nrf52840 ANT impedance clarification
I use the nRF52840-QIAA and in the datasheet are 2 different reference designs for the ANT pin. 3 or 4 component matching and filter network. When I calculate the impedance of the 2 filters I got 2 complete different impedance.
 Z = 112Ω - j15Ω
  Z = 65.8Ω - j30.5Ω
I found here the impedance of 111.8 - 32.9j which would match with the 3 component solution. But I can't explain the impedance for the 4 component solution. Could you please explain why there is such a big difference in this 2 different reference designs.
Could you please provide the impedance of the ANT pin. If the output impedance is dependent from the output power than I am interested in the values of 0 and 8 dBm.
As my antenna has not 50 Ohm I would add only one matching / filtering network from ANT pin to antenna fed point.
    the matching network with four components are better at filtering harmonics, so if your planning to use 8 dBm as TX power, we recommend the one with four matching components.
    We do recommend that you use two matching networks, one for the radio and one for the antenna. This is to make sure that you can adjust the values, for your specific design, making sure that you are able to pass the certification criteria's.
    Since the PC is not designed to see a 50 Ohm load, so we can't do the measurements on the antenna pin directly. But we have done measurements on the matching networks. nRf52840 QIAA matching network (1).pdfnRF52833 QIAA matching network.pdf
    Again, I recommend that you have two matching network, so that you have a 50 Ohm reference point, to do conducted measurements.
    Kaja
  • Hi
    Thanks for the reply and the document. I have some questions about the documents and its measurements.
    1. Measurement was done with HW revision C0. Is it for HW revision F0 still the same?
    2. The measurements shows that the impedance vary with the output power, so the matching should be done according the selected output power?
    3. If I do matching for max output power, what happens with the RX path? Is max output power matching equal perfect RX matching?
    4. The 2 port measurements I don't understand. Is this the measurement of the matching network. If yes, how does this matching network look like.
    1. Yes, the radio is the same.
    2. Yes it varies with output power, so we do a tuning of the components values with TX in channel 2, 40 and 80, and adjust to get low harmonics and high output power. Only matching based on impedance would not work, as harmonics will vary from channel to channel. You can have a look at our RF performance test guidelines
    3. When it's adjusted for TX, it's usually good for RX as well, it very rarely/never that I need to adjust the components for RX, when it's tuned properly for TX,
    4. Yes, it's a measurements of the matching network:
    The two ports are the ports on the VNA.
    Note: We offer to do RF tuning and antenna tuning for you, this is a free service we provide for our costumers.
    Kaja
  • Hi Kaja
    I simulated our layout and matching component values for IC-ANT to 50 Ohm point. I have used S2P-parameter file found from HERE as reference.
    With slight component tuning I was able to get quite nice correlation with your measured S-parameter file and my simulation model. We can now proceed to our first prototype build with these questimated/simulated values:
    We have also 2nd design with your three component reference matching circuitry. Would it be possible to have S-parameter file for this reference design matching circuit?
    Kind Regards
    Jouni
