How to reduce zigbee power consumption when endpoint is searching network
We have a multiprotocol project running BLE and Zigbee Stacks. The device always operate on BLE, but Zigbee is optional. The project is developed using NCS with zephyr revision v2.4.99-ncs2. Zigbee can be enabled or disabled writing to a BLE characteristic. The device is configured as a Zigbee Endpoint
Zigbee stack is started with those lines of code:
	zb_af_register_device_ctx(&device_context);
	zb_set_ed_timeout(ED_AGING_TIMEOUT_64MIN);
	zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
	zb_set_rx_on_when_idle(ZB_FALSE);
	zigbee_enable();
When zigbee stack is searching network, the device is consuming around 15 mA, and after successful steering it lows down to 100 uA. If Zigbee is enabled, consumption is OK, but when Zigbee is disabled, and no network is available, the device keeps consuming 15 mA forever.
My questions are:
¿How can I disable the Zigbee stack on runtime, and avoid the consumption part due to zigbee functions?
alternatively
¿Is there a way to simulate a network join, without having a real network, so that the Zigbee EP thinks it is connected and the consumption keeps on 100 uA?
Even if we decide not to execute zigbee_enable at start up, the fact of having CONFIG_ZIGBEE=y consumes around 1 mA. So that not enabling zigbee at start up, is not an option.
Any help will be appreciated, thanks,
Jordi
    No worries about the response time. We get notified when a reply comes in on our open tickets.
    Allright, so I see you've tried a couple of functions to disable the Zigbee network and none of them works as intended, which is as expected if we take a closer look on what these functions do.
    • zb_bdb_reset_via_local_action(0): In short terms, what this function does is to factory reset the Zigbee stack and sends the ZB_ZDO_SIGNAL_LEAVE to the network, and leaving the network. It does not disable the Zigbee.
    • zdo_mgmt_leave_req(): This function sends a "management leave request" to a device and asks it to leave the network. It can be used to ask other devices to leave the network or send it to itself and leave the network itself.
    • zb_sleep_now(): As far as I know this function puts the network to sleep on command, but it whenever it gets interrupted by any routines or tasks to do, the system goes out of sleep. It is only usable in a end device such as a light switch, which does not continually have tasks to do (unless it is toggled all the time).
    What all these 3 functions have in common, is that if you try to leave the network in any manner, the first action that happens after this is done is that the device starts looking for a network again, leaving you with the power spikes whenever this process starts.
    You're right that there are no equivalent function to zigbee_enable() in the shape of a "zigbee_disable()", which is why multiprotocol support in NCS with this Zigbee sample that supports enabling of multiprotocol support is the proper way to implement it. Over time, the power consumption caused by the action of searching and joining a network becomes far larger than to properly implement a time sliced multi-protocol application. Doing it this way you may take advantage of the functionality that negotiates timeslots for the 802.15.4 radio driver and ensure that the various protocols have allocated enough time to the tasks required by them such as discovering, joining, and performing other various tasks in the queue before going to sleep and being awoken.
    Feel free to follow up with more questions and let me know if this clarifies anything for you!
    andreas
  • Hi Andreas,
    Thanks for your answer. I attached my code here for the zboss_signal_handler and for the function start, that starts the zigbee stack. You can observe is like in the example Multiprotocol Light Switch . The Sleepy End Device behavior is enabled with the function zb_set_rx_on_when_idle(ZB_FALSE):
    void zboss_signal_handler(zb_bufid_t bufid)
    	ZigbeeDeviceContext* instance = ZigbeeDeviceContext::getInstance();
    	zb_zdo_app_signal_hdr_t* p_sg_p = nullptr;
    	zb_zdo_app_signal_type_t sig = zb_get_app_signal(bufid, &p_sg_p);
    	zb_ret_t status = ZB_GET_APP_SIGNAL_STATUS(bufid);
    	LOG_DBG("sig = %d", sig);
    	ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
    	if(sig == ZB_BDB_SIGNAL_STEERING || sig == ZB_BDB_SIGNAL_DEVICE_REBOOT) {
    		if(status == RET_OK) {
    			instance->joinedSuccessful();
    	} else if(sig == ZB_COMMON_SIGNAL_CAN_SLEEP) {
    		if(instance->isJoined() == true) {
    			zb_sleep_now();
    	/* All callbacks should either reuse or free passed buffers.
    	 * If bufid == 0, the buffer is invalid (not passed).
    	if(bufid) {
    		zb_buf_free(bufid);
    void ZigbeeDeviceContext::start()
    	ZB_ZCL_REGISTER_DEVICE_CB(commandHandler);
    	if(endpoints.empty() == false) {
    		device_context.ep_count = endpoints.size();
    		device_context.ep_desc_list = new zb_af_endpoint_desc_t*[device_context.ep_count];
    		int i = 0;
    		for(const auto& endpoint: endpoints) {
    			device_context.ep_desc_list[i] = endpoint.second->getDescriptor();
    			i++;
    	zigbee_enable();
    Now, I have just discovered than if I comment line 330 of file zigbee_app_utils.c:
    // 				start_network_rejoin();
    The system behaves as desired, that is, consumption is high 17mA for 40 seconds, while end device is trying to join network, and is low 150 uA, after those 40 seconds.
    So, my conclusion is that the fact that the end device is continuously trying to join to a zigbee network is the responsible for high consumption.
    I don't like the solution of commenting line 330, because zigbee_app_utils.c belongs to the SDK. So, do you think, there is another way of avoiding a continuous network rejoin try (change CONFIG, call to a function, ... any idea?)
    Jordi
  • Hi Jordi,
    1) and 2): Great! Then we're on the same page! It is easy to focus on the practical aspects about something, and not spend enough time on reading and understanding the theory/API and I must admit I really know the feeling of prioritizing one over the other!..
    Jorcis said:
    I wonder if it would be possible to pair BLE peripheral and central device, automatically when they get closer one another.
    Yes, this is possible, and it can be done by modifying the peripheral_uart and central_uart filters. The BLE scan API should give you a headstart on how to do this together with those two samples. What you want to do is to limit the scanning of devices with a filter such that the peripheral only advertises a given filter (it could be UUID or a name in form of a string), and that the central and peripheral should only connect to each other if that filter criteria is met
    You could get started with this documentation and the two samples, and I'll see if I can put together a small sample illustrating this tomorrow!
    Andreas
  • Hi again, following up from yesterdays post
    Jorcis said:
    There's a possibly general misunderstanding in our department that pairing is only possible between two legacy traditional bluetooth devices but not between low energy ones.
    Yes, this is a misunderstanding. Both bonding and pairing can be done with both legacy Bluetooth protocol and newer Low Energy protocols. I said I was going to create a small sample to illustrate this, but I think the peripheral_bms sample which uses the Bluetooth LE bond module or the central and peripheral hrs, sample which scans for peripherals with the heart rate service defined, explains this far better. Here you may also see how the pairing callback structs are done line 128 in the main file in peripheral_bms as well as 202 in central_and_peripheral_hrs with with their respective
    I hope this answers the missing details from my reply yesterday!
    Andreas
  • Thanks very much Andreas for this information. I looks promising, and I will come back to it, in future projects.
    Jordi.
  • Hi Jordi,
    Glad to hear that the information is helping!
    Does this mean that your questions has been answered and we can close this case? For future cases you open you may refer to this one by case ID if the new one is related to this project.
    Andreas
  • Yes Andreas, the ticket can be closed.
    Thanks for your help, for the complete and precise information!
    Jordi.
