Apply the Heartbeat publication and subscription to Serial interface of nRF5 SDK for Mesh.
In our cases, Serial interface needs to support Heartbeat of Configuration Server.
But configuration server's heartbeat handler is not support serial interface and serial interface has no method using heartbeat server.
Therefore, I made it possible, as follows:
I modified 4 files. If you have any questions, please feel free to ask anytime
1. nrf5_SDK_for_Mesh_v5.0.0_src/scripts/interactive_pyaci/aci/aci_cmd.py
diff --git a/nrf5_SDK_for_Mesh_v5.0.0_src/scripts/interactive_pyaci/aci/aci_cmd.py b/nrf5_SDK_for_Mesh_v5.0.0_src/scripts/interactive_pyaci/aci/aci_cmd.py
index f7f92f3b..8fa50048 100644
--- a/nrf5_SDK_for_Mesh_v5.0.0_src/scripts/interactive_pyaci/aci/aci_cmd.py
+++ b/nrf5_SDK_for_Mesh_v5.0.0_src/scripts/interactive_pyaci/aci/aci_cmd.py
@@ -968,6 +968,70 @@ class NetStateGet(CommandPacket):
__data = bytearray()
super(NetStateGet, self).__init__(0xAF, __data)
+class HBPublicationGet(CommandPacket):
+ """Gets the Heartbeat Publication state"""
+ def __init__(self):
+ __data = bytearray()
+ super(HBPublicationGet, self).__init__(0xB0, __data)
+class HBPublicationSet(CommandPacket):
+ """Sets the Heartbeat Publication state
+ Parameters
+ dst : uint16_t
+ The destination to send heartbeat messages.
+ count : uint32_t
+ How many messages to send.
+ period : uint32_t
+ What interval to send messages.
+ ttl : uint8_t
+ Initial TTL.
+ features : uint16_t
+ The features that trigger sending messages when changed.
+ netkey_index : uint16_t
+ The global NetKey Index of the Netkey used to send.
+ Return
+ NRF_ERROR_INVALID_DATA :
+ Invalid netkey_index.
+ Check that A netkey is added corresponding the netkey_index in device
+ def __init__(self, dst, count, period, ttl, features, netkey_index):
+ __data += struct.pack("<H", dst)
+ __data += struct.pack("<I", count)
+ __data += struct.pack("<I", period)
+ __data += struct.pack("<B", ttl)
+ __data += struct.pack("<H", features)
+ __data += struct.pack("<H", netkey_index)
+ super(HBPublicationSet, self).__init__(0xB1, __data)
+class HBSubscriptionGet(CommandPacket):
+ """Gets the Heartbeat Subscription state"""
+ super(HBSubscriptionGet, self).__init__(0xB2, __data)
+class HBSubscriptionSet(CommandPacket):
+ """Sets the Heartbeat Subscription state
+ Parameters
+ src : uint16_t
+ The unicast source address for messages a node shall process.
+ dst : uint16_t
+ period : uint32_t
+ The number of seconds left for processing messages.
+ def __init__(self, src, dst, period):
+ __data += struct.pack("<H", src)
+ super(HBSubscriptionSet, self).__init__(0xB3, __data)
class JumpToBootloader(CommandPacket):
"""Immediately jump to bootloader mode."""
@@ -1740,6 +1804,29 @@ class NetStateGetRsp(ResponsePacket):
__data["next_seqnum_block"], = struct.unpack("<I", raw_data[7:11])
super(NetStateGetRsp, self).__init__("NetStateGet", 0xAF, __data)
+class HBPublicationGetRsp(ResponsePacket):
+ """Response to a(n) HBPublicationGet command."""
+ def __init__(self, raw_data):
+ __data = {}
+ __data["dst"], = struct.unpack("<H", raw_data[0:2])
+ __data["count_log"], = struct.unpack("<B", raw_data[2:3])
+ __data["period_log"], = struct.unpack("<B", raw_data[3:4])
+ __data["ttl"], = struct.unpack("<B", raw_data[4:5])
+ __data["features"], = struct.unpack("<H", raw_data[5:7])
+ __data["netkey_index"], = struct.unpack("<H", raw_data[7:9])
+ super(HBPublicationGetRsp, self).__init__("HBPublicationGet", 0xB0, __data)
+class HBSubscriptionGetRsp(ResponsePacket):
+ """Response to a(n) HBSubscriptionGet command."""
+ __data = {}
+ __data["src"], = struct.unpack("<H", raw_data[0:2])
+ __data["dst"], = struct.unpack("<H", raw_data[2:4])
+ __data["period_log"], = struct.unpack("<B", raw_data[4:5])
+ __data["count_log"], = struct.unpack("<B", raw_data[5:6])
+ __data["min_hops"], = struct.unpack("<B", raw_data[6:7])
+ __data["max_hops"], = struct.unpack("<B", raw_data[7:8])
+ super(HBSubscriptionGetRsp, self).__init__("HBSubscriptionGet", 0xB2, __data)
class BankInfoGetRsp(ResponsePacket):
"""Response to a(n) BankInfoGet command."""
@@ -1930,6 +2017,8 @@ RESPONSE_LUT = {
0xA6: {"object": AddrPublicationRemoveRsp, "name": "AddrPublicationRemove"},
0xAB: {"object": PacketSendRsp, "name": "PacketSend"},
0xAF: {"object": NetStateGetRsp, "name": "NetStateGet"},
+ 0xB0: {"object": HBPublicationGetRsp, "name": "HBPublicationGet"},
+ 0xB2: {"object": HBSubscriptionGetRsp, "name": "HBSubscriptionGet"},
0xD4: {"object": BankInfoGetRsp, "name": "BankInfoGet"},
0xD6: {"object": StateGetRsp, "name": "StateGet"},
0xE1: {"object": ModelPubAddrGetRsp, "name": "ModelPubAddrGet"},
2. nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/include/serial_cmd.h
diff --git a/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/include/serial_cmd.h b/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/include/serial_cmd.h
index 11c94a6f..1118e6fc 100644
--- a/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/include/serial_cmd.h
+++ b/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/include/serial_cmd.h
@@ -155,6 +155,10 @@
#define SERIAL_OPCODE_CMD_MESH_CONFIG_SERVER_BIND (0xAD) /**< Params: @ref serial_cmd_mesh_config_server_devkey_bind_t */
#define SERIAL_OPCODE_CMD_MESH_NET_STATE_SET (0xAE) /**< Params: @ref serial_cmd_mesh_net_state_set_t */
#define SERIAL_OPCODE_CMD_MESH_NET_STATE_GET (0xAF) /**< Params: None. */
+#define SERIAL_OPCODE_CMD_MESH_HB_PUBLICATION_GET (0xB0) /**< Params: None. */
+#define SERIAL_OPCODE_CMD_MESH_HB_PUBLICATION_SET (0xB1) /**< Params: @ref serial_cmd_mesh_hb_publication_set_t */
+#define SERIAL_OPCODE_CMD_MESH_HB_SUBSCRIPTION_GET (0xB2) /**< Params: None. */
+#define SERIAL_OPCODE_CMD_MESH_HB_SUBSCRIPTION_SET (0xB3) /**< Params: @ref serial_cmd_mesh_hb_subscription_set_t */
#define SERIAL_OPCODE_CMD_RANGE_MESH_END (0xBF) /**< MESH range end. */
#define SERIAL_OPCODE_CMD_RANGE_DFU_START (0xD0) /**< DFU range start. */
@@ -518,6 +522,25 @@ typedef struct __attribute((packed))
uint32_t next_seqnum_block; /**< The first sequence number block which is not yet allocated. */
} serial_cmd_mesh_net_state_set_t;
+/** Heartbeat publication set command parameters */
+typedef struct __attribute((packed))
+ uint16_t dst; /**< The destination to send heartbeat messages.*/
+ uint32_t count; /**< How many messages to send.*/
+ uint32_t period; /**< What interval to send messages.*/
+ uint8_t ttl; /**< Initial TTL.*/
+ uint16_t features; /**< The features that trigger sending messages when changed.*/
+ uint16_t netkey_index; /**< The global NetKey Index of the Netkey used to send.*/
+} serial_cmd_mesh_hb_publication_set_t;
+/** Heartbeat subscription set command parameters */
+ uint16_t src; /**< The unicast source address for messages a node shall process.*/
+ uint16_t dst; /**< The destination to receive heartbeat messages.*/
+ uint32_t period; /**< The number of seconds left for processing messages.*/
+} serial_cmd_mesh_hb_subscription_set_t;
/** Mesh command parameters. */
typedef union __attribute((packed))
@@ -549,6 +572,8 @@ typedef union __attribute((packed))
serial_cmd_mesh_packet_send_t packet_send; /**< Packet send parameters. */
serial_cmd_mesh_config_server_devkey_bind_t config_server_devkey_bind; /**< Configuration Server: device key bind parameters. */
serial_cmd_mesh_net_state_set_t net_state_set; /**< Net state set parameters */
+ serial_cmd_mesh_hb_publication_set_t hb_publication_set; /**< Heartbeat Publication set parameters */
+ serial_cmd_mesh_hb_subscription_set_t hb_subscription_set; /**< Heartbeat Subscription set parameters */
} serial_cmd_mesh_t;
/* **** PB-MESH Client **** */
3. nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/include/serial_cmd_rsp.h
diff --git a/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/include/serial_cmd_rsp.h b/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/include/serial_cmd_rsp.h
index 00f4d45b..f1733aa7 100644
--- a/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/include/serial_cmd_rsp.h
+++ b/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/include/serial_cmd_rsp.h
@@ -309,6 +309,28 @@ typedef struct __attribute((packed))
uint32_t next_seqnum_block; /**< The start of the next unused sequence number block. */
} serial_evt_cmd_rsp_data_net_state_get_t;
+/** Command response to @ref SERIAL_OPCODE_CMD_MESH_HB_PUBLICATION_GET with the current heartbeat publication state */
+ uint8_t count_log; /**< How many messages to send.*/
+ uint8_t period_log; /**< What interval to send messages.*/
+} serial_evt_cmd_rsp_data_hb_publication_get_t;
+/** Command response to @ref SERIAL_OPCODE_CMD_MESH_HB_SUBSCRIPTION_GET with the current heartbeat subscription state */
+ uint8_t period_log; /**< The number of seconds left for processing messages.*/
+ uint8_t count_log; /**< The number of periodical messages received.*/
+ uint16_t min_hops; /**< The minimum hops value registered when receiving messages.*/
+ uint16_t max_hops; /**< The maximum hops value registered when receiving messages.*/
+} serial_evt_cmd_rsp_data_hb_subscription_get_t;
/** Command response packet. */
@@ -348,7 +370,8 @@ typedef struct __attribute((packed))
serial_evt_cmd_rsp_data_model_init_t model_init; /**< Reserved handle for the initialized model instance. */
serial_evt_cmd_rsp_data_packet_send_t packet_send; /**< Information about the sent packet. */
serial_evt_cmd_rsp_data_net_state_get_t net_state_get; /**< Net state. */
+ serial_evt_cmd_rsp_data_hb_publication_get_t hb_publication_get; /**< Heartbeat Publication States. */
+ serial_evt_cmd_rsp_data_hb_subscription_get_t hb_subscription_get; /**< Heartbeat Subscription States. */
} data; /**< Optional command response data. */
} serial_evt_cmd_rsp_t;
4. nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/src/serial_handler_mesh.c
diff --git a/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/src/serial_handler_mesh.c b/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/src/serial_handler_mesh.c
index 655cdcd3..25fd52ff 100644
--- a/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/src/serial_handler_mesh.c
+++ b/nrf5_SDK_for_Mesh_v5.0.0_src/mesh/serial/src/serial_handler_mesh.c
@@ -54,6 +54,7 @@
#include "mesh_opt_net_state.h"
#include "mesh_config_entry.h"
#include "mesh_config_listener.h"
+#include "heartbeat.h"
/* Ensure that we're mapping the size of the serial parameter to the
* dsm_handle_t. If this triggers, someone changed the size of the
@@ -488,6 +489,143 @@ static void handle_net_state_get(const serial_packet_t * p_cmd)
serial_handler_common_cmd_rsp_nodata_on_error(p_cmd->opcode, status, (uint8_t *)&rsp, sizeof(rsp));
+static inline uint8_t heartbeat_pubsub_period_encode(uint32_t period)
+ if (period == 0)
+ return 0x00;
+ else if (period <= HEARTBEAT_MAX_PERIOD)
+ return (log2_get(period) + 1);
+ else
+ NRF_MESH_ASSERT(false);
+ return HEARTBEAT_MAX_PERIOD_LOG;
+static inline uint8_t heartbeat_publication_count_encode(uint32_t count)
+ if (count <= 1)
+ return count;
+ else if (count <= HEARTBEAT_MAX_COUNT)
+ /* Finding smallest n where 2^(n-1) is greater than or equal to the count value */
+ return (log2_get(count - 1) + 1 + 1);
+ else if (count == HEARTBEAT_INF_COUNT)
+ return HEARTBEAT_INF_COUNT_LOG;
+ else
+ return HEARTBEAT_MAX_COUNT_LOG;
+static inline uint8_t heartbeat_subscription_count_encode(uint32_t count)
+ if (count == 0)
+ return 0x00;
+ /* Finding largest n where 2^(n-1) is less than or equal to the count value */
+ return (log2_get(count) + 1);
+ else
+static void handle_heartbeat_publication_get(const serial_packet_t * p_cmd)
+ const heartbeat_publication_state_t * p_hb_pub = heartbeat_publication_get();
+ serial_evt_cmd_rsp_data_hb_publication_get_t rsp = {
+ .dst = p_hb_pub->dst,
+ .count_log = heartbeat_publication_count_encode(p_hb_pub->count),
+ .period_log = heartbeat_pubsub_period_encode(p_hb_pub->period),
+ .ttl = p_hb_pub->ttl,
+ .features = p_hb_pub->features,
+ .netkey_index = p_hb_pub->netkey_index
+ serial_cmd_rsp_send(p_cmd->opcode, SERIAL_STATUS_SUCCESS, (uint8_t *)&rsp, sizeof(rsp));
+static void handle_heartbeat_publication_set(const serial_packet_t * p_cmd)
+ uint32_t status;
+ const heartbeat_publication_state_t hb_pub = {
+ .dst = p_cmd->payload.cmd.mesh.hb_publication_set.dst,
+ .count = p_cmd->payload.cmd.mesh.hb_publication_set.count,
+ .period = p_cmd->payload.cmd.mesh.hb_publication_set.period,
+ .ttl = p_cmd->payload.cmd.mesh.hb_publication_set.ttl,
+ .features = p_cmd->payload.cmd.mesh.hb_publication_set.features,
+ .netkey_index = p_cmd->payload.cmd.mesh.hb_publication_set.netkey_index
+ /* This is specifically required for INVALID_NETKEY status code */
+ if (dsm_net_key_index_to_subnet_handle(p_cmd->payload.cmd.mesh.hb_publication_set.netkey_index)
+ == DSM_HANDLE_INVALID)
+ status = NRF_ERROR_INVALID_DATA;
+ else
+ status = heartbeat_publication_set(&hb_pub);
+ serial_handler_common_cmd_rsp_nodata_on_error(p_cmd->opcode, status, NULL, 0);
+static void handle_heartbeat_subscription_get(const serial_packet_t * p_cmd)
+ const heartbeat_subscription_state_t * p_hb_sub = heartbeat_subscription_get();
+ serial_evt_cmd_rsp_data_hb_subscription_get_t rsp;
+ /* When the Heartbeat Subscription Source or Destination state is set to the unassigned address,
+ the value of - the Source and Destination fields of the Status message shall be set to the
+ unassigned address and the values of the CountLog, PeriodLog, MinHops, and MaxHops fields shall
+ be set to 0x00. Refer to @tagMeshSp section 4.4.1.2.16 */
+ if (p_hb_sub->src == NRF_MESH_ADDR_UNASSIGNED ||
+ p_hb_sub->dst == NRF_MESH_ADDR_UNASSIGNED)
+ memset(&rsp, 0, sizeof(serial_evt_cmd_rsp_data_hb_subscription_get_t));
+ else
+ rsp.src = p_hb_sub->src;
+ rsp.dst = p_hb_sub->dst;
+ rsp.count_log = heartbeat_subscription_count_encode(p_hb_sub->count);
+ rsp.period_log = heartbeat_pubsub_period_encode(p_hb_sub->period);
+ rsp.min_hops = p_hb_sub->min_hops;
+ rsp.max_hops = p_hb_sub->max_hops;
+static void handle_heartbeat_subscription_set(const serial_packet_t * p_cmd)
+ uint32_t status;
+ const heartbeat_subscription_state_t hb_sub = {
+ .src = p_cmd->payload.cmd.mesh.hb_subscription_set.src,
+ .dst = p_cmd->payload.cmd.mesh.hb_subscription_set.dst,
+ .period = p_cmd->payload.cmd.mesh.hb_subscription_set.period,
+ /* other state values shall remain unchanged, see @tagMeshSp section 4.4.1.2.16 */
+ status = heartbeat_subscription_set(&hb_sub);
* Static functions
@@ -527,7 +665,11 @@ static const mesh_serial_cmd_handler_t m_handlers[] =
{SERIAL_OPCODE_CMD_MESH_STATE_CLEAR, 0, 0, handle_cmd_clear},
{SERIAL_OPCODE_CMD_MESH_CONFIG_SERVER_BIND, sizeof(serial_cmd_mesh_config_server_devkey_bind_t), 0, handle_config_devkey_bind},
{SERIAL_OPCODE_CMD_MESH_NET_STATE_SET, sizeof(serial_cmd_mesh_net_state_set_t), 0, handle_net_state_set},
- {SERIAL_OPCODE_CMD_MESH_NET_STATE_GET, 0, 0, handle_net_state_get}
+ {SERIAL_OPCODE_CMD_MESH_NET_STATE_GET, 0, 0, handle_net_state_get},
+ {SERIAL_OPCODE_CMD_MESH_HB_PUBLICATION_GET, 0, 0, handle_heartbeat_publication_get},
+ {SERIAL_OPCODE_CMD_MESH_HB_PUBLICATION_SET, sizeof(serial_cmd_mesh_hb_publication_set_t), 0, handle_heartbeat_publication_set},
+ {SERIAL_OPCODE_CMD_MESH_HB_SUBSCRIPTION_GET, 0, 0, handle_heartbeat_subscription_get},
+ {SERIAL_OPCODE_CMD_MESH_HB_SUBSCRIPTION_SET, sizeof(serial_cmd_mesh_hb_subscription_set_t), 0, handle_heartbeat_subscription_set}
static void mesh_config_listener_cb(mesh_config_change_reason_t reason, mesh_config_entry_id_t id, const void * p_entry)
  • The post has some problem of code format, so uploaded again.
    +    Parameters
    +        dst : uint16_t
    +        count : uint32_t
    +        period : uint32_t
    +        ttl : uint8_t
    +            Initial TTL.
    +    Return
    +    Parameters
    +        src : uint16_t
    +        dst : uint16_t
    +        period : uint32_t
    +        __data = {}
    +        __data = {}
    @@ -54,6 +54,7 @@
    +    if (period == 0)
    +        return 0x00;
    +    else
    +    if (count <= 1)
    +        return count;
    +    else
    +    if (count == 0)
    +        return 0x00;
    +    else
    +    uint32_t status;
    +    else
    +    else
    +    uint32_t status;
     * Static functions
