I am using the MX25R64 NOR Flash chip on my own PCB with the nRF9160 package. With the help of this thread I have managed to get the NVS library to work with it. I don't necessarily have a problem to solve, but I would like to understand a few things because to be honest I'm quite confused as to how this is working.
Firstly, here is a segment from the overlay file.
&spi1 {
status = "okay";
sck-pin = < 2 >;
mosi-pin = < 3 >;
miso-pin = < 4 >;
label = "SPI_1";
cs-gpios = < &gpio0 1 GPIO_ACTIVE_LOW >;
mx25r64: mx25r6435f@0 {
compatible = "jedec,spi-nor";
reg = < 0x0 >;
spi-max-frequency = < 8000000 >;
label = "MX25R64";
jedec-id = [ C2 28 17 ];
size = < 0x4000000 >;
has-dpd;
t-enter-dpd = < 0x2710 >;
t-exit-dpd = < 0x88b8 >;
partitions {
#address-cells = < 0x1 >;
#size-cells = < 0x1 >;
lfs1_part: partition@0 {
label = "ext_storage";
reg = < 0x0 0x10000 >;
phandle = < 0x5 >;
Here are the relevant macros in the conf file
CONFIG_SPI=y CONFIG_SPI_NOR=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_PM_EXTERNAL_FLASH=y CONFIG_PM_EXTERNAL_FLASH_DEV_NAME="MX25R64" CONFIG_PM_EXTERNAL_FLASH_BASE=0x0 CONFIG_SPI_NOR_IDLE_IN_DPD=y CONFIG_PM_EXTERNAL_FLASH_SIZE=0x4000000
And this is what I am doing in main to initalise the flash (This was originally linked to the internal flash storage so I basically just changed the first line and the sector size/count)
flash_dev = DEVICE_DT_GET(DT_N_NODELABEL_mx25r64);
if (!device_is_ready(flash_dev)){
printk("Internal Flash ERROR");
fs.offset = 0x00;
err = flash_get_page_info_by_offs(flash_dev, fs.offset, &info);
if (err) {
printk("Unable to get page info...");
fs.sector_size = 32768;
fs.sector_count = 256;
err = nvs_init(&fs, flash_dev->name);
if (err) {
printk("Internal Flash Initialisation Failed");
else{
printk("Internal Flash Initialisation Passed");
After this I can use nvs libraries to read and write to the flash - great!
What I cannot understand though...
1. Do all SPI NOR Flash chips have the same protocol to read and write? (By protocol I don't mean SPI - I mean the command set that you send over SPI to read/write)
If so, does that mean to use a different SPI NOR chip, you would just have to change the JEDEC ID in the overlay?
Or if not, where is the driver that is allowing me to read and write to the MX25R64, and how was it invoked from the overlay?
2. What is happening when I write an 8 byte array to the flash using nvs_write() ?
From my understanding, the minimum amount of data that can be written to flash is one "page" which the smallest page size I can define is 4096 bytes, so if I write 8 bytes, am I actually writing 8 bytes (+8 bytes header that NVS uses) followed by 4080 NULL bytes to write one page? If so, then the second time I write, am I copying the page, adding a further 8 bytes and writing over the same page?
This is important as I am aware of flash ware, and I don't want to rewrite over the same page 256 times (in this example setup) when I could store that data in RAM until I have filled a page worth of data.
Damien
