Troubleshooting HF clock that is not starting
I am troubleshooting a board with no working RF. On looking deeper it appears that the HFCLK is not starting (NRF_CLOCK->EVENTS_HFCLKSTARTED is never set).
This is on a PCB that was working previously. I want to troubleshoot it deeper to see if it's a
* Soldering issue
* Component issue (capacitors or crystal)
* ESD issue
If I assume the crystal is not working, what is the expected behaviour of the XC1 and XC2 pins on a nRF52840 when the HFCLK is started by setting NRF_CLOCK->TASKS_HFCLKSTART
Does one of these pins get driven high? If so which one?
Is there a way to tell if the nRF52840 XC1/XC2 pins have become unsoldered. I was thinking that I could do a diode check between XC1/XC2 and VCC and GND on the assumption there are ESD protection diodes on these pins. Would that work? Which power rail should I use for this check? VDD, VDDH, or one of the DEC pins?
  • Hi Mark,
    mark.blackburn.orpyx said:
    We haven't characterized are failures to this detail yet. There may be other failures like this but I haven't confirmed. We have other units where the radio (BLE) is not working, but haven't confirmed if the crystal oscillator is the cause. Do you have an idea how often this might occur?
    This isn't a common problem so I don't really have any numbers on this, and I'm still not sure if the problem is the IC itself. Have you tried changing the load capacitors for the other units that doesn't work?
    I don't have that capability without taking the board to our contract manufacturer. I'll perhaps reassess if we think this is occurring often enough to do that work.
    Ok.
    regards
    Jared
