Trouble building at_client sample
I've mostly gotten the tools installed to build for the SparkFun Thing+ nRF9160 board. It had a version of the at_client installed, in that it responded to some AT commands I'd send (but it also was outputting a logging message about an accelerometer). One of the commands I could not get to work was AT+CGDCONT?, or it would just return OK and no information.
Anyway, I tried to build the at_client sample from the v1.9.1 SDK. I flashed the resulting zephyr.bin file to the device, but it seems to not do anything. I saw in the SparkFun getting started that I needed to add "CONFIG_BOOTLOADER_MCUBOOT=y", but that breaks the build.
I tried deleting the build directory, but it doesn't seem to help:
[205/217] Linking C executable zephyr/zephyr.elf
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/mcuboot/zephyr/zephyr.hex /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/mcuboot/zephyr/zephyr.elf
cd /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/mcuboot && /opt/nordic/ncs/v1.9.1/toolchain/Cellar/cmake/3.21.1/bin/cmake --build . --
[207/217] Linking C executable zephyr/zephyr.elf
FAILED: zephyr/zephyr.elf zephyr/zephyr.map zephyr/zephyr.hex zephyr/zephyr.bin zephyr/zephyr.meta zephyr/zephyr.lst zephyr/zephyr.stat /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/zephyr/zephyr.map /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/zephyr/zephyr.hex /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/zephyr/zephyr.bin /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/zephyr/zephyr.meta /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/zephyr/zephyr.lst /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/zephyr/zephyr.stat
: && /opt/nordic/ncs/current/toolchain/bin/arm-none-eabi-gcc   zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj -o zephyr/zephyr.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -Wl,-T  zephyr/linker.cmd  -Wl,-Map=/opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/zephyr/zephyr_final.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/boards/arm/circuitdojo_feather_nrf9160/libboards__arm__circuitdojo_feather_nrf9160.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/net/ip/libsubsys__net__ip.a  zephyr/subsys/random/libsubsys__random.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/nrf_modem_lib/lib..__nrf__lib__nrf_modem_lib.a  modules/nrf/lib/at_monitor/lib..__nrf__lib__at_monitor.a  modules/nrf/lib/at_host/lib..__nrf__lib__at_host.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  /opt/nordic/ncs/current/nrfxlib/nrf_modem/lib/cortex-m33/soft-float/libmodem.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/opt/nordic/ncs/v1.9.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main/nofp"  -L/opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/zephyr  -lgcc  -Wl,--print-memory-usage  zephyr/arch/common/libisr_tables.a  -no-pie  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  spm/libspmsecureentries.a && cd /opt/nordic/ncs/current/nrf/samples/nrf9160/at_client/build/zephyr && /opt/nordic/ncs/v1.9.1/toolchain/Cellar/cmake/3.21.1/bin/cmake -E rename zephyr_final.map zephyr.map && /opt/nordic/ncs/current/toolchain/bin/arm-none-eabi-objcopy --gap-fill 0xff --output-target=ihex --remove-section=.comment --remove-section=COMMON --remove-section=.eh_frame zephyr.elf zephyr.hex && /opt/nordic/ncs/current/toolchain/bin/arm-none-eabi-objcopy --gap-fill 0xff --output-target=binary --remove-section=.comment --remove-section=COMMON --remove-section=.eh_frame zephyr.elf zephyr.bin && /opt/nordic/ncs/current/toolchain/bin/python3 /opt/nordic/ncs/current/zephyr/scripts/zephyr_module.py --zephyr-base /opt/nordic/ncs/current/zephyr --meta-out zephyr.meta && /opt/nordic/ncs/current/toolchain/bin/arm-none-eabi-objdump -d -S zephyr.elf > zephyr.lst && /opt/nordic/ncs/current/toolchain/bin/arm-none-eabi-readelf -e zephyr.elf > zephyr.stat
           FLASH:       62672 B     425472 B     14.73%
            SRAM:       32344 B     211736 B     15.28%
        IDT_LIST:          0 GB         2 KB      0.00%
  File "/opt/nordic/ncs/current/zephyr/scripts/zephyr_module.py", line 542, in <module>
    main()
  File "/opt/nordic/ncs/current/zephyr/scripts/zephyr_module.py", line 534, in main
    meta = process_meta(args.zephyr_base, west_proj, modules,
  File "/opt/nordic/ncs/current/zephyr/scripts/zephyr_module.py", line 318, in process_meta
    if project.sha(MANIFEST_REV_BRANCH) != revision:
  File "/opt/nordic/ncs/v1.9.1/toolchain/lib/python3.9/site-packages/west/manifest.py", line 847, in sha
    cp = self.git(f'rev-parse {rev}^{{commit}}', capture_stdout=True,
  File "/opt/nordic/ncs/v1.9.1/toolchain/lib/python3.9/site-packages/west/manifest.py", line 831, in git
    raise subprocess.CalledProcessError(popen.returncode, cmd_list,
subprocess.CalledProcessError: Command '['rev-parse', 'manifest-rev^{commit}']' returned non-zero exit status 128.
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/current/toolchain/bin/cmake --build /opt/nordic/ncs/v1.9.1/nrf/samples/nrf9160/at_client/build
(full transcript: https://pastebin.com/DCurPYsu)
I'm puzzled as to what to do next.
