Hello Nordic Engineer,
I'm a beginner
In this GitHub
If I add code after 473 lines
rx_payload.noack = true
what will the final result be?
Thanks
I'm a beginner
In this GitHub
Thanks
Have in mind that when you are not using ACK, it is a chance that one or both devices will not receive the packet. So just to make sure I don't misunderstand the problem here, are some packets received from the relay, or are no packet received from the relay?
Kenneth
Thank you for your reply
I want to discuss the content of your reply in two parts
In my understanding, TX can send data to Rx
If RX wants to send data to TX, it must use ACK
RX can choose to turn off ack (do not send response to TX)
TX can also choose to turn off ack (no response is received)
Do I have a wrong understanding? (If I'm wrong, hope you can correct me)
"Relay" will only receive BLE data and send ESB_ ptx
As for other Devices, they have the functions of TX and RX at the same time
Thank you
eric_cheng said:RX can choose to turn off ack (do not send response to TX)
This is not possible, it's only the TX that can control whether it want an ACK or not.
eric_cheng said:TX can also choose to turn off ack (no response is received)
Correct.
