Added Peer Manage to ble_app_blinky
Hi All,
I want to add pairing and binding functions to the blinky project.
But nothing happens when I connect.
Please help me,thank you.
Here is my project => Lab10_PeerManager_pairing.zip
I'm using SDK v17.1.0
Kai
  • Hi Einar,
    What do you mean? The function just initiates pairing, it works the same every time (that said, if bonded already, it will just initiate encryption of the link using existing key. If not bonded, it will initiate pairing).
    You can refer to this link.
    The statement is a problem with Android itself. If it is actually applied to the product, will the same situation happen?
  • Sorry, I am still not able to understand your question. Please explain in detail, and preferably also provide logs or method to reproduce the issue you are describing to make things clearer.
  • Hi Einar,
    Do you actually use an Android phone to run my program?
    No, I have not tested with an Android device yet (I do not have immediate access to one, and I am still not sure about what to test - all the tests I have been able to do both from iOS and nRF Connect for Desktop shows everything working as expected with regard to pairing). The thread you link to does not describe a common problem, and I do not see any reason in what you have written before that indicate it is related. However, I have yet to get a proper description about what the problem is, so I do not know what to look for.
    If you want me to look into this, then please elaborate on the issue. Currently my understanding is that "pairing function appear", and if you by that mean does not appear by itself, that is expected. With your current code you need to initiate it from the Android side, and it will not happen automatically. Again, please describe in more detail both what is happening and what you want.
  • Hi Einar,
    I had no idea how to tell you the problem, so I made a video.
