USBD_MSC example on nRF52833
we are using an nRF52833 for an application where we have a sensors, a USB interface and an SD memory device.
We would like to write and read back sensor values to/from the SD memory.
Can we do this with the nRF52833 using 4 wires interface (writing data rate is slow 12KB a second into files)?
We would also like to connect a PC to the device through USB to read back the data (hopefully a bit faster).
The USBD_MSC example looks like a good starting point but is designed for QSPI on the nRF52840
I assume the nRF52833 doesn't support QSPI?
Could the example application be modified to work with the nRF52833 and a 4 pin interface?
If so do you have any other pointers on how best to port it?
Thanks
