Assertion Fail Using ble_nus_client_send with UART in NRF Connect SDK 1.8.0
I am getting the error: ASSERTION FAIL @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/conn.c:1152
E: r0/a1: 0x00000004 r1/a2: 0x00000480 r2/a3: 0x200060d0
I'm using the Fanstel BLG840X which integrates an nrf52840 and nrf9160.  I am using NRF Connect SDK 1.8.0.  At a high level the software:
1) nrf52840 establishes BLE connection with a sensor using nordic uart service
2) receives a message from the sensor
3)52840 uses UART to notify the 9160 to ask for information back
4) 9160 responds with queried information (uart transfer from 9160 to 52840)
5)the information received from the 9160 over UART is sent out over BLE to the sensor
In trying to narrow the problem I found that sending information to the sensor before step 3 (using UART to communicate between the boards) functions properly.  So I suspect that there may be some interference from the UART module in steps 3/4/5.  I was also getting an MPSL 112,2165 error but that has stopped appearing.  Here is my ble function causing the fault and my prj.conf file:
void send_timestamp(struct uart_data_t *uart_data)
    struct bt_nus_client *nus1 = &nus_client;
    int status;
    uint8_t len = 10;
    status = bt_nus_client_send(nus1, uart_data->data, len); // why is this incompatible
    if (status != 0)
        printk("err: %d\n", status);
        printk("successful send \n");
CONFIG_BT=y
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_CENTRAL=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
CONFIG_BT_L2CAP_TX_BUF_COUNT=10
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_NUS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_NEWLIB_LIBC=y
CONFIG_REBOOT=y
CONFIG_RTT_CONSOLE=y
CONFIG_SERIAL=y
CONFIG_UART_1_ASYNC=y
CONFIG_UART_ASYNC_API=y
CONFIG_UART_CONSOLE=n
CONFIG_USE_SEGGER_RTT=y
#ble split, hardfault was being caused by multi-protocol service layer (mpsl), this changes ble controller to zephyr. not sure if needed
#CONFIG_BT_LL_SW_SPLIT=y
Another note is that UART is initialized before steps 1-5 take place, so if there is interference from the UART module it would likely be happening from the actual UART messages sending/receiving.
Another potential issue is that the UART is still busy.  Further testing I tried sending a UART message then immediately after sending a BLE message and that failed as well, so I was wondering if there was any overlap between UART/BLE since it's nordic UART service being used for the BLE, and if there are standardized ways to keep them separated, ie: don't use BLE while UART is active.
Currently receiving information over BLE then sending it over UART works but not receiving information over UART then sending over BLE causes the Assertion.
Thanks for the help and please let me know if you need other information/code.
