used 0xF3) through UARTE on pin 18 of the nrf52805 (connected in slave mode), but if I read the value to which the buffer points is not the data that I send rather they are values that change randomly.
    nrf_uarte_baudrate_set(PORTA_UARTE, NRF_UARTE_BAUDRATE_115200);
    nrf_uarte_txrx_pins_set(PORTA_UARTE, PORTA_TXD, PORTA_RXD);
    nrf_uarte_configure(PORTA_UARTE, NRF_UARTE_PARITY_EXCLUDED, NRF_UARTE_HWFC_DISABLED);
    nrf_uarte_enable(PORTA_UARTE);
    nrf_uarte_rx_buffer_set(PORTA_UARTE,rx_buffer,1);
    if (nrf_uarte_event_check(PORTA_UARTE, NRF_UARTE_EVENT_RXSTARTED))
            if (nrf_uarte_event_check(PORTA_UARTE, NRF_UARTE_EVENT_RXDRDY))
                dato_uarte=*rx_buffer;
            if (nrf_uarte_event_check(PORTA_UARTE, NRF_UARTE_EVENT_ENDRX))
                nrf_uarte_task_trigger(PORTA_UARTE,NRF_UARTE_TASK_STOPRX);
                nrf_uarte_task_trigger(PORTA_UARTE,NRF_UARTE_TASK_FLUSHRX);
                nrf_uarte_task_trigger(PORTA_UARTE,NRF_UARTE_TASK_STARTRX);
  • for completeness of information I also put back the definition of the pins and the declarations of input and output pins.
      #define PORTA_TXD            21
      #define PORTA_RXD            18
     nrf_gpio_cfg_input(PORTA_RXD,NRF_GPIO_PIN_PULLUP);
     nrf_gpio_cfg_output(PORTA_TXD);
    These statements already return something strange, as declaring pin 18 as input and configuring the pullup, the latter does not give visible results to the oscilloscope.
  • Do you have simple uart example that you use for testing this? If yes, could you upload your example project?
  • No, I used the ESB example and I used the library function nrf_uarte
