How to reduce the power consumption of the 9160‘s modem?
I am using 9160 to develop a customer's product, which needs to reduce power consumption as much as possible to prolong the battery life of the product. I know that 9160 communicates with the modem through the default UART0. My product design uses UART2 to communicate with a peripheral.  Setting UART2 to DEVICE_PM_LOW_POWER_STATE alone reduces the current by only about 30uA, whereas setting Uart0 to DEVICE_PM_LOW_POWER_STATE reduces the current by almost 500uA. What I can't understand is,  In fact, the GPIO pin mapped to UART0 is not connected to any line, why do you need to set the low power state to reduce power consumption?
#define MODEM_DEV		"UART_0"
#define BLE_DEV			"UART_2"
	uart_ble = device_get_binding(BLE_DEV);
	if(!uart_ble)
	#ifdef UART_DEBUG
		LOGD("Could not get %s device", BLE_DEV);
		return;
	uart_modem = device_get_binding(MODEM_DEV);
	if(!uart_modem)
	#ifdef UART_DEBUG
		LOGD("Could not get %s device", uart_modem);
		return;
void uart_sleep_out(void)
#ifdef CONFIG_DEVICE_POWER_MANAGEMENT
	if(k_timer_remaining_get(&uart_sleep_in_timer) > 0)
		k_timer_stop(&uart_sleep_in_timer);
	k_timer_start(&uart_sleep_in_timer, K_SECONDS(UART_WAKE_HOLD_TIME_SEC), NULL);
	if(uart_is_waked)
		return;
#if 1
	device_set_power_state(uart_ble, DEVICE_PM_ACTIVE_STATE, NULL, NULL);
	uart_irq_rx_enable(uart_ble);
	uart_irq_tx_enable(uart_ble);
	k_sleep(K_MSEC(10));
#else
	device_set_power_state(uart_modem, DEVICE_PM_ACTIVE_STATE, NULL, NULL);
	uart_irq_rx_enable(uart_modem);
	uart_irq_tx_enable(uart_modem);
	uart_is_waked = true;
#ifdef UART_DEBUG
	LOGD("uart set active success!");
void uart_sleep_in(void)
	if(!uart_is_waked)
		return;
#if 1
	uart_irq_rx_disable(uart_ble);
	uart_irq_tx_disable(uart_ble);
	device_set_power_state(uart_ble, DEVICE_PM_LOW_POWER_STATE, NULL, NULL);
#else
	uart_irq_rx_disable(uart_modem);
	uart_irq_tx_disable(uart_modem);
	device_set_power_state(uart_modem, DEVICE_PM_LOW_POWER_STATE, NULL, NULL);
	uart_is_waked = false;
#ifdef UART_DEBUG
	LOGD("uart set low power success!");
