Not able to set transmission power using s110 APIs.
Hi , I tried to change the transmission power using the s110 API and tried checking if the value of the register storing the transmission power is changed or not. Following is the portion of code code that I wrote:
#define TX_POWER_LEVEL (-8)
err_code = sd_ble_gap_tx_power_set(TX_POWER_LEVEL);
int tx_power_value = NRF_RADIO->TXPOWER;
when I tried to read the register storing the tx power (TXPOWER as shown above), its still showing value 0 which I guess is by default initialized by softdevice. I am not able to understand why we are not able to update the transmission power.
also the sdk version I am using is v 6.1.0 and softdevice used is 7.3.0
Thank you in advance.
