I am not sure what I am missing in this. This is a custom board so there is no other circuitry on this pin other than a pad to monitor the signal changes with.
#define DBG_PIN_NUMBER 9 // P0.09 -> Debug output pin
static void app_vars_init(void)
nrf_gpio_cfg_output(DBG_PIN_NUMBER);
nrf_gpio_pin_write(DBG_PIN_NUMBER, 1);
When my main function calls the init code above, I go and look at the pin and only see a signal output at ground.
nrf_gpio_cfg_input(DBG_PIN_NUMBER, NRF_GPIO_PIN_PULLUP);
If I change the pin to an input with a pullup resistor, I see the 3VDC on the o-scope. So I am pretty sure there is nothing wrong with the pin or any of the traces.
Any idea why when I set this pin to be an output and set the pin high that I do not see 3VDC?
Thanks in advance.
