LPN won't unprovision
I'm trying to get an LPN to unprovision itself based off of an external command.
I tried to base it off of the examples so I simply call:
(void) proxy_stop();
mesh_stack_config_clear();
dsm_clear();
node_reset();
However after the reset it still immediately pairs back with it's friend and still seems to have retained it's keys.
What am I missing?
Alex
    Have you stepped through the code and see if the node is actually reset?
    What SDK version are you using?
    But have you debugged the code to see if these functions:
    dsm_clear();
    node_reset();
    are called?
    It seems like the functions aren't really called at all.
    Alex Ross said:
    One thing of note is that I do have the bootloader (/Bootloader/nrf52833_secure_bootloader.hex) running on it as well for DFU.
    I don't think this will cause any issue.
  • Sorry for the delay!
    I walked through with a debugger and everything looked right. I added these messages to ensure full execution:
    void mesh_unprovision(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, __RECEIVE__ "1\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, __RECEIVE__ "2\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, __RECEIVE__ "3\n");
    dsm_clear();
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, __RECEIVE__ "4\n");
    node_reset();
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, __RECEIVE__ "5\n");
    00> <t:    1233929>, mesh_interface.c,  458, Friend poll procedure complete
    00> <t:    1509965>, mesh_interface.c,  458, Friend poll procedure complete
    00> <t:    1793067>, mesh_interface.c,  327,  RX: Unprovision request
    00> <t:    1793070>, mesh_interface.c,  332,  RX: Executing...
    00> <t:    2350794>, mesh_interface.c,  342,  RX: 1
    00> <t:    2477728>, mesh_interface.c,  344,  RX: 2
    00> <t:    6003326>, mesh_interface.c,  346,  RX: 3
    00> <t:    6129078>, mesh_i<t:      49888>, main.c,  151, ----- Pin init done -----
    00> <t:      49890>, main.c,  154, ----- Timer init done -----
    00> <t:      49893>, uart_interface.c,   73, ----------UART init complete
    00> <t:      62090>, nrf_sdh_ble.c,  240, RAM starts at 0x20002488<t:      62092>, main.c,  160, ----- NUS init done -----
    00> <t:      62711>, nrf_mesh_dfu.c,  690, ------>nrf_mesh_dfu_init 6
    00> <t:      62718>, mesh_interface.c,  187, Initializing and adding models
    00> <t:      62764>, mesh_interface.c,  224, Initting LPN mode
    00> <t:      62766>, main.c,  163, ----- Mesh init done -----
    00> <t:      62769>, mesh_interface.c,  509, Mesh Timer init finished
    00> <t:      63037>, main.c,  179, ----- Initalize done -----
    00> <t:      63040>, mesh_interface.c,  108, Node Address: 0x001B
    00> <t:      63043>, mesh_app_utils.c,   66, Device UUID (raw):
    00> <t:      63059>, mesh_interface.c,  256,
    I'm not seeing node_reset() being called since 4 isn't being printed. Can you see if this is the case?
  • I think it had to as I have init messages pop up again after it should have been called.
    It seems pretty strange. Could you try with the LPN example without any modifications? Pressing button 4 should reset the node. Do you see the same behaviour?
  • I found adding:
        mesh_stack_power_down();
    At the end of the function calls did the trick.
