I'm using a nrf52832 and NCS 1.9.0 and I would like to be able to use SMP to make firmware updates using BLE. I'm was able to perform FOTA, but the flash is divided by two because I'm using MCUBoot and my app would require more.
I saw in the documentation here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.0/nrf/ug_bootloader.html#mcuboot-partitions that it is possible to use only the primary slot using CONFIG_SINGLE_APPLICATION_SLOT parameter. I tried adding this parameter in my prj.conf, but I'm getting the following error:
warning: attempt to assign the value 'y' to the undefined symbol SINGLE_APPLICATION_SLOT
Is there any way I can write an application that I can update by BLE and having access to full flash using MCUBoot? Currently, I don't have an external flash on my board.
Alexandre
