We were developing an nRF52840 device and were working on MCUBOOT DFU firmware updates, and accidentally did an update rather than an upgrade, and now my nRF52840DK is bricked. I have two more on order as backup, but I figure it is a good learning experience to learn how to recover.
I have done all the things listed in this article.
https://devzone.nordicsemi.com/f/nordic-q-a/24592/my-nrf52-nrf51-dk-kit-doesn-t-work
Using my Windows 11 laptop, I can see the BOOTLOADER in Device Manager. I can reinstall the j-link-ob-sam3u128-v2-nordicsemi-170724.bin file. I have updated J-Link drivers. I can connect my Windows laptop to a separate nRF52832DK and everything works, so the development environment seems correct. I've tried these things with the IF BOOT/RESET switch held at power up, and not. I've tried these things on my MacBook, too.
When I tried to do a "nrjprog --recover --log", I get the log copied in below with a lot of "-1" responses.
I found a post about using a J-Link Commander to recover a device, but this post is more than 8 years old and doesn't cover the nRF52840DK.
Any thoughts on how to resurrect my trusty DK?
Best,
Steve
[2022-Apr-20 09:45:28] [ info] --------------------------------------------------------------------------------
[2022-Apr-20 09:45:28] [ info] nrfjprog --recover --log
[2022-Apr-20 09:45:28] [ info] nrfjprog version 10.15.4 external
[2022-Apr-20 09:45:28] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
[2022-Apr-20 09:45:28] [ info] Library loaded, loading member functions.
[2022-Apr-20 09:45:28] [ info] Member functions succesfully loaded.
[2022-Apr-20 09:45:28] [debug] [ Client] - open
[2022-Apr-20 09:45:28] [debug] [ Client] - start
[2022-Apr-20 09:45:28] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence c8b940f0-d928-4586-a91b-2f85557e7470.
[2022-Apr-20 09:45:28] [trace] [ Client] - Command open executed for 25 milliseconds with result 0
[2022-Apr-20 09:45:28] [debug] [ Client] - enum_emu_snr
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Apr-20 09:45:28] [debug] [ JLink] - Logger sink registered in JLink logger
[2022-Apr-20 09:45:28] [debug] [ nRFXX] - open
[2022-Apr-20 09:45:28] [debug] [ nRFXX] - just_check_family
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - open_dll
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Apr-20 09:45:28] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.7.64.3.dylib.
[2022-Apr-20 09:45:28] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Apr-20 09:45:28] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - dll_version
[2022-Apr-20 09:45:28] [ info] [SeggerBackend] - Segger dll version 7.64.c loaded.
[2022-Apr-20 09:45:28] [trace] [ Worker] - Command open executed for 12 milliseconds with result 0
[2022-Apr-20 09:45:28] [debug] [ nRFXX] - enum_emu_con_info
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Apr-20 09:45:28] [trace] [ Worker] - Command enum_emu_con_info executed for 0 milliseconds with result 0
[2022-Apr-20 09:45:28] [trace] [ Client] - Command enum_emu_con_info executed for 6 milliseconds with result 0
[2022-Apr-20 09:45:28] [debug] [ Client] - connect_to_emu_with_snr
[2022-Apr-20 09:45:28] [debug] [ nRFXX] - connect_to_emu_with_snr
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Apr-20 09:45:28] [trace] [ JLink] - Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 20 2022 16:43:31
[2022-Apr-20 09:45:28] [trace] [ JLink] - Hardware: V1.00
[2022-Apr-20 09:45:28] [trace] [ JLink] - S/N: 683792306
[2022-Apr-20 09:45:28] [trace] [ JLink] - OEM: SEGGER
[2022-Apr-20 09:45:28] [trace] [ JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2022-Apr-20 09:45:28] [trace] [ JLink] - USB speed mode: High speed (480 MBit/s)
[2022-Apr-20 09:45:28] [trace] [ JLink] - TELNET listener socket opened on port 19021
[2022-Apr-20 09:45:28] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2022-Apr-20 09:45:28] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 5.250ms returns "O.K."
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_HasError()
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_Lock()
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_GetHWStatus(...)
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.099ms returns 0
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.169ms returns 0x01
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.001ms returns 0x00
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.007ms returns 0
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.355ms returns 0x00
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_SetSpeed(2000)
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.064ms
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_GetSN()
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.002ms returns 683792306
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - read_debug_port_idr
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - read_debug_port_register
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - coresight_configure
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 102.375ms returns 0
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.660ms returns -1
[2022-Apr-20 09:45:28] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.614ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.654ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.647ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.689ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.637ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.990ms returns 0
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
[2022-Apr-20 09:45:28] [trace] [ JLink] - failed
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.641ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.611ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.623ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.618ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.601ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.621ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.642ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.607ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.619ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.592ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.713ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.624ms returns -1
[2022-Apr-20 09:45:28] [trace] [ Client] - Command connect_to_emu_with_snr executed for 175 milliseconds with result 0
[2022-Apr-20 09:45:28] [debug] [ Client] - read_connected_emu_snr
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.631ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.622ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.644ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.617ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.627ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - Value=0xFFFFF477
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.708ms returns 0
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.005ms
[2022-Apr-20 09:45:28] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 169 milliseconds with result 0
[2022-Apr-20 09:45:28] [debug] [ nRFXX] - read_connected_emu_snr
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_IsOpen()
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.004ms returns 0x01
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - read_connected_emu_snr
[2022-Apr-20 09:45:28] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2022-Apr-20 09:45:28] [trace] [ Client] - Command read_connected_emu_snr executed for 6 milliseconds with result 0
[2022-Apr-20 09:45:28] [debug] [ Client] - read_device_family
[2022-Apr-20 09:45:28] [debug] [ nRFXX] - read_device_family
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.003ms returns 0x01
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.595ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.581ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.582ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.594ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.576ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.572ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.589ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.600ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.605ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.613ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.612ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.632ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.649ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.603ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.604ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.606ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.666ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.017ms
[2022-Apr-20 09:45:28] [trace] [ Worker] - Command read_device_family executed for 49 milliseconds with result -102
[2022-Apr-20 09:45:28] [trace] [ Client] - Command read_device_family executed for 56 milliseconds with result -102
[2022-Apr-20 09:45:28] [debug] [ nRFXX] - close
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.005ms returns 0x01
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - close
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - is_connected_to_device
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_IsConnected()
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.003ms returns FALSE
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.645ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.673ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.628ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.664ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.643ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.629ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.667ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.693ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.616ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.580ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.691ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.734ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.593ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.626ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.636ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 1.698ms returns -1
[2022-Apr-20 09:45:28] [trace] [ JLink] - - 0.015ms
[2022-Apr-20 09:45:28] [trace] [ JLink] - JLINK_Close()
[2022-Apr-20 09:45:28] [debug] [SeggerBackend] - Segger Backend closed.
[2022-Apr-20 09:45:28] [debug] [ nRFXX] - nRF family DLL closed
[2022-Apr-20 09:45:28] [trace] [ Client] - Command close executed for 92 milliseconds with result 0
[2022-Apr-20 09:45:28] [debug] [ Client] - terminate
[2022-Apr-20 09:45:28] [trace] [ Client] - Command terminate executed for 6 milliseconds with result 0
[2022-Apr-20 09:45:28] [trace] [ Worker] - Command close executed for 88 milliseconds with result 0
[2022-Apr-20 09:45:28] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2022-Apr-20 09:45:28] [trace] [ Worker] - Executed 7 commands for 318 milliseconds
[2022-Apr-20 09:45:28] [debug] [ Client] - Child process terminated with result 0
[2022-Apr-20 09:45:29] [trace] [ Client] - Executed 7 commands for 366 milliseconds
[2022-Apr-20 09:45:29] [debug] [ Client] - terminate
