NB-IoT TCP Packet loss and retransmittions
Hardware: nrf9160DK
Modem FW: v1.3.1
We have been evaluating and configuring our proprietary application for NB-IoT, which is initially designed for LTE-M (CAT-M1). The Application is designed to exchange data with the cloud using MQTT over TLS and works fine with LTE-M.
However, when explicitly configured to connect to NB-IoT only network, we see a lot of TLS handshakes getting timed out (even after increasing the TLS timeout from 20 seconds for LTE-M to 90 seconds for NB-IoT).
Evaluating the Network capture files we observed many instances of TCP packet retries especially when a large data is exchanged over several TCP segments (the case where the server and clients exchange the certificates and keys during a TLS handshake).
To remove the dependency of our application and to just test the MQTT over TLS on the NB-IoT network, we switched to using the nrfConnect sample application "asset_tracker_v2".
The "asset_tracker_v2" application was configured to connect to NB-IoT only network and modem trace enabled.
After letting the application execute for a few hours, analysis was done using the application logs, modem trace and network capture.
We still see the same behaviour (TCP packet retransmissions) with the large data exchanges over several TCP segments.
Typical behaviour is observed, after receiving the first TCP segment of a large data packet, the modem seems to be not accepting any further segments for a period of approximately 20 seconds. (see the attached screenshot of the comparison between modem trace(left) and network capture (right))
Are we missing any configuration or can you give an explanation of the behaviour?
Also, attached is the Application Log, Modem Trace and Network capture for your further investigation.attachments.zip
    my initial thought is the LTE-M vs NB-Iot bandwidth e.g.
    Features LTE-M NB-IoT
    Also known as LTE CAT-M1, Enhanced Machine Type Communication (eMTC) LTE Cat-NB1 (3GPP rel 13) LTE Cat-NB2 (3GPP rel 14)
    Bandwidth 1.4 MHz 200 kHz 200 kHz
    Max throughput (DL/UL) 300/375 kbps 30/60 kbps 127/169 kbps
    Latency 50-100ms 1.5-10s
    Typical range <11 km <15 km <15 km
    Mobility/cell reselection Yes No Limited
    Roaming Yes Limited Limited
    Deployment density Up to 50 000 per cell Up to 50 000 per cell Up to 50 000 per cell
    Battery lifetime Up to 12 years1
    What is your location? Do you have equal access to both LTE-M and NB-IoT?
    Will have a look at your attachments, in the meantime please read through our white paper nWP044 - Best practices for cellular IoT development.
    Øyvind
  • A quick look at the log output you provided I find the following reject causes when connecting to NB-IoT
    2022-04-13T08:35:41.826Z DEBUG modem << +CEREG: 2,"640F","0028C515",9,0,9
    2022-04-13T08:35:42.732Z DEBUG modem << +CEREG: 2,"640F","0028C515",9,0,13
    Cause #9 – UE identity cannot be derived by the network.
    This EMM cause is sent to the UE when the network cannot derive the UE’s identity from the GUTI/S-TMSI/P-TMSI and RAI e.g. no matching identity/context in the network or failure to validate the UE’s identity due to integrity check failure of the received message.
    Cause #13 – Roaming not allowed in this tracking area
    This EMM cause is sent to an UE which requests service, or if the network initiates a detach request, in a tracking area of a PLMN which by subscription offers roaming to that UE but not in that tracking area.
    Please verify SIM/status with your network provider.
    Thanks for your response.
    The device being tested is in UK and we are using a test NB-IoT network (using Nutaq).
    The problem is not with registering to a network. The problem is with modem not accepting the TCP segments (which are transmitted by the server, seen in the network  capture. however not getting received on the client-side, seen in the modem trace)
    Have a look at the image in the attachments.zip, where it shows a duration of approximately 20 seconds when the modem doesn't log any TCP packets whereas the server is sending them at the same time.
  • Can you provide more information on what network you are trying to connect to? What version of nRF Connect SDK are you working on?
    From your PCAP I see that you are receiving the following: +CGDCONT: 0,"IP","test123","192.168.3.2",0,0  OK
    The provided log output from LTE Link Monitor has the following output several times:
    2022-04-13T05:18:31.917Z DEBUG modem << [25:52:00.274,871] [0m<inf> event_manager: APP_EVT_DATA_GET_ALL[0m
    2022-04-13T05:18:31.970Z DEBUG modem << [25:52:00.281,524] [0m<inf> event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)[0m
    2022-04-13T05:18:31.971Z DEBUG modem << [25:52:00.299,285] [1;33m<wrn> gnss_module: Failed to set GNSS fix interval, error: -22[0m
    2022-04-13T05:18:31.973Z DEBUG modem << [25:52:00.310,974] [0m<inf> event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED[0m
    2022-04-13T05:18:32.002Z DEBUG modem << [25:52:00.357,696] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2022-04-13T05:18:32.016Z DEBUG modem << [25:52:00.370,574] [1;31m<err> modem_info_params: Link data not obtained: 8 -22[0m
    2022-04-13T05:18:32.038Z DEBUG modem << [25:52:00.388,671] [1;31m<err> modem_info_params: Link data not obtained: 3 -22[0m
    2022-04-13T05:18:32.074Z DEBUG modem << [25:52:00.429,748] [1;31m<err> modem_info_params: Network data not obtained: -66[0m
    2022-04-13T05:18:32.087Z DEBUG modem << [25:52:00.437,774] [1;31m<err> modem_module: modem_info_params_get, error: -11[0m
    2022-04-13T05:18:32.098Z DEBUG modem << [25:52:00.445,678] [0m<inf> event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY[0m
    2022-04-13T05:18:32.145Z DEBUG modem << [25:52:00.501,251] [1;31m<err> modem_info_params: Link data not obtained: 5 -22[0m
    2022-04-13T05:18:32.161Z DEBUG modem << [25:52:00.513,610] [1;31m<err> modem_info_params: Link data not obtained: 8 -22[0m
    2022-04-13T05:18:32.177Z DEBUG modem << [25:52:00.531,677] [1;31m<err> modem_info_params: Link data not obtained: 3 -22[0m
    2022-04-13T05:18:32.217Z DEBUG modem << [25:52:00.572,326] [1;31m<err> modem_info_params: Network data not obtained: -66[0m
    2022-04-13T05:18:32.237Z DEBUG modem << [25:52:00.580,352] [1;31m<err> modem_module: modem_info_params_get, error: -11[0m
    2022-04-13T05:18:32.242Z DEBUG modem << [25:52:00.588,226] [0m<inf> event_manager: MODEM_EVT_BATTERY_DATA_NOT_READY[0m
    Yes, this is the problem from what I can see.
  • We have our test network which is configured for NB-IoT (NB1)
    I agree, you may be seeing the logs showing problems registering to the network as these are complete logs and we may be in the middle of changing some configuration or setting up the test network.
    That's why I am not concerned about the device not registering. What I am more concerned about is when it successfully registers to the network, it faces issues transferring data over TCP packets (The modem seems to not receive any packets for around 20 seconds, highlighted in the screenshot).
