Troubleshooting HF clock that is not starting
I am troubleshooting a board with no working RF. On looking deeper it appears that the HFCLK is not starting (NRF_CLOCK->EVENTS_HFCLKSTARTED is never set).
This is on a PCB that was working previously. I want to troubleshoot it deeper to see if it's a
* Soldering issue
* Component issue (capacitors or crystal)
* ESD issue
If I assume the crystal is not working, what is the expected behaviour of the XC1 and XC2 pins on a nRF52840 when the HFCLK is started by setting NRF_CLOCK->TASKS_HFCLKSTART
Does one of these pins get driven high? If so which one?
Is there a way to tell if the nRF52840 XC1/XC2 pins have become unsoldered. I was thinking that I could do a diode check between XC1/XC2 and VCC and GND on the assumption there are ESD protection diodes on these pins. Would that work? Which power rail should I use for this check? VDD, VDDH, or one of the DEC pins?
    What do you see if you probe the XC2 and XC1 lines, do you see a oscillating signal? Could you provide the full part number and datasheet of the crystal that you're using? And also provide the size of the parallel load capacitors?
    regards
    Jared
  • This is what I see if I probe XC1 and XC2 when the firmware does NRF_CLOCK->TASKS_HFCLKSTART = 1
    Trace 1 (Yellow): XC1
    Trace 2 (Blue): XC2
    mark.blackburn.orpyx said:
    Should I suspect that something is wrong with the crystal, capacitor or their soldering? Or could something be wrong with the XC2 pin on the IC?
    I would suspect either the crystal or the soldering. Have you tried changing the crystal on the PCB?
    Yes, the load capacitance of the crystal is 10 pF
    There are 2 12 pF load capacitors connected to the XC1 and XC2 pins and to ground.
    Then the crystal isn't properly loaded. The parallel load capacitors should be 16 pF if the internal load capacitance is 10 pF. However, I don't think this is the culprit in your case. But it would be good to change them to the correct size later.
    regards
    Jared
    What percentage of samples produced is affected by this? Could you try changing the IC from a working sample to a non-working sample and see if it fixes the problem? It could help us understand what's causing this.
    regards
    Jared
  • > What percentage of samples produced is affected by this?
    We haven't characterized are failures to this detail yet. There may be other failures like this but I haven't confirmed. We have other units where the radio (BLE) is not working, but haven't confirmed if the crystal oscillator is the cause. Do you have an idea how often this might occur?
    I don't have that capability without taking the board to our contract manufacturer. I'll perhaps reassess if we think this is occurring often enough to do that work.
  • Hi Mark,
    This isn't a common problem so I don't really have any numbers on this, and I'm still not sure if the problem is the IC itself. Have you tried changing the load capacitors for the other units that doesn't work?
    Ok.
    regards
    Jared
  • Hi Mark,
    Ok.
    regards
    Jared
