nrfConnect DTM app does not find USB serial port
I try to get the Direct Test Mode App to work on a Windows 10 Notebook. (for System Details see attached system report and verbose logfile).
Software versions:
  • nRF Connect for Desktop v3.11.0
  • Direct TestMode v2.0.1
I use a USB to Serial Converter (FTDI TTL232R-3V3) to connect a custom PCB with an nRF52840. DTM Firmware compiled for this board is flashed to the device. The I/O-Voltage levels have been changed to 3.3V with the nRF command line tools.
The DTM app does not find the USB serial port. When i click on "Select device", it only shows the message"Connect a Nordic development kit to your computer". The driver for the USB serial port is installed. Windows device manager reports it as "COM3" and working properly.
On a different PC, same USB serial cable, same PCB connected, and same version of the app, the device is correctly displayed, i can connect to the DTM firmware running on the board and control the settings. Device appears as "TTL232R-3V3 FTASVGHG" in the list.
Taking this working PC to the RF test lab is not an option, as it is not mobile. I need to get the App to work on the Notebook. Can you help me with that?
Best regards
Frank
# nRFConnect System Report - 2022-04-21T12-44-25.457Z
- System:     Hewlett-Packard HP EliteBook 840 G2
- BIOS:       Hewlett-Packard HPQOEM - 1
- CPU:        1 x Intel Core™ i5-5300U 2.3 GHz 4 cores (2 physical)
- Memory:     4 GB free of 7.8 GB total
- Filesystem: C: (NTFS) 236.2 GB 59.4% used
- OS:         Microsoft Windows 10 Enterprise (10.0.18363) Windows ia32
- Versions
    - kernel: 10.0.18363
    - git:
    - node: 14.16.0
    - python:
    - python3:
    - nrf-device-lib-js: 0.4.5
    - nrf-device-lib: 0.11.0
    - nrfjprog DLL: 10.15.1
    - JLink: JLink_V7.58b
- Connected devices:
2022-04-21T12:45:32.220Z DEBUG Application data folder: C:\Users\locadmin\AppData\Roaming\nrfconnect\pc-nrfconnect-dtm
2022-04-21T12:45:32.326Z INFO Using nrf-device-lib-js version: 0.4.5
2022-04-21T12:45:32.327Z INFO Using nrf-device-lib version: 0.11.0
2022-04-21T12:45:32.327Z INFO Using nrfjprog DLL version: 10.15.1
2022-04-21T12:45:32.328Z INFO Using JLink version: JLink_V7.58b
2022-04-21T12:45:32.335Z VERBOSE [nrfdl][trace](14:45:32.245) [NRFJPROG] [SeggerBackend] [Info] Load library at C:\Program Files (x86)\SEGGER\JLink\JLinkARM.dll.
2022-04-21T12:45:32.338Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Info] Library loaded, loading member functions.
2022-04-21T12:45:32.340Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Info] Member functions succesfully loaded.
2022-04-21T12:45:32.341Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Debug] dll_version
2022-04-21T12:45:32.342Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Info] Segger dll version 7.58.b loaded.
2022-04-21T12:45:32.343Z DEBUG [nrfdl][debug](14:45:32.258) nrfjprog_function return value: 0
2022-04-21T12:45:32.344Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [nRFXX] [Debug] dll_version
2022-04-21T12:45:32.345Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Debug] is_connected_to_emu
2022-04-21T12:45:32.346Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Debug] dll_version
2022-04-21T12:45:32.347Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Debug] is_connected_to_emu
2022-04-21T12:45:32.348Z DEBUG [nrfdl][debug](14:45:32.258) nrfjprog_function return value: 0
2022-04-21T12:45:32.349Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [nRFXX] [Debug] close
2022-04-21T12:45:32.351Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Debug] is_connected_to_emu
2022-04-21T12:45:32.353Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Debug] close
2022-04-21T12:45:32.354Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Debug] disconnect_from_emu
2022-04-21T12:45:32.355Z VERBOSE [nrfdl][trace](14:45:32.258) [NRFJPROG] [SeggerBackend] [Debug] is_connected_to_emu
2022-04-21T12:45:32.356Z VERBOSE [nrfdl][trace](14:45:32.259) [NRFJPROG] [SeggerBackend] [Debug] Segger Backend closed.
2022-04-21T12:45:32.357Z VERBOSE [nrfdl][trace](14:45:32.259) [NRFJPROG] [nRFXX] [Debug] nRF family DLL closed
2022-04-21T12:45:32.358Z VERBOSE [nrfdl][trace](14:45:32.269) DeviceLister::enumerate: Checking future_status of enumerate_task_status
2022-04-21T12:45:32.359Z VERBOSE [nrfdl][trace](14:45:32.269) DeviceLister::enumerate: Waiting for enumerate task to complete
2022-04-21T12:45:32.360Z VERBOSE [nrfdl][trace](14:45:32.269) DeviceLister::enumerate::enumerate_task: Start
2022-04-21T12:45:32.361Z VERBOSE [nrfdl][trace](14:45:32.269) DeviceLister::enumerate::enumerate_task: Device_pool is empty
2022-04-21T12:45:32.361Z VERBOSE [nrfdl][trace](14:45:32.269) DeviceLister::enumerate::enumerate_task: Before async_lister->enumarate
2022-04-21T12:45:32.362Z DEBUG [nrfdl][debug](14:45:32.274) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
2022-04-21T12:45:32.363Z DEBUG [nrfdl][debug](14:45:32.274) Hub device path: \\?\USB#VID_0424&PID_2134#5&27D8BCF7&0&3#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 2, origin: {9E18AB1F-55F3-50DA-8A03-AF55028B5F69}
2022-04-21T12:45:32.364Z DEBUG [nrfdl][debug](14:45:32.274) Starting DeviceIoControl
2022-04-21T12:45:32.365Z DEBUG [nrfdl][debug](14:45:32.279) Getting config descriptor
2022-04-21T12:45:32.366Z DEBUG [nrfdl][debug](14:45:32.279) Iterating descriptors.
2022-04-21T12:45:32.367Z DEBUG [nrfdl][debug](14:45:32.279) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 4ms]
2022-04-21T12:45:32.368Z DEBUG [nrfdl][debug](14:45:32.281) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
2022-04-21T12:45:32.369Z DEBUG [nrfdl][debug](14:45:32.281) Hub device path: \\?\USB#ROOT_HUB30#4&2657E0E3&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 8, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
2022-04-21T12:45:32.370Z DEBUG [nrfdl][debug](14:45:32.281) Starting DeviceIoControl
2022-04-21T12:45:32.371Z DEBUG [nrfdl][debug](14:45:32.281) Getting config descriptor
2022-04-21T12:45:32.372Z DEBUG [nrfdl][debug](14:45:32.281) Iterating descriptors.
2022-04-21T12:45:32.373Z DEBUG [nrfdl][debug](14:45:32.281) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
2022-04-21T12:45:32.373Z DEBUG [nrfdl][debug](14:45:32.282) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
2022-04-21T12:45:32.374Z DEBUG [nrfdl][debug](14:45:32.282) Hub device path: \\?\USB#ROOT_HUB30#4&2657E0E3&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
2022-04-21T12:45:32.376Z DEBUG [nrfdl][debug](14:45:32.282) Starting DeviceIoControl
2022-04-21T12:45:32.377Z DEBUG [nrfdl][debug](14:45:32.282) Getting config descriptor
2022-04-21T12:45:32.378Z DEBUG [nrfdl][debug](14:45:32.282) Iterating descriptors.
2022-04-21T12:45:32.379Z DEBUG [nrfdl][debug](14:45:32.283) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
2022-04-21T12:45:32.381Z DEBUG [nrfdl][debug](14:45:32.285) [->] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB
2022-04-21T12:45:32.382Z DEBUG [nrfdl][debug](14:45:32.285) Hub device path: \\?\USB#ROOT_HUB30#4&2657E0E3&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 7, origin: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
2022-04-21T12:45:32.383Z DEBUG [nrfdl][debug](14:45:32.285) Starting DeviceIoControl
2022-04-21T12:45:32.385Z DEBUG [nrfdl][debug](14:45:32.286) Getting config descriptor
2022-04-21T12:45:32.386Z DEBUG [nrfdl][debug](14:45:32.286) Iterating descriptors.
2022-04-21T12:45:32.388Z DEBUG [nrfdl][debug](14:45:32.286) [<-] NRFDL::Win32::USBPlatformAPI::copyDeviceToUSB [took 0ms]
2022-04-21T12:45:32.388Z DEBUG [nrfdl][debug](14:45:32.286) USBLister: Adding device with serial number: FTASVGHG
2022-04-21T12:45:32.390Z DEBUG [nrfdl][debug](14:45:32.286) USBLister: Adding device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
2022-04-21T12:45:32.392Z VERBOSE [nrfdl][trace](14:45:32.286) DeviceLister::enumerate::enumerate_task: After async_lister->enumarate
2022-04-21T12:45:32.393Z VERBOSE [nrfdl][trace](14:45:32.286) DeviceLister::enumerate: Enumerating with sync lister
2022-04-21T12:45:32.394Z VERBOSE [nrfdl][trace](14:45:32.286) SerialPortLister::enumerate
2022-04-21T12:45:32.394Z VERBOSE [nrfdl][trace](14:45:32.304) DeviceLister::enumerate: Enumerating with sync lister
2022-04-21T12:45:32.395Z VERBOSE [nrfdl][trace](14:45:32.304) JLinkLister::enumerate
2022-04-21T12:45:32.396Z DEBUG [nrfdl][debug](14:45:32.304) [->] NRFDL::UniversalPlatform::JLinkHW::enumerate
2022-04-21T12:45:32.397Z DEBUG [nrfdl][debug](14:45:32.304) [HighLevel][TID:12712] get_connected_probes
2022-04-21T12:45:32.398Z DEBUG [nrfdl][debug](14:45:32.319) nrfjprog_function return value: 0
2022-04-21T12:45:32.399Z DEBUG [nrfdl][debug](14:45:32.319) [<-] NRFDL::UniversalPlatform::JLinkHW::enumerate [took 14ms]
2022-04-21T12:45:32.399Z VERBOSE [nrfdl][trace](14:45:32.319) DeviceLister::enumerate: Enumerating with sync lister
2022-04-21T12:45:32.401Z VERBOSE [nrfdl][trace](14:45:32.319) BrokenLister::enumerate
2022-04-21T12:45:32.402Z VERBOSE [nrfdl][trace](14:45:32.319) DeviceLister::enumerate: Found device with serial number: FTASVGHG
2022-04-21T12:45:32.403Z VERBOSE [nrfdl][trace](14:45:32.319) DeviceLister::enumerate: Found device with serial number: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
2022-04-21T12:45:32.404Z VERBOSE [nrfdl][trace](14:45:32.319) DeviceLister::enumerate: Completed waiting for enumerate task
2022-04-21T12:45:32.405Z VERBOSE [nrfdl][trace](14:45:32.319) DeviceLister::enumerate: done
2022-04-21T12:45:32.442Z DEBUG App pc-nrfconnect-dtm v2.0.1 official
2022-04-21T12:45:32.442Z DEBUG App path: C:\Users\locadmin\.nrfconnect-apps\node_modules\pc-nrfconnect-dtm
2022-04-21T12:45:32.442Z DEBUG nRFConnect 3.11.0, required by the app is (^3.8.0)
2022-04-21T12:45:32.442Z DEBUG nRFConnect path: C:\Users\locadmin\AppData\Local\Programs\nrfconnect\resources\app.asar
2022-04-21T12:45:32.442Z DEBUG HomeDir: C:\Users\locadmin
2022-04-21T12:45:32.443Z DEBUG TmpDir: C:\Users\locadmin\AppData\Local\Temp
