sd_ble_enable in debug mode
Hello Nordic Semi team,
Need help with sd_enable call.
I am using this code to set my MTU to 64.
// Configure the gatt MTU size .
memset(&ble_cfg, 0, sizeof(ble_cfg));
ble_cfg.conn_cfg.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
ble_cfg.conn_cfg.params.gatt_conn_cfg.att_mtu = 64;
err_code = sd_ble_cfg_set(BLE_CONN_CFG_GATT, &ble_cfg, *ptr );
When I compile code in release mode the sd_ble_enable call returns fine with 0
When I compile code in debug mode the sd_ble_enable call returns a 4, which is insufficient memory. NRF_ERROR_NO_MEM
However, if I change mtu to 32 bytes, the sd_enable call returns 0 even in debug mode.
Does debug mode use more RAM resources on the NRF?
As a solution, do I just give it more RAM to work in the debug mode? Why am I seeing this behavior?  Some insights would be much appreciated.
Hari
