nRF52840dongle new strange probelm
Upto a week I had *no* problem in programming a nRF52840 dongle with an app I am porting from the nRF52840dk.
All of a sudden I can't get the app running, the dongle appears dead.
I've reisntalled all software and notice the following behaviour.
From scratch (after reinstall of software for example) I can program the dongle with an app I developed with the nRF5SDK using segger - no problem.
Then I can program the dongle with an example program, in this case the periperal lbs example with segger and nRF Connect SDK - no problem.
If I use VSCode and program the dongle with the periperal lbs example the dongle does not work. (Even though the dongle is reported as successfully programmed (and verified if I use that option).
To get the board working again I have to reprogramme with the app from the nRF5SDK! After programming with the VScode the dongle can't be repgrammed from segger and nRF Connect SDK.
Would appreciate any suggestions to fix the problem!
  • Also please note I'm flashing using the nRF52840dk as a debug probe.
    I am struggling a bit to get a full understanding of this. Is it so that in all cases you are programming using a debugger (so not USB DFU via nRF Connect Programmer), and that programming etc. always works? The "only" issue is that your application from a point in time stopped working, and you only see example applications working? If so, what change did you do around the time when your application stopped working? What have you found from debugging?
    Without knowing more, and with the understanding I currently have, I wonder if it could be that you need a higher VDD than 1.8V and the changes you did a week ago cause da change in the VDD voltage (which is output of REG0)? If so, that could match with that it works after you program a example firmware, which will set REG0 output voltage to 3.0 V in UICR. As long as you don't do a full chip erase that is kept. But if you do a full chip erase UICR is also erased, and in that case your new application must also set it to 3.0 V. (This may not be the issue though, both because I don't know if this is actually what is happening, of if 1.8 V is a problem for your application).
  • Thanks for the reply.
    I've managed to narrow down the problem. It appears  erase&flash in VSCode causes the problem. I can succesfuly program with the command line command nrfjprog.
    So to be clear I'm using the nRF52840dongle attached to a nRF52840-dk to program the dongle via a TC2050 lead.
    I can generate a hex file in Segger IDE or VSCode and program with nrfjprog.
    I can program the dongle from inside the Segger IDE as normal.
    It seems just the erase&flash in VSCode causes a problem and stops the dongle being programmed until I program with an nRF5SDK based app. (Even though erase&flash reports success!).
    I haven't yet had time to go any further, but I need to understand why does the reprogramming with an nRF5SDK app 'reset' the dongle, and why is the erase&flash causing a problem.
    If you have any thought on that I'd be insterested but otherwise I'll keep plugging away.
    (As used: nrfjprog -f nrf52 --program  /opt/nordic/ncs/v1.9.1/nrf/samples/bluetooth/peripheral_lbs/build_nrf52840dongle_nrf52840/zephyr/zephyr.hex --sectorerase --verify -reset)
    Ah, it is interesting that the issue here is only flashing from VS Code, and that it works if you flash the same hex file yourself using nrfjprog. VS Code also use nrfjprog (via west), but apparently there is an issue here. Can you copy-paste the log you get in the terminal in VS code when you program from there?
    I notice that you use --sectorerase when you program with nrfjprog. Is there anything else that should be kept from before, or would it work just as good if you did a full chip erase and then programmed? Also, how does that work if you do it from VS Code (first erase the chip, then program it)?
    Which version of VS Code and the nRF Connect for VS Code plugin do you have?
  • Hi, tried the above:
    Programming nRF52840-dongle, via nRF52840dk with dongle powered of dk
    board and connected via TC2050
    From the tests below.
    a) --chiperase works ok with nRF5SDK app.
    b) --chiperase and --eraseall blocks the nRFConnectSDK app from running
    though programming appears successful
    c) In VSCode erase works on a 'non-blocked'  board (i.e reset as
    shown below).
    d) In VSCode erase&flash fails to let the app run though appears
    succesfully programmed. 'Board blocked'
    e) (Re)Programming with nRF5SDK app 'unblocks' the board.
    Versions
    VSCode Version: 1.66.2
    nRF connect for VS Code v2022.3.104
    nrfjprog version: 10.15.4 external
    JLinkARM.dll version: 7.58b
    Toolchain Manager 0.10.3 (Terminal opened from Toolchain menu for command line tests)
    Tests
    1) 1. The nRF5SDK app ‘resets’ the board (note using —chiperase option).
    ****RESET DONGLE WITH PRGRAMMING THIS APP****
    /Users/▦▦▦▦▦▦▦▦▦/Development/nRFProjects/Feeder2021ClassicV11-
    InstalledHighTorquecopy/pca10059/s140/ses/Output/Release/Exe/feeder.hex
    --chiperase --verify --reset --snr 683934038
    Parsing image file.
    Verifying programming.
    Verified OK.
    Applying system reset.
    Run.
    *****App working******
    2)The zephyr app can then be programmed (using —erasesector option).
    /Users/▦▦▦▦▦▦▦▦▦/Development/nRFConnectSDKProjects/peripheral_lbsx/build
    /zephyr/zephyr.hex --sectorerase --verify --reset --snr 683934038
    Parsing image file.
    Verified OK.
    Run.
    ***app working*****
    3) First doing an eraseall before a programming action - app does not
    work.
    nrfjprog -f nrf52  --eraseall  --snr 683934038
    Erasing user available code and UICR flash areas.
    Parsing image file.
    Verified OK.
    Run.
    ***APP NOT WORKING****
    4)Reset app and succesfully programme zephyr app with --sectorerase, but
    fails with --chiperase.
    ****RESET DONGLE WITH PROGRAMMING THIS APP****
    Parsing image file.
    Verified OK.
    Run.
    ****app working****
    Parsing image file.
    Verified OK.
    Run.
    *****app working******
    /zephyr/zephyr.hex --chiperase --verify --reset --snr 683934038
    Parsing image file.
    Verified OK.
    Run.
    *** APP NOT WORKING ******
    5) VSCode erase and flash on 'non-blocked' board -
    Flashing build to undefined
    west flash -d
    --skip-rebuild -r nrfjprog --snr 683934038
    -- west flash: using runner nrfjprog
    WARNING: runners: Argument --snr is deprecated, use -i/--dev-id instead.
    -- runners.nrfjprog: Flashing file:
    /zephyr/zephyr.hex
    Parsing image file.
    WARNING: A programming operation has been performed without --verify.
    WARNING: Programming can fail without error.
    Enabling pin reset.
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 683934038 flashed
    successfully.
    Terminal will be reused by tasks, press any key to close it.
    > Executing task: nRF Connect: Flash peripheral_lbsx/build (active) <
    west flash -d
    --skip-rebuild -r nrfjprog --snr 683934038 --erase
    -- runners.nrfjprog: mass erase requested
    /zephyr/zephyr.hex
    Parsing image file.
    Enabling pin reset.
    Applying pin reset.
    successfully.
