nrfx_i2s_start will impact k_timer_start?
NCS1.9.1,nRF5340DK,  VSCode,
see code, timer_lms==1000 spend 1000ms
but if start i2s
i2s_audio_init(); //this line will Slow down the time
 timer_lms==200  spend 1000ms
static int timer_lms=0;
void timer_ms_handler(struct k_timer *dummy)
	if(timer_lms%1000==0)printk("ms:%d   %d\n",timer_lms,timer_lms/1000);
    timer_lms++;//k_work_submit(&my_work);
K_TIMER_DEFINE(my_timer, timer_ms_handler, NULL);
void main(void)
	#if defined (NRF5340_XXAA_APPLICATION)
	nrfx_clock_divider_set(NRF_CLOCK_DOMAIN_HFCLK, NRF_CLOCK_HFCLK_DIV_1);//128MHz
	k_timer_start(&my_timer, K_MSEC(1), K_MSEC(1));
	i2s_audio_init();//this line will Slow down the time
	while(true){k_msleep(1000);};
#define I2S_SCK_PIN 		0x08
#define I2S_LRCK_PIN 		0x23
#define I2S_SDOUT_PIN 		0x09
#define I2S_SDIN_PIN 		0x20
#define I2S_DATA_BLOCK_WORDS 40
static nrfx_i2s_buffers_t initial_buffers;
ISR_DIRECT_DECLARE(i2s_isr_handler)
	nrfx_i2s_irq_handler();
	ISR_DIRECT_PM(); /* PM done after servicing interrupt for best latency
	return 1;		 /* We should check if scheduling decision should be made */
static void data_handler(nrfx_i2s_buffers_t const *p_released, uint32_t status)
nrfx_err_t i2s_audio_init()
	IRQ_DIRECT_CONNECT(I2S0_IRQn, 0, i2s_isr_handler, 0);
	#else
	IRQ_DIRECT_CONNECT(I2S_IRQn, 0, i2s_isr_handler, 0);
	//YOu should probably change this config to fit your I2S microphone and audio preferences.
	nrfx_i2s_config_t config =NRFX_I2S_DEFAULT_CONFIG(I2S_SCK_PIN, I2S_LRCK_PIN,
								NRFX_I2S_PIN_NOT_USED,I2S_SDOUT_PIN, I2S_SDIN_PIN);// NRFX_I2S_PIN_NOT_USED   I2S_MCK_PIN
	config.mode = NRF_I2S_MODE_MASTER;
	config.ratio = NRF_I2S_RATIO_96X;
	config.sample_width = NRF_I2S_SWIDTH_16BIT;
	config.mck_setup = NRF_I2S_MCK_32MDIV42;	//Preference     freq = (MCKfreq/ratio) =8 KHz.
	config.channels = NRF_I2S_CHANNELS_LEFT;
	nrfx_err_t err_code = nrfx_i2s_init(&config, data_handler);
	if (err_code != NRFX_SUCCESS)
		printk("I2S init error\n");
		return err_code;
	err_code = nrfx_i2s_start(&initial_buffers, I2S_DATA_BLOCK_WORDS, 0); //start recording
		printk("I2S start error\n");
		return err_code;
	// nrfx_i2s_stop();
	// k_sleep(K_SECONDS(2));
	return err_code;
thanks
Best Regards
