Blinky does not work after OTA Firmware update
I am following the step by step tutorial "Getting Started with Secure DFU Bootloader Step by Step guide"
Before following the above guide I compiled  ble_app_blinky from the examples/ble_peripheral folder of NRF52 SDK Ver 17.0.2
The above example was tested successfully on NRF52-DK along with NRF Blinky App running on an Android phone. Everything worked well.
I then followed the guide to create:
1. Secure bootloader (Steps A, B in the guide)
2. Created the application ZIP file (Step C)
3. Performed DFU using NRF Connect for mobile (Steps D1 to D3)
STEP D4 (Testing the Application after DFU)  - failed - Most of the time I could not see the BLE Device name in NRF Blinky App. Once I did see the BLE Device name "Nordic_Blinky" but it would not connect. Once it did connect and I was even able to switch on the LED but after that it seemed the program froze - there were no responses to LED on/off on Blinky App nor was there any response to BUTTON press on the NRF52-DK.
I failed to understand what is it that I am doing that is breaking the Application!
Any help in this regard would be helpful.
    Could you please provide more information about these transitions (cannot see the device -> can see the device, cannot connect -> can connect)?
    When did they occur? Did you do anything to enable these transitions?
    Dejan
  • Hi Dejan,
    I restarted fresh as I had modified the code with some debug line in blink's main.c and was not sure if did something wrong.
    Here is what I mean by restarted:
    PART 1 - blinky app as is
    1. Downloaded NRF52 SDK 17.0.2
    2. Recompiled ble_app_blinky  available in the examples/ble_peripheral folder
    3. Tested the app on NRF52-DK using. both Android and iOS nrf blinky app. Everything worked consistently - i.e. LED on/of as well as BUTTON press/release.
    PART 2 - blinky app - transferred using SECURE DFU
    Next step was to do the secure DFU OTA.
    1. Created the secure bootloader hex file by following steps in the guide (Steps B1a,B2,B3)
    2. Generated DFU package (.zip file) as in step C of guide
     nrfutil pkg generate --hw-version 52 --sd-req 0x0101 --application-version 0 --application ble_app_blinky_new.hex --key-file ../private.pem blinky_new.zip
    3. Created Bootloader Settings file
    nrfutil settings generate --family NRF52 --application ble_app_blink_new.hex --application-version 0 --bootloader-version 0 --bl-settings-version 2 boot_loader_setting.hex
    4. Flashed SoftDevice and Secure Bootloader and Bootloader Settings file
    ## Flash SD
    nrfjprog --family nRF52 --verify --program s132_nrf52_7.2.0_softdevice.hex --sectorerase
    echo ... Softdevice flashed
    echo ----------------------
    ## Flash BOOTLOADER
    nrfjprog --family nRF52 --verify --program secure_bootloader_ble_s132_pca10040_debug_mar22.hex --sectorerase
    echo ... Secure Bootloader flashed
    ## Flast Settings
    nrfjprog --family nRF52 --verify --program boot_loader_setting.hex --sectorerase
    5. Restarted NRF52 DK (power off/on)
    6. Using iOS app nRF Connect connected to NRF52 DK  (device named  "DfuTarg" ) and did DFU over the air using the package generated in step 2 of PART 2.
    Logfile of secure DFU attached
    File Name: blinky_new.zip
    Parts: 1
    Soft Device Size: Zero KB
    Bootloader Size: Zero KB
    Connecting to DfuTarg...
    Connected to DfuTarg
    Discovering services...
    Services discovered
    Starting Secure DFU...
    Services discovered
    Secure DFU Service found
    Discovering characteristics in DFU Service...
    DFU characteristics discovered
    MTU set to 247
    Enabling notifications for 8EC90001-F315-4F60-9FB8-838830DAEA50...
    Notifications enabled for 8EC90001-F315-4F60-9FB8-838830DAEA50
    Secure DFU Control Point notifications enabled
    Writing to characteristic 8EC90001-F315-4F60-9FB8-838830DAEA50...
    Data written to 8EC90001-F315-4F60-9FB8-838830DAEA50
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600601000200000000000000000000
    Command object selected (Max size = 512, Offset = 0, CRC = 00000000) received
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600101
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600201
    Packet Receipt Notif disabled (Op Code = 2, Value = 0)
    Writing to characteristic 8EC90002-F315-4F60-9FB8-838830DAEA50...
    Command object sent (CRC = 835828DA)
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003018d000000da285883
    Checksum (Offset = 141, CRC = 835828DA) received
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600401
    Command object executed
    Packet Receipt Notif enabled (Op Code = 2, Value = 12)
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600601001000000000000000000000
    Data object selected (Max size = 4096, Offset = 0, CRC = 00000000) received
    Data object 1/43 created
    Uploading firmware...
    Sending firmware to DFU Packet characteristic...
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100100000bbdf12c5
    Checksum (Offset = 4096, CRC = C512DFBB) received
    Data object executed
    Data object 2/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301002000000d68113f
    Checksum (Offset = 8192, CRC = 3F11680D) received
    Data object 3/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100300000a422b687
    Checksum (Offset = 12288, CRC = 87B622A4) received
    Data object 4/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301004000003c303cb7
    Checksum (Offset = 16384, CRC = B73C303C) received
    Data object 5/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100500000e6fd0f92
    Checksum (Offset = 20480, CRC = 920FFDE6) received
    Data object 6/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100600000e4e87bfd
    Checksum (Offset = 24576, CRC = FD7BE8E4) received
    Data object 7/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301007000000ca51b99
    Checksum (Offset = 28672, CRC = 991BA50C) received
    Data object 8/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100800000451b28e8
    Checksum (Offset = 32768, CRC = E8281B45) received
    Data object 9/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003010090000087e964f1
    Checksum (Offset = 36864, CRC = F164E987) received
    Data object 10/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100a0000071ce20dc
    Checksum (Offset = 40960, CRC = DC20CE71) received
    Data object 11/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100b0000011b98140
    Checksum (Offset = 45056, CRC = 4081B911) received
    Data object 12/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100c00000a7b5c703
    Checksum (Offset = 49152, CRC = 03C7B5A7) received
    Data object 13/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100d00000d9fe6053
    Checksum (Offset = 53248, CRC = 5360FED9) received
    Data object 14/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100e00000fb10f5ea
    Checksum (Offset = 57344, CRC = EAF510FB) received
    Data object 15/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100f00000ce43757b
    Checksum (Offset = 61440, CRC = 7B7543CE) received
    Data object 16/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100000100aa9ce51f
    Checksum (Offset = 65536, CRC = 1FE59CAA) received
    Data object 17/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301001001006a80d9e4
    Checksum (Offset = 69632, CRC = E4D9806A) received
    Data object 18/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100200100389fd759
    Checksum (Offset = 73728, CRC = 59D79F38) received
    Data object 19/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301003001000cc9c4ca
    Checksum (Offset = 77824, CRC = CAC4C90C) received
    Data object 20/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100400100ad4cf12f
    Checksum (Offset = 81920, CRC = 2FF14CAD) received
    Data object 21/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100500100e712da51
    Checksum (Offset = 86016, CRC = 51DA12E7) received
    Data object 22/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003010060010054094e37
    Checksum (Offset = 90112, CRC = 374E0954) received
    Data object 23/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003010070010006c4da00
    Checksum (Offset = 94208, CRC = 00DAC406) received
    Data object 24/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100800100c8a22ef3
    Checksum (Offset = 98304, CRC = F32EA2C8) received
    Data object 25/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301009001001f5e799c
    Checksum (Offset = 102400, CRC = 9C795E1F) received
    Data object 26/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100a00100190e6662
    Checksum (Offset = 106496, CRC = 62660E19) received
    Data object 27/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100b0010058be3a50
    Checksum (Offset = 110592, CRC = 503ABE58) received
    Data object 28/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100c0010040dd3c82
    Checksum (Offset = 114688, CRC = 823CDD40) received
    Data object 29/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100d001000434a103
    Checksum (Offset = 118784, CRC = 03A13404) received
    Data object 30/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100e001003696e356
    Checksum (Offset = 122880, CRC = 56E39636) received
    Data object 31/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100f0010096040b66
    Checksum (Offset = 126976, CRC = 660B0496) received
    Data object 32/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301000002006d34c041
    Checksum (Offset = 131072, CRC = 41C0346D) received
    Data object 33/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100100200ab14e4bc
    Checksum (Offset = 135168, CRC = BCE414AB) received
    Data object 34/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100200200059d98a5
    Checksum (Offset = 139264, CRC = A5989D05) received
    Data object 35/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100300200129c5d05
    Checksum (Offset = 143360, CRC = 055D9C12) received
    Data object 36/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100400200e6ad58d8
    Checksum (Offset = 147456, CRC = D858ADE6) received
    Data object 37/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003010050020071bde020
    Checksum (Offset = 151552, CRC = 20E0BD71) received
    Data object 38/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301006002004e23fdbc
    Checksum (Offset = 155648, CRC = BCFD234E) received
    Data object 39/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100700200ab2750f5
    Checksum (Offset = 159744, CRC = F55027AB) received
    Data object 40/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003010080020024e11123
    Checksum (Offset = 163840, CRC = 2311E124) received
    Data object 41/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100900200366cb62e
    Checksum (Offset = 167936, CRC = 2EB66C36) received
    Data object 42/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100a00200c6b4bc76
    Checksum (Offset = 172032, CRC = 76BCB4C6) received
    Data object 43/43 created
    Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301e8ac0200588be7f6
    Checksum (Offset = 175336, CRC = F6E78B58) received
    Upload completed in 18.09 seconds
    Disconnected.
    Disconnected by the remote device
    7. Powered off / on the NRF52 DK
    8. Using nrf Connect app on iOS - Tried to look for "Nordic_Blinky" but did NOT see any. Tried this multiple time by restarting NRF52 board and checked with both iOS and Android phones - the result was same - cannot see the BLE device name. [This is way different from my observations in earlier post but this time I was careful of recording each step and have provided more details.
    After this weekend - I will try the same process with buttonless DFU IMAGEs provided in the SDK to check if that works.
    Do let me know if you need more details.
    Regards
    Murthy
  • Hi Dejan,
    Today I tested Buttonless Secure DFU without bonds using the images that came with the SDK 17.0.2
    I was able to Test the whole process as given in the SDK documentation.
    From this I conclude that the BLINKY fails on DFU OTA because I may be overwriting some code while flashing but I don't know how to check that.
    Grateful for a solution.
    Can you provide more information about the current issue?
    Are you having a problem with the DFU process or is the problem that after the DFU has finished you cannot see your device anymore?
    Dejan
  • Hi Dejan,
    The DFU process works and there are no issues.
    It is after the DFU is completed successfully that I cannot see device name. In this case I am using the ble_blinky app.
    Note: I did not modify anything in the example ble_blinky app.
    I have tried the buttonless_dfu_without_bonds image provided in the SDK - DFU as well as being able to device name after DFU works well. No issues.
    I am really hard pressed for time. I am stuck at this last step. Grateful for any help. I am sure I am missing some step somewhere and not able to see it.
