How can i Rejoin with the previously paired network after power goes off ?
Hi Team, In my project i am using nrf52833 and i have established a network using Open Thread protocol to communicate . I am able to pair my device with the network. One scenario i wanted to implement for my project are described below.
Generally when power goes off device got disconnected from the network. I wanted to rejoin the device with the previously paired thread network when device powered  again. Is there any possibilities to rejoin with the network when power ON with out doing any physical activities with the device. If so, then what are the possible way we can rejoin the device with the network.
Thank you.
    The OpenThread stack should store the network dataset in flash during the commissioning procedure. When you power cycle the device, your application should be able to utilize the existing credentials to rejoin the network. See this post for more details.
    You can use the function otDatasetIsCommissioned() to check if the dataset is commissioned, to determine if you should start joiner process or not.
    Jørgen
  • is dataset stored in flash automatically after successfully got paired?
  • if once we paired, is it needs to be pair again while joining into the network?
    Very first time i am pairing the devices by pressing the key but i don't wanted to press key while device tries to rejoin into same network after got disconnect once. Device should join automatically.
    How it would be possible?
  • No, you do not need to pair again if you have reset the device and want to rejoin the network. Dataset and keys are stored in flash during commissioning. See Chapter 10.12 (Persistent data) in Thread 1.1.1 specifications for more details.
    In your application, you can call otDatasetIsCommissioned() to see if the dataset is commissioned. If the dataset is not commissioned, you can choose to start the joiner, or call otThreadSetEnabled() to join the network if dataset is commissioned.
  • otDatasetIsCommissioned() this function accept otinstance as a parameter . Very 1st time while i am pairing device one otinstance gets created . I have used this function otDatasetIsCommissioned() with the otinstace and i can see this function returned TRUE that's mean data gets commissioned. now i  do reset my device and i wanted to use those data . How can i faced those data? so that i can use the stored dataset and key for join again.
