NRF52805 ADC BLE APP UART
Hello, I'm working currently on an nrf52805 module and I'm creating a board with it, for now, I managed to do the ble app uart for this module and improve to code a little bit.
My goal, for now, is to create an ADC measurement of voltage, and I'm struggling with this. If someone could help me with this that would be great to give a code that would be good with it or an idea (i'm kinda new with BLE)
So I tried to use the example:    github.com/.../ble_app_uart__saadc_timer_driven__scan_mode
I'm trying to readapt the example to my board and thanks to the datasheet i saw that The nRF52805 only has 10 PPI channels (0-9) and The nRF52805 also only has 3 timers (TIMER0-TIMER2) but when I'm trying to taking off this in the code i get this error after :
Thank you to everybody for their help.
  • Hello again lets continue here :) i gave you the infos that i have in the last answers :) thank you for your help
  • I'm making of resume of the situation for now, not shure if i'm in the right orad but saw different threads about this error : https://devzone.nordicsemi.com/f/nordic-q-a/73213/nrfx_timer3_inst_idx-undeclared-first-use-in-this-function-sdk-enabled
    Can't found the real solution : I tried to change the apply_old_config.h (nothing changes), enabled the right timers to 1
    // <e> NRFX_TIMER_ENABLED - nrfx_timer - TIMER periperal driver
    #ifndef NRFX_TIMER_ENABLED
    #define NRFX_TIMER_ENABLED 1
    // <q> NRFX_TIMER0_ENABLED  - Enable TIMER0 instance
    #ifndef NRFX_TIMER0_ENABLED
    #define NRFX_TIMER0_ENABLED 0
    // <q> NRFX_TIMER1_ENABLED  - Enable TIMER1 instance
    #ifndef NRFX_TIMER1_ENABLED
    #define NRFX_TIMER1_ENABLED 0
    // <q> NRFX_TIMER2_ENABLED  - Enable TIMER2 instance
    #ifndef NRFX_TIMER2_ENABLED
    #define NRFX_TIMER2_ENABLED 0
    // <q> NRFX_TIMER3_ENABLED  - Enable TIMER3 instance
    #ifndef NRFX_TIMER3_ENABLED
    #define NRFX_TIMER3_ENABLED 1
    // <q> NRFX_TIMER4_ENABLED  - Enable TIMER4 instance
    #ifndef NRFX_TIMER4_ENABLED
    #define NRFX_TIMER4_ENABLED 1
    For now, i watched all the treads that i could in nordic but never saw espacially for the nrf52805 and because he has only 3 timers it is hard  to found a real solution
    Thank you for your understanding
    Have a good day
  • Hello again,
    Thank you for your patience with this.
    lm said:
    And the problem is that i don't know if i'm in the right road with the example that i showed you before ( saadc timer driven and ble app uart example ) i would like to know what i have to dot with my code of now (ble app uart) to just add ADC and have the voltage consumption result thank you
    I think the saadc timer driven ble app uart is the perfect example for you to start from when you want to achieve VDD measurement through the SAADC and send it over BLE using the NUS service.
    If you would like to do so yourself starting from the ble app uart you will basically end up where the saadc timer driven ble app uart example starts.
    If you still would like to go through it I would recommend that you start looking at the SAADC peripheral example, and then merge it into the ble app uart example.
    lm said:
    I tried to enable in sdk_config the timer 0 1 and 2 but i have those errors again
    It seems to me that you are still trying to use the TIMER3 instance, which does not exist on the nRF52805 SoC. Could you confirm that you have changed the timer instance to 1 or 2 instead? Please note that TIMER0 is reserved for the SoftDevice when it is enabled.
    Please do not make changes to apply_old_config.h as this may cause trouble down the road.
    The issue here is that there does not exist a TIMER3, which you are trying to use in your main.c timer instance creation.
    Please confirm that you have changed the following line from your originally shared project:
    static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(3);
    Karl
  • Hello Karl, I'm going to give you my main for you to see that the line is okay
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * Peripheral: SAADC
     * Compatibility: nRF52832 rev 2/nRF52840 rev 1, SDK 15.2.0
     * Softdevice used: S132 v6.1.0/S140 v6.1.0
     * This SAADC example samples on 4 different input pins, and enables scan mode to do that. It is otherwise an
     * offsprint from the standard ble_app_uart example available in nRF5 SDK 15.2.0
     * Works together with softdevice S132 v6.1.0 on nRF52832 and S140 v6.1.0 on nRF52840
     * Transmits SAADC output to hardware UART and over BLE via Nordic UART Servive (NUS).
     * Info on NUS -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/ble_sdk_app_nus_eval.html?cp=4_0_0_4_1_2_17
     * Info on hardware UART settings -> http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/uart_example.html?cp=4_0_0_4_4_41
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SAADC_SAMPLES_IN_BUFFER         4
    #define SAADC_SAMPLE_RATE               250                                         /**< SAADC sample rate in ms. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    volatile uint8_t state = 1;
    static nrf_saadc_value_t       m_buffer_pool[2][SAADC_SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t       m_ppi_channel;
    static uint32_t                m_adc_evt_counter;
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    void timer_handler(nrf_timer_event_t event_type, void* p_context)
        nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
        timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
        err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
        /* setup m_timer for compare event */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer,SAADC_SAMPLE_RATE);
        nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
        uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
            uint16_t adc_value;
            uint8_t value[SAADC_SAMPLES_IN_BUFFER*2];
            uint16_t bytes_to_send;
            // set buffers
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
            // print samples on hardware UART and parse data for BLE transmission
            printf("ADC event number: %d\r\n",(int)m_adc_evt_counter);
            for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
                printf("%d\r\n", p_event->data.done.p_buffer[i]);
                adc_value = p_event->data.done.p_buffer[i];
                value[i*2] = adc_value;
                value[(i*2)+1] = adc_value >> 8;
             // Send data over BLE via NUS service. Create string from samples and send string with correct length.
            uint8_t nus_string[50];
            bytes_to_send = sprintf(nus_string,
                                    "CH0: %d\r\nCH1: %d\r\nCH2: %d\r\nCH3: %d",
                                    p_event->data.done.p_buffer[0],
                                    p_event->data.done.p_buffer[1],
                                    p_event->data.done.p_buffer[2],
                                    p_event->data.done.p_buffer[3]);
            err_code = ble_nus_data_send(&m_nus, nus_string, &bytes_to_send, m_conn_handle);
            if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_NOT_FOUND))
            m_adc_evt_counter++;
    void saadc_init(void)
        nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
        saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
        nrf_saadc_channel_config_t channel_0_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
        channel_0_config.gain = NRF_SAADC_GAIN1_4;
        channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_1_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
        channel_1_config.gain = NRF_SAADC_GAIN1_4;
        channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_2_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
        channel_2_config.gain = NRF_SAADC_GAIN1_4;
        channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_3_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
        channel_3_config.gain = NRF_SAADC_GAIN1_4;
        channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4;
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
        err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
        err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
        err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        saadc_sampling_event_init();
        saadc_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • So now i'm going to change the line like you told me by this:
    /** @file
     * Peripheral: SAADC
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(2);
        uint32_t                err_code;
            uint32_t err_code;
                do
        uint32_t           err_code;
        // Initialize NUS.
        uint32_t err_code;
        uint32_t err_code;
                sleep_mode_enter();
        uint32_t err_code;
            } break;
        uint32_t err_code;
        switch (event)
                sleep_mode_enter();
        uint32_t       err_code;
                index++;
                    if (index > 1)
                        do
                    index = 0;
    #else
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
        nrf_pwr_mgmt_run();
            uint16_t adc_value;
            // set buffers
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        saadc_init();
        // Start execution.
        // Enter main loop.
        for (;;)
    and it is the error the I have now :
    1> In file included from ../../../../../../modules/nrfx/nrfx.h:45,
    1>                  from ../../../../../../modules/nrfx/hal/nrf_gpio.h:44,
    1>                  from ../../../../../../components/boards/boards.h:43,
    1>                  from ../../../../../../components/libraries/bsp/bsp.h:58,
    1>                  from ../../../../../../components/libraries/bsp/bsp_btn_ble.h:60,
    1>                  from C:\Users\l.marcos\Desktop\nRF5_SDK_17.1.0_ddde560 URGENCE\examples\ble_peripheral\ble_app_uart__saadc_timer_driven__scan_mode v3\main.c:71:
    1> ../../../../../../modules/nrfx/drivers/include/nrfx_timer.h:72:38: error: 'NRFX_TIMER2_INST_IDX' undeclared here (not in a function); did you mean 'NRFX_TIMER_INSTANCE'?
    1> ../../../../../../modules/nrfx/drivers/nrfx_common.h:113:37: note: in definition of macro 'NRFX_CONCAT_3_'
    1> ../../../../../../modules/nrfx/drivers/include/nrfx_timer.h:72:24: note: in expansion of macro 'NRFX_CONCAT_3'
    1> ../../../../../../integration/nrfx/legacy/nrf_drv_timer.h:64:50: note: in expansion of macro 'NRFX_TIMER_INSTANCE'
    1> C:\Users\l.marcos\Desktop\nRF5_SDK_17.1.0_ddde560 URGENCE\examples\ble_peripheral\ble_app_uart__saadc_timer_driven__scan_mode v3\main.c:130:42: note: in expansion of macro 'NRF_DRV_TIMER_INSTANCE'
    Build failed
