nRF9160 SPM problems
Hi!
I need to modify the code of the secure and the non-secure images of my project.
I tried to follow this guide https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/using-a-custom-secure-partition-manager-wtih-your-application but I encountered some issues: I need to use the last version of Toolchain (1.9.1) and with that, it doesn't run.
The second solution that I tried is to create two different projects, one in the secure domain (like here https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/spm/README.html)  and one in the non-secure domain (I used my main project that works fine). To do that I suppose that there is the need to include this command "CONFIG_SPM=n" in the prj.conf file but when I build that I receive the following errors:
/opt/nordic/ncs/v1.9.1/nrf/lib/nrf_modem_lib/shmem_sanity.c:9:10: fatal error: pm_config.h: No such file or directory
    9 | #include <pm_config.h>
compilation terminated.
[151/188] Building C object zephyr/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards_arm_nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[152/188] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
[153/188] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[154/188] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc_armcommon_cortex_m.a
[155/188] Building C object modules/nrf/lib/at_cmd_parser/CMakeFiles/.._nrflib_at_cmd_parser.dir/at_params.c.obj
[156/188] Building C object modules/nrf/lib/at_cmd_parser/CMakeFiles/.._nrflib_at_cmd_parser.dir/at_cmd_parser.c.obj
[157/188] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/.._nrflib_nrf_modem_lib.dir/nrf_modem_os.c.obj
FAILED: modules/nrf/lib/nrf_modem_lib/CMakeFiles/.._nrflib_nrf_modem_lib.dir/nrf_modem_os.c.obj
ccache /opt/nordic/ncs/v1.9.1/toolchain/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.7.99-ncs1-1 -DKERNEL -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DUSE_PARTITION_MANAGER=0 -D_LINUX_ERRNO_EXTENSIONS_ -D_PROGRAM_START -DZEPHYR=1 -I/opt/nordic/ncs/v1.9.1/zephyr/include -I/Users/lorenzobrancaleoni/Progetti/Progetto_ESP/qrCodeReader/main_project/build/zephyr/include/generated -I/opt/nordic/ncs/v1.9.1/zephyr/soc/arm/nordic_nrf/nrf91 -I/opt/nordic/ncs/v1.9.1/zephyr/lib/libc/newlib/include -I/opt/nordic/ncs/v1.9.1/zephyr/soc/arm/nordic_nrf/common/. -I/opt/nordic/ncs/v1.9.1/zephyr/subsys/net/lib/sockets/. -I/opt/nordic/ncs/v1.9.1/zephyr/subsys/net/lib/tls_credentials/. -I/opt/nordic/ncs/v1.9.1/nrf/include -I/opt/nordic/ncs/v1.9.1/nrf/lib/at_cmd_parser/include -I/opt/nordic/ncs/v1.9.1/modules/lib/cjson -I/opt/nordic/ncs/v1.9.1/nrf/modules/cjson/include -I/opt/nordic/ncs/v1.9.1/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v1.9.1/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v1.9.1/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v1.9.1/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v1.9.1/zephyr/modules/hal_nordic/nrfx/. -I/opt/nordic/ncs/v1.9.1/nrfxlib/nrf_modem/include -O0 -imacros /Users/lorenzobrancaleoni/Progetti/Progetto_ESP/qrCodeReader/main_project/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -imacros /opt/nordic/ncs/v1.9.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/Users/lorenzobrancaleoni/Progetti/Progetto_ESP/qrCodeReader/main_project=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v1.9.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v1.9.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -MD -MT modules/nrf/lib/nrf_modem_lib/CMakeFiles/..nrflibnrf_modem_lib.dir/nrf_modem_os.c.obj -MF modules/nrf/lib/nrf_modem_lib/CMakeFiles/..nrflibnrf_modem_lib.dir/nrf_modem_os.c.obj.d -o modules/nrf/lib/nrf_modem_lib/CMakeFiles/..nrflib_nrf_modem_lib.dir/nrf_modem_os.c.obj -c /opt/nordic/ncs/v1.9.1/nrf/lib/nrf_modem_lib/nrf_modem_os.c
/opt/nordic/ncs/v1.9.1/nrf/lib/nrf_modem_lib/nrf_modem_os.c:18:10: fatal error: pm_config.h: No such file or directory
   18 | #include <pm_config.h>
[158/188] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/.._nrflib_nrf_modem_lib.dir/nrf_modem_lib.c.obj
FAILED: modules/nrf/lib/nrf_modem_lib/CMakeFiles/.._nrflib_nrf_modem_lib.dir/nrf_modem_lib.c.obj
ccache /opt/nordic/ncs/v1.9.1/toolchain/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.7.99-ncs1-1 -DKERNEL -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DUSE_PARTITION_MANAGER=0 -D_LINUX_ERRNO_EXTENSIONS_ -D_PROGRAM_START -DZEPHYR=1 -I/opt/nordic/ncs/v1.9.1/zephyr/include -I/Users/lorenzobrancaleoni/Progetti/Progetto_ESP/qrCodeReader/main_project/build/zephyr/include/generated -I/opt/nordic/ncs/v1.9.1/zephyr/soc/arm/nordic_nrf/nrf91 -I/opt/nordic/ncs/v1.9.1/zephyr/lib/libc/newlib/include -I/opt/nordic/ncs/v1.9.1/zephyr/soc/arm/nordic_nrf/common/. -I/opt/nordic/ncs/v1.9.1/zephyr/subsys/net/lib/sockets/. -I/opt/nordic/ncs/v1.9.1/zephyr/subsys/net/lib/tls_credentials/. -I/opt/nordic/ncs/v1.9.1/nrf/include -I/opt/nordic/ncs/v1.9.1/nrf/lib/at_cmd_parser/include -I/opt/nordic/ncs/v1.9.1/modules/lib/cjson -I/opt/nordic/ncs/v1.9.1/nrf/modules/cjson/include -I/opt/nordic/ncs/v1.9.1/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v1.9.1/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v1.9.1/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v1.9.1/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v1.9.1/zephyr/modules/hal_nordic/nrfx/. -I/opt/nordic/ncs/v1.9.1/nrfxlib/nrf_modem/include -O0 -imacros /Users/lorenzobrancaleoni/Progetti/Progetto_ESP/qrCodeReader/main_project/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -imacros /opt/nordic/ncs/v1.9.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/Users/lorenzobrancaleoni/Progetti/Progetto_ESP/qrCodeReader/main_project=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v1.9.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v1.9.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -MD -MT modules/nrf/lib/nrf_modem_lib/CMakeFiles/..nrflibnrf_modem_lib.dir/nrf_modem_lib.c.obj -MF modules/nrf/lib/nrf_modem_lib/CMakeFiles/..nrflibnrf_modem_lib.dir/nrf_modem_lib.c.obj.d -o modules/nrf/lib/nrf_modem_lib/CMakeFiles/..nrflib_nrf_modem_lib.dir/nrf_modem_lib.c.obj -c /opt/nordic/ncs/v1.9.1/nrf/lib/nrf_modem_lib/nrf_modem_lib.c
/opt/nordic/ncs/v1.9.1/nrf/lib/nrf_modem_lib/nrf_modem_lib.c:14:10: fatal error: pm_config.h: No such file or directory
   14 | #include <pm_config.h>
[159/188] Building C object modules/nrf/lib/at_monitor/CMakeFiles/.._nrflib_at_monitor.dir/at_monitor.c.obj
[160/188] Building C object modules/nrf/lib/at_host/CMakeFiles/.._nrflib_at_host.dir/at_host.c.obj
[161/188] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c.obj
FAILED: zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c.obj
ccache /opt/nordic/ncs/v1.9.1/toolchain/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.7.99-ncs1-1 -DKERNEL -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DUSE_PARTITION_MANAGER=0 -D_LINUX_ERRNO_EXTENSIONS_ -D_PROGRAM_START -DZEPHYR_SUPERVISOR_ -D_ZEPHYR=1 -I/opt/nordic/ncs/v1.9.1/zephyr/include -I/Users/lorenzobrancaleoni/Progetti/Progetto_ESP/qrCodeReader/main_project/build/zephyr/include/generated -I/opt/nordic/ncs/v1.9.1/zephyr/soc/arm/nordic_nrf/nrf91 -I/opt/nordic/ncs/v1.9.1/zephyr/lib/libc/newlib/include -I/opt/nordic/ncs/v1.9.1/zephyr/soc/arm/nordic_nrf/common/. -I/opt/nordic/ncs/v1.9.1/zephyr/subsys/net/lib/sockets/. -I/opt/nordic/ncs/v1.9.1/zephyr/subsys/net/lib/tls_credentials/. -I/opt/nordic/ncs/v1.9.1/nrf/include -I/opt/nordic/ncs/v1.9.1/nrf/lib/at_cmd_parser/include -I/opt/nordic/ncs/v1.9.1/modules/lib/cjson -I/opt/nordic/ncs/v1.9.1/nrf/modules/cjson/include -I/opt/nordic/ncs/v1.9.1/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v1.9.1/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v1.9.1/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v1.9.1/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v1.9.1/zephyr/modules/hal_nordic/nrfx/. -I/opt/nordic/ncs/v1.9.1/nrfxlib/nrf_modem/include -O0 -imacros /Users/lorenzobrancaleoni/Progetti/Progetto_ESP/qrCodeReader/main_project/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -imacros /opt/nordic/ncs/v1.9.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/Users/lorenzobrancaleoni/Progetti/Progetto_ESP/qrCodeReader/main_project=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v1.9.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v1.9.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -MD -MT zephyr/drivers/serial/CMakeFiles/driversserial.dir/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c.obj -MF zephyr/drivers/serial/CMakeFiles/driversserial.dir/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c.obj.d -o zephyr/drivers/serial/CMakeFiles/drivers_serial.dir/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c.obj -c /opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c
In file included from /opt/nordic/ncs/v1.9.1/zephyr/include/arch/arm/aarch32/arch.h:20,
                 from /opt/nordic/ncs/v1.9.1/zephyr/include/arch/cpu.h:19,
                 from /opt/nordic/ncs/v1.9.1/zephyr/include/kernel_includes.h:33,
                 from /opt/nordic/ncs/v1.9.1/zephyr/include/kernel.h:17,
                 from /opt/nordic/ncs/v1.9.1/zephyr/include/init.h:11,
                 from /opt/nordic/ncs/v1.9.1/zephyr/include/device.h:29,
                 from /opt/nordic/ncs/v1.9.1/zephyr/include/drivers/uart.h:26,
                 from /opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c:7:
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:305:40: error: 'DT_N_INST_0_nordic_nrf_sw_lpuart_BUS_P_label' undeclared here (not in a function)
  305 | #define DT_INST(inst, compat) UTIL_CAT(DT_N_INST, DT_DASH(inst, compat))
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:3022:24: note: in definition of macro 'DT_CAT'
 3022 | #define DT_CAT(a1, a2) a1 ## a2
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:2390:31: note: in expansion of macro 'DT_PROP'
 2390 | #define DT_BUS_LABEL(node_id) DT_PROP(DT_BUS(node_id), label)
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:2383:25: note: in expansion of macro 'DT_CAT'
 2383 | #define DT_BUS(node_id) DT_CAT(node_id, _BUS)
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:2390:39: note: in expansion of macro 'DT_BUS'
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:2771:33: note: in expansion of macro 'DT_BUS_LABEL'
 2771 | #define DT_INST_BUS_LABEL(inst) DT_BUS_LABEL(DT_DRV_INST(inst))
/opt/nordic/ncs/v1.9.1/zephyr/include/sys/util_internal.h:98:26: note: in expansion of macro 'UTIL_PRIMITIVE_CAT'
   98 | #define UTIL_CAT(a, ...) UTIL_PRIMITIVE_CAT(a, _VA_ARGS_)
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:305:31: note: in expansion of macro 'UTIL_CAT'
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:2434:27: note: in expansion of macro 'DT_INST'
 2434 | #define DT_DRV_INST(inst) DT_INST(inst, DT_DRV_COMPAT)
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:2771:46: note: in expansion of macro 'DT_DRV_INST'
/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c:989:15: note: in expansion of macro 'DT_INST_BUS_LABEL'
  989 |  .uart_name = DT_INST_BUS_LABEL(0),
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:305:40: error: 'DT_N_INST_0_nordic_nrf_sw_lpuart_P_req_pin' undeclared here (not in a function); did you mean 'DT_N_INST_0_nordic_nrf_uarte'?
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:2491:34: note: in expansion of macro 'DT_PROP'
 2491 | #define DT_INST_PROP(inst, prop) DT_PROP(DT_DRV_INST(inst), prop)
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:2491:42: note: in expansion of macro 'DT_DRV_INST'
/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c:984:10: note: in expansion of macro 'DT_INST_PROP'
  984 |   .pin = DT_INST_PROP(0, pin_prop) & 0x1F, \
/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c:990:9: note: in expansion of macro 'LPUART_PIN_CFG_INITIALIZER'
  990 |  .req = LPUART_PIN_CFG_INITIALIZER(req_pin),
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:305:40: error: 'DT_N_INST_0_nordic_nrf_sw_lpuart_P_rdy_pin' undeclared here (not in a function)
/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c:991:9: note: in expansion of macro 'LPUART_PIN_CFG_INITIALIZER'
  991 |  .rdy = LPUART_PIN_CFG_INITIALIZER(rdy_pin)
In file included from /opt/nordic/ncs/v1.9.1/zephyr/include/toolchain.h:50,
                 from /opt/nordic/ncs/v1.9.1/zephyr/include/init.h:10,
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:177:36: error: 'DT_N_NODELABEL_lpuart_PARENT_IRQ_IDX_0_VAL_priority' undeclared here (not in a function)
  177 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
/opt/nordic/ncs/v1.9.1/zephyr/include/toolchain/gcc.h:61:51: note: in definition of macro 'BUILD_ASSERT'
   61 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:1847:2: note: in expansion of macro 'DT_CAT'
 1847 |  DT_CAT(node_id, IRQ_IDX##idx##VAL##cell)
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:1874:31: note: in expansion of macro 'DT_IRQ_BY_IDX'
 1874 | #define DT_IRQ(node_id, cell) DT_IRQ_BY_IDX(node_id, 0, cell)
/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1029:14: note: in expansion of macro 'DT_IRQ'
 1029 | BUILD_ASSERT(DT_IRQ(DT_PARENT(DT_NODELABEL(lpuart)), priority) ==
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:326:28: note: in expansion of macro 'UTIL_CAT'
  326 | #define DT_PARENT(node_id) UTIL_CAT(node_id, _PARENT)
/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1029:21: note: in expansion of macro 'DT_PARENT'
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:177:29: note: in expansion of macro 'DT_CAT'
/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1029:31: note: in expansion of macro 'DT_NODELABEL'
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:177:36: error: expression in static assertion is not an integer
In file included from /opt/nordic/ncs/v1.9.1/zephyr/include/drivers/uart.h:26,
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:177:36: error: 'DT_N_NODELABEL_lpuart_FULL_NAME' undeclared here (not in a function)
/opt/nordic/ncs/v1.9.1/zephyr/include/device.h:903:11: note: in definition of macro 'Z_DEVICE_DEFINE'
  903 |   .name = drv_name,     \
/opt/nordic/ncs/v1.9.1/zephyr/include/sys/util_internal.h:64:53: note: in expansion of macro '__DEBRACKET'
   64 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val
/opt/nordic/ncs/v1.9.1/zephyr/include/sys/util_internal.h:59:2: note: in expansion of macro '__GET_ARG2_DEBRACKET'
   59 |  __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code)
/opt/nordic/ncs/v1.9.1/zephyr/include/sys/util_internal.h:54:2: note: in expansion of macro '__COND_CODE'
   54 |  __COND_CODE(_XXXX##_flag, _if_1_code, _else_code)
/opt/nordic/ncs/v1.9.1/zephyr/include/sys/util_macro.h:157:2: note: in expansion of macro 'Z_COND_CODE_1'
  157 |  Z_COND_CODE_1(_flag, _if_1_code, _else_code)
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:649:2: note: in expansion of macro 'COND_CODE_1'
  649 |  COND_CODE_1(DT_NODE_HAS_PROP(node_id, prop), \
/opt/nordic/ncs/v1.9.1/zephyr/include/device.h:203:2: note: in expansion of macro 'DT_PROP_OR'
  203 |  DT_PROP_OR(node_id, label, DT_NODE_FULL_NAME(node_id))
/opt/nordic/ncs/v1.9.1/zephyr/include/devicetree.h:475:36: note: in expansion of macro 'DT_CAT'
  475 | #define DT_NODE_FULL_NAME(node_id) DT_CAT(node_id, _FULL_NAME)
/opt/nordic/ncs/v1.9.1/zephyr/include/device.h:203:29: note: in expansion of macro 'DT_NODE_FULL_NAME'
/opt/nordic/ncs/v1.9.1/zephyr/include/device.h:253:4: note: in expansion of macro 'DEVICE_DT_NAME'
  253 |    DEVICE_DT_NAME(node_id), init_fn,  \
/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1033:1: note: in expansion of macro 'DEVICE_DT_DEFINE'
 1033 | DEVICE_DT_DEFINE(DT_NODELABEL(lpuart), lpuart_init, NULL,
/opt/nordic/ncs/v1.9.1/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1033:18: note: in expansion of macro 'DT_NODELABEL'
[162/188] Building C object modules/nrf/lib/lte_link_control/CMakeFiles/.._nrflib_lte_link_control.dir/lte_lc_helpers.c.obj
[163/188] Building C object modules/nrf/lib/lte_link_control/CMakeFiles/.._nrflib_lte_link_control.dir/lte_lc.c.obj
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/v1.9.1/toolchain/bin/cmake --build /Users/lorenzobrancaleoni/Progetti/Progetto_ESP/qrCodeReader/main_project/build
What should I do? Thank's
