ANT example ant_continuous_scanning_controller(SDK 17.0.2) problem
Dear Members,
The project I'm working on now requires searching for nearby ANT+ devices and then using a table to choose which device to pair with.
These ANT+ devices include: BPWR,BSC,HRM devices.
So,I first practice with example ant_continuous_scanning_controller(SDK 17.0.2, SoftDevice S212 ). Test with SimulANT+ (Version 2.3.0.0). Open 2 BPWR devices at the same time, But it can't find any device normally.
bpwr  device:
I press button ,It always shows up p_ant_evt->event: 0x00000007(EVENT_CHANNEL_CLOSED).
I try to change the setting of sdk_config.h, But it still doesn't work.
// <o> ANT_NETWORK_NUM - Network number.
#ifndef ANT_NETWORK_NUM
#define ANT_NETWORK_NUM 0
// <o> ANT_RESPONSE_CHANNEL_NUMBER - ANT response channel number.
#ifndef ANT_RESPONSE_CHANNEL_NUMBER
#define ANT_RESPONSE_CHANNEL_NUMBER 1
// <o> ANT_SCAN_CHANNEL_NUMBER - ANT scan channel number.
#ifndef ANT_SCAN_CHANNEL_NUMBER
#define ANT_SCAN_CHANNEL_NUMBER 0
// <o> CHAN_ID_DEV_TYPE - Channel ID: Device Type.
#ifndef CHAN_ID_DEV_TYPE
#define CHAN_ID_DEV_TYPE 11	// 1
// <o> CHAN_ID_TRANS_TYPE - Channel ID: Transmission type.
#ifndef CHAN_ID_TRANS_TYPE
#define CHAN_ID_TRANS_TYPE 5	// 5	// 21
// <o> HOME_ID - Unique ID for the entire network.
#ifndef HOME_ID
#define HOME_ID 4660
// <o> RF_FREQ - RF Frequency.
#ifndef RF_FREQ
#define RF_FREQ 57	//0x39u	// 25
Also add ant_search_init(); to code,then change "search_priority" to highest , But it still doesn't work.
/**@brief initialize ant search // joe
static void AntSearchInit(void)	// joe
	uint32_t err_code;
	ant_search_config_t init;
	init.channel_number = ANT_SCAN_CHANNEL_NUMBER;
	init.high_priority_timeout = ANT_DEFAULT_HIGH_PRIORITY_TIMEOUT;
	init.low_priority_timeout = ANT_DEFAULT_LOW_PRIORITY_TIMEOUT;
	init.search_priority = ANT_SEARCH_PRIORITY_HIGHEST;
	init.search_sharing_cycles = ANT_SEARCH_SHARING_CYCLES_DISABLE;
	init.waveform = ANT_WAVEFORM_FAST;
	err_code = ant_search_init(&init);
/**@brief initialize application
static void continuous_scan_init()
    uint32_t err_code;
	AntSearchInit();
    // Set library config to report RSSI and Device ID
    err_code = sd_ant_lib_config_set(
        ANT_LIB_CONFIG_MESG_OUT_INC_RSSI | ANT_LIB_CONFIG_MESG_OUT_INC_DEVICE_ID);
    // Configure channel 0 for scanning mode, but do not open it.
    // The scanning channel will be opened in scan mode for a short amount of time on a button press.
    ant_channel_config_t channel_config =
        .channel_number    = ANT_SCAN_CHANNEL_NUMBER,
        .channel_type      = CHANNEL_TYPE_SLAVE,
        .ext_assign        = 0x00,
        .rf_freq           = RF_FREQ,
        .transmission_type = CHAN_ID_TRANS_TYPE,
        .device_type       = CHAN_ID_DEV_TYPE,
        .device_number     = 0x00,          // Wildcard
        .channel_period    = 0x00,          // Not used, since this is going to be scanning
        .network_number    = ANT_NETWORK_NUM,
    err_code = ant_channel_init(&channel_config);
    // Assign a second channel for sending messages on the reverse direction
    // There is no need to configure any other parameters, this channel is never opened;
    // its resources are used by ANT to send messages in the reverse direction while in
    // continuous scanning mode.
    err_code = sd_ant_channel_assign(ANT_RESPONSE_CHANNEL_NUMBER,
                                     CHANNEL_TYPE_SLAVE,
                                     ANT_NETWORK_NUM,
                                     0x00);
Please,how can I solve this problem?
Thanks!
Joe
  • Thanks for  your  reply! I  add ANT_PLUS_NETWORK_KEY to  code  as you  said.
    void ant_evt_handler(ant_evt_t * p_ant_evt, void * p_context)
        uint32_t err_code;
        uint8_t  message_rssi;
        uint16_t message_device_number;
        ANT_MESSAGE * p_ant_message = (ANT_MESSAGE *) &p_ant_evt->message;
    		NRF_LOG_INFO("p_ant_evt->event:0x%08X", p_ant_evt->event);
        switch (p_ant_evt->event)
            case EVENT_RX:
                if (p_ant_message->ANT_MESSAGE_aucPayload[0] == DEVICE_STATUS_PAGE)
                    bsp_board_led_invert(BSP_BOARD_LED_1);
                    if (p_ant_message->ANT_MESSAGE_stExtMesgBF.bANTDeviceID &&
                        p_ant_message->ANT_MESSAGE_stExtMesgBF.bANTRssi)
                        message_device_number =
                            (uint16_t)(p_ant_message->ANT_MESSAGE_aucExtData[0] |
                                       ((uint16_t)p_ant_message->ANT_MESSAGE_aucExtData[1] << 8));
                        message_rssi = p_ant_message->ANT_MESSAGE_aucExtData[5];
                        node_to_list_add(message_device_number, message_rssi);
            case EVENT_TRANSFER_TX_COMPLETED:
                bsp_board_led_off(BSP_BOARD_LED_0);
                bsp_board_led_off(BSP_BOARD_LED_1);
                err_code = sd_ant_channel_close(ANT_SCAN_CHANNEL_NUMBER);
            case EVENT_TRANSFER_TX_FAILED:
                if (m_retries > 0)
                    command_send();
                    m_retries--;
                break; // No implementation needed
    Now it can receive EVENT_RX(p_ant_evt->event = 0x00000080),but it can't find
    "p_ant_message->ANT_MESSAGE_aucPayload[0] == DEVICE_STATUS_PAGE ", Check the log of SimulANT+,It doesn't seem  transmit DEVICE_STATUS_PAGE, How can  I solve  this problem?
    Thanks!
    Joe
